HMG 2.8.6 (Forum Test)
Here we go again :)
I've made the following changes from 2.8.5 (all of these in Grid (CellNavigation style)):
- Fixed runtime error when 'Value' is not specified at definition.
- Fixed incorrect behavior, when the user clicks outside cell area.
- Optimized control paint.
You must merge the attached file with your current HMG installation (backup first).
Please, test and report any problem.
Thanks in advance.
hmg286.rar
(370.48 KiB) Downloaded 346 times
Re: HMG 2.8.6 (Forum Test)
Hi
Tested.
It's seeming everything is okay :D
When VALUE property omitted, system (perhaps) assume { 0, 0 }. This is also okay, ( instead of {1,1} ) because ITEMS array may be empty.
Thanks a lot.
Best Regards
esgici wrote:Hi
Tested.
Thanks a lot.
Best Regards
Thanks for test.
esgici wrote: When VALUE property omitted, system (perhaps) assume { 0, 0 }. This is also okay, ( instead of {1,1} ) because ITEMS array may be empty.
Yes it is.
In general, a value of '0' for row component means 'no selection'.
Fantastic. Thanks a lot Roberto. I will accommodate.
I tested it. Running without any problem.
Roberto, thank you very much.
Regards.
Thanks to all for the tests.
In the case that all still going fine, I'll do a full release, update the IDE with the CellNavigation property and start the tests to incorporate 'by cell' navigation to Browse.
Thanks Roberto. Expecting the release soon.
