- during compilation, the Build64.bat or the IDE returns: windres preprocessing failed
- this means that the windres not found hmg64.rc
- even duplicating the hmg.rc to hmg64.rc, HMG build it, but in 32 bit according Windows Task Manager
HMG 3.3.0 trouble with 64 bit compilation
I'm having the following troubles with HMG 3.3.0 compilation in 64 bit
AMD Phenom II X6 1090T 3.2GHz (OverClock 3.9GHz) | Windows 8.1 Pro 64-bit
4GB DDR3 | GTX 550 Ti 1GB | MSI 880GMA-E35
- srvet_claudio
Re: HMG 3.3.0 trouble with 64 bit compilation
The HMG.3.3.0 version is not complete (missing 64-bits libraries).
Missing a patch that Rathi will prepare with the following folders needed to build 64-bit app:
- Harbour-64
- MinGW-64
- Lib-64
- Harbour-64
- MinGW-64
- Lib-64
- srvet_claudio
I forgot, to create 64-bit applications should be compiled with build64.bat or with the IDE you select option "build" in main menu.srvet_claudio wrote:The HMG.3.3.0 version is not complete (missing 64-bits libraries).
- Harbour-64
- MinGW-64
- Lib-64
Thank for the info
I compiled with build64.bat, or in IDE chosing Build->64-bits. Also compiled Libs with _BuildAllLib64.bat
