print preview - PDFCreator
Carlos Reis
Post by Carlos Reis »
Hello all
How can I print a PDF file ?
I'm using the HMG 3.0.35 and I want to print a PDF file
for example:
xfile :=" Teste.pdf"
START PRINTDOC
START PRINTPAGE
// commands for Print the "teste.pdf " file
END PRINTPAGE
END PRINTDOC
[u]Moderator Notes[/u] (Pablo César) wrote:This topic was splitted and moved from HMG Wishlist.
Best Regards
Carlos Reis, Portugal
39º 46' 47" N
08º 55' 45 W
Re: print preview
i think the best way in this time is to install PDFCreator and select it as printer...
I've tested some time ago a sample with pdf creating, but there were some problems (I don't remember what kind - something about positions... I think)
Re: print preview
mol wrote:i think the best way in this time is to install PDFCreator and select it as printer...
Hello,
I'm agree with your opinion.
Please take a look for the following simple sample of using PDFCreator for the printing:
#include "minigui.ch"
Function Main()
//	AVAILABLE LIBRARY INTERFACE LANGUAGES
//	SET LANGUAGE TO ENGLISH (DEFAULT)
//	SET LANGUAGE TO SPANISH
//	SET LANGUAGE TO PORTUGUESE
//	SET LANGUAGE TO ITALIAN
//	SET LANGUAGE TO GERMAN
//	SET LANGUAGE TO FRENCH
	Private aColor [10]
	aColor [1] := YELLOW
	aColor [2] := PINK
	aColor [3] := RED
	aColor [4] := FUCHSIA
	aColor [5] := BROWN
	aColor [6] := ORANGE
	aColor [7] := GREEN
	aColor [8] := PURPLE
	aColor [9] := BLACK
	aColor [10] := BLUE
	DEFINE WINDOW Win_1 ;
		WIDTH 400 ;
		HEIGHT 400 ;
		TITLE 'MiniPrint Library Test' ;
		MAIN
		DEFINE MAIN MENU
			DEFINE POPUP 'File'
				MENUITEM 'Default Printer' ACTION PrintTest1()
				MENUITEM 'User Selected Printer' ACTION PrintTest2()
				MENUITEM 'User Selected Printer And Settings' ACTION PrintTest3()
				MENUITEM 'User Selected Printer And Settings (Preview)' ACTION PrintTest4()
			END POPUP
		END MENU
	MAXIMIZE WINDOW Win_1
	ACTIVATE WINDOW Win_1
Procedure PrintTest1()
Local DefaultPrinterBak
	oPDFC := CreateObject( "PDFCreator.clsPDFCreator" )
	oPDFC:cVisible := .F.
	If oPDFC:cStart("/NoProcessingAtStartup") = .f.
		If oPDFC:cStart("/NoProcessingAtStartup", .t.) = .f.
			msginfo("Init printer error!")
			return nil
	 	EndIf
	EndIf
	oPDFC:cOption('UseAutosave',1)
	oPDFC:cOption('UseAutosaveDirectory',1)
	oPDFC:cOption("AutosaveFormat",0) && PDF format
	DefaultPrinterBak := oPDFC:cDefaultprinter
	oPDFC:cDefaultprinter := "PDFCreator"
	oPDFC:cClearCache()
	oPDFC:cOption('AutosaveFilename',"test")
	oPDFC:cOption('AutosaveDirectory',GetTempFolder())
	SELECT PRINTER DEFAULT ;
		ORIENTATION	PRINTER_ORIENT_PORTRAIT ;
		PAPERSIZE	PRINTER_PAPER_LETTER ;
		QUALITY		PRINTER_RES_MEDIUM
	PrintDoc()
	oPDFC:cPrinterStop := .f.
	oPDFC:cClearcache()
	oPDFC:cDefaultprinter := DefaultPrinterBak
	oPDFC:cClose()
MsgInfo('Print Finished')
Procedure PrintTest2()
Local i
Local cPrinter
	cPrinter := GetPrinter()
	If Empty (cPrinter)
	EndIf
	SELECT PRINTER cPrinter ;
	PrintDoc()
Procedure PrintTest3()
Local i
Local lSuccess
	// Measure Units Are Millimeters
	SELECT PRINTER DIALOG TO lSuccess
	If lSuccess == .T.
		PrintDoc()
	EndIf
Procedure PrintTest4()
Local i
Local lSuccess
	SELECT PRINTER DIALOG TO lSuccess PREVIEW
	If lSuccess == .T.
		PrintDoc()
	EndIf
Procedure PrintDoc
Local i
	START PRINTDOC
		FOR I := 1 TO 10
			START PRINTPAGE
				@ 20,20 PRINT RECTANGLE ;
					TO 50,190 ;
					PENWIDTH 0.1
				@ 25,25 PRINT IMAGE "hmg.jpg" ;
					WIDTH 20 ;
					HEIGHT 20
				@ 30,85 PRINT "PRINT DEMO" ;
					FONT "Courier New" ;
					SIZE 24 ;
					BOLD ;
					COLOR aColor [i]
				@ 140,60 PRINT "Page Number :" + Str(i,2) ;
					FONT "Arial" ;
					SIZE 20 ;
					COLOR aColor [i]
				@ 260,20 PRINT LINE ;
					TO 260,190 ;
					PENWIDTH 0.1
			END PRINTPAGE
		NEXT I
	END PRINTDOC
Hope that helps :idea:
Carlos Reis
Re: print preview
Hi
Thanks for your reply.
The problem is that I need to print a document with a part of data from a table and another part from a pre-defenided document in PDF.
Best Regards
39º 46' 47" N
08º 55' 45 W
Carlos Reis
Re: print preview
Thanks gfilatov for the sample.
I will test it to see if it serves my needs.
Thanks a lot.
Best Regards
39º 46' 47" N
08º 55' 45 W
