Ftp @ in username problem
hynan
Post by hynan »
Hi all,
My webhost only allow @ in username when making extra ftp accounts
I found already this:
/* Comprobamos si el usuario contiene una @ para forzar el userid */
IF At( "@", cUser ) > 0
oFTP:oUrl:cServer := cServer
oFTP:oUrl:cUserID := cUser
oFTP:oUrl:cPassword := cPassword
Try to implement it, but cannot get it to work,
i think ( as dummy ) oFTP:Open ( cURL ) has still the @ in username ?
Or ?
My code, ftp is working, i will delete account after i get it to work:
FUNCTION FTPUPLOAD ( cFILE )
LOCAL lOK := .F.
LOCAL cUSER := "Eldemo@johnsjn22.twentytwo.axc.nl"
LOCAL cSERVER := "johnsjn22.twentytwo.axc.nl"
LOCAL cPASSWORD := "12345"
LOCAL cUrl := "ftp://" + cUSER + ":" + cPASSWORD + "@" + cSERVER
LOCAL oURL := tUrl():NEW ( cURL )
LOCAL oFTP := tIPClientFtp():NEW ( oURL, .F. )
oFTP:nConnTimeout := 20000
oFTP:bUsePasv := .F.
oFTP:oUrl:cServer := cSERVER
oFTP:oUrl:cUserID := cUSER
oFTP:oUrl:cPassword := cPASSWORD
IF oFTP:Open ( cURL )
? "OK"
oFTP:CLOSE ()
? "Error"
RETURN ( lOK )
Thanks and greetings...
Re: Ftp @ in username problem
Hynan,
Try this with correct login/pw:
FUNCTION FTPUPLOAD()
LOCAL lOK         := .F.
LOCAL cUSER       := "Eldemo"
LOCAL oFTP        := tIPClientFtp():NEW ( cUrl )
IF oFtp:open()
   msginfo( StrValue(oFtp:cReply) + ' ' + StrValue(oFtp:lastErrorMessage()) , 'ok')
   lOK         := .t.
   //oFTP:CLOSE ()
   msginfo( StrValue(oFtp:cReply) + ' ' + StrValue(oFtp:lastErrorMessage()) , 'nok')
RETURN ( lOK )
FUNCTION StrValue( string, onoff )
LOCAL retval := pNULL
onoff := Valid_parm( onoff, pLOGICAL, FALSE )
DO CASE
CASE VALTYPE( string ) = pCHARACTER
	retval := string
CASE VALTYPE( string ) = pNUMERIC
	retval := LTRIM( STR( string ) )
CASE VALTYPE( string ) = pMEMO
	retval := IF( (LEN(string) > (MEMORY(0) * 1024) * .80), ;
						SUBSTR(string,1, INT((MEMORY(0) * 1024) * .80)), ;
						string )
CASE VALTYPE( string ) = pDATE
	retval := DTOC( string )
CASE VALTYPE( string ) = pLOGICAL
	retval := IF( ( onoff ), IF(string, "On", "Off"), ;
				 IF(string, "True", "False") )
OTHERWISE
	retval := ''
ENDCASE
RETURN( ALLTRIM(retval) )
Greetings, Serge
Hynan,
Error is now: 530 Login incorrect.
hynan
Post by hynan »
And thanks for thinking with me
must be that way
i did try with ftp program with this and its working
Greetings...
I can use that username and password to authenticate to the FTP server?
User OK
Login :cry:
20140521-11:18:45 :INETCONNECT( johnsjn22.twentytwo.axc.nl, 21 )
>> <pointer> <<
20140521-11:18:45 :INETERRORCODE( <pointer> )
>> 0 <<
20140521-11:18:45 :INETRECVLINE( <pointer>, , 128 )
>> 220 ProFTPD 1.3.4d Server ready. <<
>> 0 <<
20140521-11:18:45 :INETSENDALL( <pointer>, 13, USER Eldemo<cr><lf> )
>> 13 <<
20140521-11:18:46 :INETRECVLINE( <pointer>, , 128 )
>> 331 Password required for Eldemo <<
20140521-11:18:46 :INETERRORCODE( <pointer> )
>> 0 <<
20140521-11:18:46 :INETSENDALL( <pointer>, 12, PASS 12345<cr><lf> )
>> 12 <<
>> 530 Login incorrect. <<
>> 0 <<
hynan
Post by hynan »
Hi danielmaximiliano,
I only know,
i tested ftp login
( i copy/paste from source in this post to make sure )
and it works
i did use totalcommander ftp function
maby any login name ftp server ask for password
Greetings and thanks...
hynan wrote:Hi danielmaximiliano,
I only know,
i tested ftp login
and it works
the FTP server might work in safe mode and need secure authentication
hynan
Post by hynan »
I think not
with main ftp account ( no @ in username )
same settings in ftp program as Eldemo account
both works ok
In Harbour with main ftp account ( no @ in username )
works ok.
Only account with @ in username gives problem
hynan
Post by hynan »
Hi all,
Did some testing with main ftp account,
what is working OK in Harbour
LOCAL cUSER := "GOODACCOUNTNAME"
LOCAL cUrl := "ftp://" + "NOTGOODACCOUNTNAME" + ":" + cPASSWORD + "@" + cSERVER
Works not, because
does not doing what it should do ?
hynan wrote:Hi all,
Works not, because
can you tell me how to create a new user and the requirements demanded by the web server?
