Here is a new test.
I've fixed double execution and problems with value property.
To install, merge the attached file with your current HMG installation (please backup first).
Please, test and report any problem.
Thanks in advance.
HMG 2.8.5 (Forum Test)
- HMG Founder
- hmg285.rar
- (370.48 KiB) Downloaded 369 times
Re: HMG 2.8.5 (Forum Test)
Yes. It's great.
Thanks Roberto. It is working now as expected. So nice of you.
Perfect i'm testing now
Tested.Roberto Lopez wrote: ... test and report any problem.
Now everything is okay and more clear ( it's seeming to ...
Best Regards
- HMG Founder
Thanks to all for testing.Roberto Lopez wrote:Hi All,
I'm testing too and I've found a little new problem.
If you omit value at control definition a runtime error is generated.
I've just fixed.
Anyway appears to be that there will be a 2.8.6 test
Thanks again.
Roberto, primero que nada muchas gracias.Roberto Lopez wrote:Hi All,
Here is a new test.
He probado el test 2.8.5 y hasta ahora va todo bien. Solo tengo una duda:
En el sample\grid_23 dice:
DEFINE GRID Grid_1
ROW 10
COL 10
WIDTH 500
HEIGHT 322
HEADERS {'Column 1','Column 2','Column 3'}
WIDTHS {100,100,100}
ITEMS aRows
VALUE 1
ALLOWEDIT .T.
CELLNAVIGATION .T.
ONCHANGE GridChange()
VALUE { 3 , 2 }
END GRID
veo que hay dos propiedades VALUE, entonces pregunto si CELLNAVIGATION es .F. la propiedad VALUE que vale es la que no se indica por ARRAY?
Si deseo trabajar sin CELLNAVIGATION .T. la propiedad VALUE debe especificarse sin ARRAY no?
muchas gracias y seguiré probando.
Saludos, Fernando Chirico.
- HMG Founder
English:fchirico wrote:Roberto, primero que nada muchas gracias.Roberto Lopez wrote:Hi All,
Here is a new test.
DEFINE GRID Grid_1
ROW 10
COL 10
WIDTH 500
HEIGHT 322
ITEMS aRows
VALUE 1
ALLOWEDIT .T.
CELLNAVIGATION .T.
VALUE { 3 , 2 }
END GRID
It's my mistake. You must eliminate 'value 1' line.
Español:
Es mi error. Hay que eliminar la línea 'value 1'.
Gracias por reportarlo.
Saludos,
