Informe de la aplicacion
Posted: Wed Apr 09, 2014 6:15 pm
by Agustin
Hay alguna forma de que desde cualquier parte del programa se pueda llamar a una función que nos de informe de tablas abiertas, indices etc..
Poniendo ON KEY en cada Form funciona, pero me gustaría tener una única llamada.
Saludos cordiales
Re: Informe de la aplicacion
Posted: Thu Apr 10, 2014 1:20 am
by srvet_claudio
See this demo:
WIDTH 500 HEIGHT 300 ;
TITLE "Press ALT+F9";
@ 30,10 EDITBOX Edit_1 ;
WIDTH 400 ;
HEIGHT 100 ;
VALUE 'Hello'
@ 200, 100 BUTTON Button_1 CAPTION "Modal" ACTION ModalWin()
DEFINE WINDOW Form_Info;
AT 0,0;
WIDTH 700;
HEIGHT 600;
FONTNAME "Courier New" FONTSIZE 10;
NOAUTORELEASE
@ 10 , 10 LABEL Label_1 VALUE "Display your Info" AUTOSIZE
@ 30 , 10 LABEL Label_2 VALUE "" AUTOSIZE
CREATE EVENT PROCNAME FormInfoKeyProc()
CENTER WINDOW Form_1
Function FormInfoKeyProc()
IF HMG_VirtualKeyIsPressed (VK_F9) .AND. HMG_VirtualKeyIsPressed (VK_ALT)
Form_Info.SHOW
IF ISWINDOWENABLED (Form_Info.HANDLE) == .F.
ENABLEWINDOW (Form_Info.HANDLE) // avoid disable Form_Info for Modal Windows
Form_Info.Label_2.VALUE := "Modal Window : " + IF (_IsWindowDefined ( "Form_2" ) == .F., "OFF","ON")
Return NIL
Procedure ModalWin
IF _IsWindowDefined ( "Form_2" ) == .F.
DEFINE WINDOW Form_2;
AT 0,0;
WIDTH 200;
HEIGHT 200;
MODAL
@ 10 , 10 LABEL Label_1 VALUE "Modal Window" AUTOSIZE
CENTER WINDOW Form_2
ACTIVATE WINDOW Form_2
Posted: Thu Apr 10, 2014 1:46 am
by Javier Tovar
Gracias Dr. Claudio Soto por compartir, y un excelente demo!
Posted: Thu Apr 10, 2014 8:20 am
by Agustin
Muchisimas gracias por su ayuda.
Posted: Thu Apr 10, 2014 10:45 am
by mol
I want to modify FormInfoKeyProc() for replacing pressed comma to dot "on the fly".
I don't know, why comma does not appear in the editbox:
IF xtemp := HMG_VirtualKeyIsPressed (VK_DECIMAL) // kropka
msgdebug("Decimal on the numeric keyboard was pressed!")
HMG_SendCharacter (Form_1.Handle , "," )
return 1
Form_Info.SHOW
Return NIL
Posted: Thu Apr 10, 2014 2:40 pm
by srvet_claudio
mol wrote:I want to modify FormInfoKeyProc() for replacing pressed comma to dot "on the fly".
return 1
Form_Info.SHOW
Return NIL
Hi Marek,
see this code:
IF HMG_GetLastVirtualKeyDown() == VK_DECIMAL
HMG_CleanLastVirtualKeyDown() // avoid re-entry
// msgdebug("Decimal on the numeric keyboard was pressed!")
HMG_SendCharacter (Form_1.Edit_1.Handle , "," )
return 1
Form_Info.SHOW
Return NIL
