Page 1 of 2
Too many connections / 4 - HMG Reference
Posted: Wed Apr 16, 2014 5:37 pm
by Italia1
Hello to everyone
On 07 Apr 11:20, with Firefox 28.0 in Windows XP Home OEM, when I go on forum -
viewforum.php?uid=56&f=44&start=0 - i found this error:
General Error
SQL ERROR [ mysql4 ]
Too many connections [1040]
An sql error occurred while fetching this page. Please contact an administrator if this problem persists.
I think there's not an browser error but a Server SQL error (more forums have this problem).
This pages have only a number 404 (it's link HFCL of
HMG Reference):
HFCL/DOC/Intro.htm
HFCL/DOC/AutoFill.htm
HFCL/DOC/COMBOSEARCHBOX.htm
HFCL/DOC/gridprint.htm
HFCL/DOC/HMG_HPDF_Doc.pdf
HFCL/DOC/BosTaurus-FunctionsReferenceGuide.pdf
Peraphs directory HFCL/DOC/ it's renamed.
I hope this segnalations is useful for you.
Bye bye.
Edit: when i send URL the forum system add
onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Too many connections / 404
Posted: Wed Apr 16, 2014 6:02 pm
Thank you for reporting us these errors Italia1. Let´s wait Mr. Rathinagiri what probably happen with this folder in the forum.
Italia1 wrote:Edit: when i send URL the forum system add
Regarding this... it is a quite recently error which is hapining when user not uses a URL tags. This also Rathinagiri could say about. Because this started to happen after some
EXTURL tag added.
Re: Too many connections / 404
Posted: Wed Apr 16, 2014 7:01 pm
by Italia1
You're welcome.
For URL I will use ever tag URL.
Missing image file in DOC
Posted: Thu Apr 17, 2014 4:02 am
Hi Rathinagiri,
Just to inform you is missing the image called HMG-Unicode.bmp at
http://hmgforum.com/hmgdoc/data/HMG_UNICODE_DOC" onclick="window.open(this.href);return false;
Rgds
Posted: Thu Apr 17, 2014 4:33 am
I will look into the matter and will revert back.
Pablo, the image url is working for me.
Posted: Thu Apr 17, 2014 9:35 am
by Italia1
Rathinagiri wrote:Pablo, the image url is working for me.
Is ok for me too in link
http://hmgforum.com/hmgdoc/data/HMG_UNI ... NICODE.bmp
Thanks Rathinagiri for looking it.
Edit. I found what Pablo say. The error is
http://hmgforum.com/hmgdoc/data/HMG_UNI ... nicode.bmp because is in lower case (linux is case sensitive) in this .htm
http://hmgforum.com/hmgdoc/data/HMG_UNI ... nicode.htm.
Posted: Thu Apr 17, 2014 1:37 pm
Oh! Now I understand.
Posted: Thu Apr 17, 2014 1:38 pm
Yes for me this just image, is ok too.
Sorry I should put complete URL, which is still not working as Italia1 said.
See in Chrome:
- Screen.PNG (27.62 KiB) Viewed 6709 times
and Mozilla:
- Tela1.PNG (23.66 KiB) Viewed 6709 times
This is the complete URL (not display image):
Posted: Thu Apr 17, 2014 2:04 pm
by Italia1
Two solutions possible:
1) rename HMG-UNICODE.bmp in HMG-Unicode.bmp in hmgdoc/data/HMG_UNICODE_DOC/
The first solution is valid if do you have not another image refer in other htm. I reccomend the second if the name of image is correct.
Bye bye
Posted: Fri May 09, 2014 4:24 pm
by Italia1
Hello. For correct problem with 1) solution must modifiy file Update_HMG_Unicode.htm
<img width=200 height=100 id="_x0000_i1025" src=HMG-Unicode.bmp alt=1>
with
<img width=200 height=100 id="_x0000_i1025" src=HMG-UNICODE.bmp alt=1>
Bye bye
