Pablo César wrote:
Please Claudio, can you include this fix on your next PATCH ?
If possible, arrange the fix for this conflict please ? I already gave a review and a possible solution, but still not received adequately answered from Rathi this issue and already took 2 PATCHs... and still nothing...
This bug will be fixed by Rathi.
When Rathi finds the best solution for this bug I include it in the source code.
Why Claudio ? The solution that I have submitted is not good enough ?? Or are you referring to just this ?
HMGing a better world "Matter tells space how to curve, space tells matter how to move." Albert Einstein
Ok, I understood. Let's wait Rathi returns...
Sometimes I think: What advances strive to improve something when we do not receive some encouragement ... instead.
In my opinion, we should encourage that we can all contribute and help each other. The source code of HMG is open source and that means we can all study it, comprehend it and even improve it.
I hope there is always good spirit to receive changes and either accept the information when they are approved and also reciprocate with any help thanks. I hope this from everyone.
Translated to Spanish
A veces pienso: ¿ Qué adelanta esforzarse por mejorar algo cuando no recibimos algo de aliento ... por lo contrário.
En mi opinión, debemos fomentar que todos podemos contribuir y ayudar a los demás. El código fuente de HMG es de código abierto y eso significa que todos podemos estudiarlo, comprenderlo e incluso mejorarlo.
Espero que siempre tengamos buen espíritu para recibir los cambios y aceptar la indicaciones cuando estes son aprobados y también retribuir con agradecimiento cualquier ayuda. Asi espero esto, de todos.
Translated to Portuguese
As vezes penso: O quê adianta se esforçar para melhorar algo quando nós não recebemos incentivo algum... pelo contrário.
Na minha opinião, devemos incentivar que todos possamos contribuir e ajudar-nos uns aos outros. O código fonte da HMG é source open e isso significa que todos podemos estudá-lo, comprender-lo e até mesmo melhorá-lo.
Espero que haja sempre bom espirito para receber mudanças e tanto aceitar as indicações quando forem aprovadas e também retribuir com agradecimento qualquer ajuda. Assim espero isso de todos.
En cuanto a mi reporte del bug, creo que es mi obligación al ser parte del forum.-
Se que no tengo todos los conocimientos que Uds., y por ello mis aportes son más de "tester" que de "developer", pero es una forma de colaborar.-
Desde ya que te quedo y creo que todo el foro tambien, muy agradecidos por tu empeño en resolver los distintos bugs que vamos denunciando.-
Todavía no pude implementar su sugerencia, porque preferí primero responderte ni bien leí tu aporte, pero ya veo que funciona correctamente.-
Sin perjuicio de que Claudio ha implementado la mayor parte de los patch, Rathi creo que es quien más ha trabajado con HMG_PDF, y seguramente lo implementarán en algun nuevo patch.-
Mientras tanto seguimos trabajando todos juntos por HMG.-
Nuevamente Gracias por toda tu invalorable colaboración.-
Eduardo
Hi Pablo Cesar:
About my bug report, y think that i'm obly to do it as a permanent member of this forum.-
I also know that because of my less knowledge about C++, all my contributions becomes more from a "tester" than from a "developer", although i think it's a way to colaborate.-
Initially, speaking about myself, and also about the forum, everyone must thank your efforts to solve any bug is discovered.-
I could not implement yyour upgrade your suggestion, because i want first to answer your post, but i'm sure it works.-
Although Claudio has made all new patches, as Rathi is HMG_PDF father, i'm sure both will implement your fantastic idea and soon they will make a new patch containing your solution.-
Meanwhile everyone must continue working for a powerfull HMG.-
Again, thanks for your unvaluable colaboration.-
With regards. Eduardo
Eduardo
Ahhh que bueno, Eduardo.
Esta correcion no es definitiva como Claudio dijo. Esperemos a Rathi, talvez lo haga de forma diferente, aunque si funciona es lo que importa y dar continuidad nuestros trabajos.
Abrazos
Pablo César wrote:Why Claudio ? The solution that I have submitted is not good enough ?? Or are you referring to just this ?
I do not know, I never have analyzed this change.
As I said, I think Rathi is the person most suited to modify HMG_HARUPDF because it is whoever implemented the code.
Pablo César wrote:Sometimes I think: What advances strive to improve something when we do not receive some encouragement ... instead.
Not as simple as it seems, me and Rathi, always we have to harmonize the changes to not interfere with the current code and the development of the future code. Someone always has to judge the changes, in this moment we are me and Rathi as the judges, we could be wrong in the our decisions, but for now it is what it is ...
