HMG.3.3.0 Patch 3 (32 and 64-bits)
Hi all.
This patch include the previous patch 1 and 2. viewtopic.php?f=43&t=3782
Unzip the patch in c:\hmg.3.3.0\ and execute BuildAllLib.bat and _BuildAllLib64.bat
Please you check for changes made.
The changes I made:
- Now all controls (Button, CheckButton, ToolBarButton, ComboBox, Grid, Tab, Tree, Menu, etc) of the HMG loaded images: BMP, GIF, TIF, JPG and PNG and support the NOTRANSPARENT property
- Print images in formats: BMP, GIF, JPG, TIF, WMF, EMF, CUR and PNG.
@ <nRow> , <nCol> PRINT IMAGE <cImageFileName> | <cImageResourcename>
    WIDTH <nWidth>
    HEIGHT <nHeight>
    [ STRETCH ]
    [ TRANSPARENT ]
    [ TRANSPARENTCOLOR anTransparentColor ]
- DatePicker control --> New property FORMAT <cFormatDate> (see demo)
DatePicker demo:
   DEFINE WINDOW Form_1 ;
      WIDTH 600 HEIGHT 400 ;
      TITLE "HMG DatePicker Format" ;
      MAIN
      @ 10,10 DATEPICKER Date_1 VALUE DATE() WIDTH 280 HEIGHT 50 FORMAT "'Today is:' dddd d MMMM' of 'yyyy"
      @ 10,330 DATEPICKER Date_2 VALUE DATE() FORMAT "yyyy:MM:dd"
      @ 230,10 DATEPICKER Date_3 VALUE DATE() FORMAT "dd/MM/yyyy"
      @ 230,310 DATEPICKER Date_4 VALUE DATE() FORMAT "dd-MM-yyyy"
   CENTER WINDOW Form_1
   ACTIVATE WINDOW Form_1
Note: description of the cDateFormat string
   "d"        The one- or two-digit day.
   "dd"       The two-digit day. Single-digit day values are preceded by a zero.
   "ddd"      The three-character weekday abbreviation.
   "dddd"     The full weekday name.
   "M"        The one- or two-digit month number.
   "MM"       The two-digit month number. Single-digit values are preceded by a zero.
   "MMM"      The three-character month abbreviation.
   "MMMM"     The full month name.
   "yy"       The last two digits of the year (that is, 1996 would be displayed as "96").
   "yyyy"     The full year (that is, 1996 would be displayed as "1996").
   Example:
      "d.MM.yyyy"   will display date as 9.02.2012
      "dd.MM.yyyy"  will display date as 09.02.2012
      "dd/MM/yyyy"  will display date as 16/02/2012
      "dd.MMM.yyyy" will display date as 16. FEB. 2012
   To make the information more readable, you can add body text to the format string by enclosing it in single quotes.
   Spaces and punctuation marks do not need to be quoted. Nonformat characters that are not delimited by single
   quotes will result in unpredictable display by the DATEPICKER control.
   For example, to display the current date with the format "'Today is: 04:22:31 Tuesday Mar 23, 1996",
   the format string is "'Today is: 'hh':'m':'s dddd MMM dd', 'yyyy".
   To include a single quote in your body text, use two consecutive single quotes.
   For example, "'Don''t forget' MMM dd',' yyyy" produces output that looks like:
   Do not forget Mar 23, 1996. It is not necessary to use quotes with the comma,
   so "'Don''t forget' MMM dd, yyyy" is also valid, and produces the same output.
HMG.3.3.0_patch3_(32 and 64-bits).rar
(864.7 KiB) Downloaded 1141 times
klauskugel
Re: HMG.3.3.0 Patch 3 (32 and 64-bits)
Post by klauskugel »
M U C H A S G R A C I A S , DOC !
That was it. A Devil's work.
Grid/Browse are working under 64-bit and the compiling in
the IDE is definitely seamless.
Wonderful JOB.
:roll: This is Clipper 3000.
Greetings from Germany
klauskugel
klauskugel
My Platform is AMD64 / Win 8.0 Prof. and All is working so far.
Many Thanks again.
klauskugel
klauskugel wrote:Grid/Browse are working under 64-bit and the compiling in
klauskugel wrote:My Platform is AMD64 / Win 8.0 Prof. and All is working so far.
These are very good news, thanks!
klauskugel wrote: This is Clipper 3000.
Is Clipper 3000 Turbo :lol:
Gracias Claudio..
Gracias Dr. Claudio ! :D :D :D
Many Thanks again.
klauskugel
Really nice to know this !! :D
Thank you CLaudio, again ! :)
jayadevu
Post by jayadevu »
I am yet to see a MORE RESPONSIVE TEAM. Congratulations on your excellent work.
Friends, Is there any significant improvement in speed/other areas because of change from 32 to 64 bit.
Warm regards,
Jayadev
jayadevu wrote:Hi,
Warm regards,
Jayadev
See: http://hmgforum.com/viewtopic.php?p=34869#p34869
Post by EduardoLuis »
Hola Claudio:
Maravilloso trabajo, como siempre, y desde ya gracias por compartirlo con nosotros.-
Un abrazo.-
Eduardo
Thanks Claudio:
Wonderfull job, as allways, and thanks for share with us.-
With Regards.
Eduardo
