HI all:
any way that the height of grid cells in windows 7 are the same as in windows xp?
best regards
Ciro
Grid cells in windows 7
- sistemascvc
Hola Ciro,
IMO, this should be the same, but seems apparently not the same (minimal difference), but this is given by API of Window, not from Grid library. Why are you asking this ??
Re: Grid cells in windows 7
Ciro sent this post to another placesistemascvc wrote:HI all:
best regards
Ciro
Thanks Ciro to remind
Viva HMG
Hi Ciro,
Examples I have run win 7 and win XP and can not tell the difference is minimal and will not take importance, it does not affect the program itself.
There are higher grid cells in windows 7 than windows XP.
I had to rebuild my application after changing windows to have all rows visible in small table.
Hola Ciro :
si tiene problemas de tamaño en su aplicacion necesita averiguar que version de Windows tiene. utilizé la funcion
y modifique en tiempo real el tamaño de sus ventanas y sus respectivos controles para que se ajuste a sus requerimientos.
Hi Cyrus
if you have problems in your application size needs to find out which version of Windows you have. I Use the function
and modify in real time the size of your windows and their controls to suit their requirements.
WindowsVersion()Hi Cyrus
WindowsVersion () *´¨)
Creo que es lo mismo que con el Calendario...
viewtopic.php?f=5&t=3386&start=10
