Page 4 of 7
Re: Underline and italic in PDF seems not work
Posted: Wed Apr 09, 2014 6:07 pm
by EduardoLuis
Excelente Dany !!!!!!!!!
Queda confirmado que el problema es la fuente.-
Abrazo y siempre gracias por compartir.-
Eduardo
Posted: Thu Apr 10, 2014 8:30 am
by mustafa
Hola EduardoLuis y y danielmaximiliano
muy agardecido por buestros samples
Daniel: Ok , era la fuente, la que me has mandado
funciona correcto.
Mustafa :idea:
Posted: Thu Apr 10, 2014 8:51 am
Instead of using ttf fonts for creating barcodes, we can use zebra library to create any type of barcode. Isn't it?
Posted: Fri Apr 11, 2014 7:50 pm
Hi all !
I also have found dificulties to generate pdf thru HARUPDF and I have exaustly study it source fonts for HMG_HARUPDF and I saw the main problem is to VALIDATE the names of fonts regarding:
- Correct name, this must be according Haru array and when is put the pathfile name
- It's properties, when is ITALIC and BOLD
- Localization when is passed path, name and extension.
And all of these points it all works together. So I decided to review the function _HMG_HPDF_SetFont which now is making the right validation and more options was added like as:
_HMG_HPDF_SeekHaruFonts(cFntName,lBold,lItalic)
_HMG_HPDF_SeekEquivalences(cFntName,lBold,lItalic)
_HMG_HPDF_ExistInLocal(cFntName)
_HMG_HPDF_SeekInLocalOptions(cFntName,lBold,lItalic)
FWriteLine( nHandle, cString )
And LOG option to create a text file with all fonts involved in the pdf creation and its reassigned fonts names. This gives to the programmer, the chance to see what font is not passed correctly as parameter in _HMG_HPDF_PRINT.
Some times we pass wrongly name of font. With NO path when we want to load from TTF file unless than this file is in current folder.
Some times we pass wrongly with wrong name. So, there is a _HMG_HPDF_SeekInLocalOptions function which takes the 4 first characters and seek in current folder and in Windows folder, then is reassigned name.
I have added cFilePath to work with cFileNoExt in _HMG_HPDF_SeekInLocalOptions function in order to take the correct pathfile name.
But HARUPDF which is the library, it has a limitation regarding: STRIKEOUT and UNDERLINE properties. In our code, we have both itens, but is not working because HARUPDF works with TTF (True Type Fonts) and this with its limitations.
HARU PDF
Drawing a line for UNDERLINE and STRIKEOUT (suggestion in SourceForge forum)
Posted: Fri Apr 11, 2014 8:09 pm
by Javier Tovar
Gracias Pablo César por tu información muy detallada!
Posted: Fri Apr 11, 2014 10:41 pm
Que bien que te gustó Javier, vos siempre tan atento. :)
Anexé los dos ejemplos que hicieron y adapté poca cosa, solo para poder hacer las lineas simulando STRIKEOUT e UNDERLINE.
HMGHPDFDoc.rar
Two examples (with exexcutables files)
(2.44 MiB) Downloaded 407 times
Los archivos fuentes, serán liberados en la próxima version de HMG 3.2.1, porque no hay como testear con lo que ya está en andamiento. :(
Hechale una miradita al archivo UsedFonts.txt ;)
Para que el LOG funcione, debes agregarle (futuramente) la palabra "log" al final de:
SELECT HPDFDOC "sample.pdf" PAPERLENGTH 300 PAPERWIDTH 300 LOG
Espero que es gusten. :D
I am happy you liked, Javier. You are always so attentive. :)
I am attaching two examples (little adaptetion), just to make the lines simulating STRIKEOUT and UNDERLINE.
The source files will be released in the next version of HMG 3.2.1, because there is no way to test it with actual version, because new version is already in progress.
Please look up at UsedFonts.txt file after PDFs creation ;)
For creation of LOG, you must add (in next release) the word "log" at the end of:
I Hope you enjoy it !! :D
Posted: Fri Apr 11, 2014 11:44 pm
by Javier Tovar
Muy bien Pablo césar, Excelente! :D :D :D
Pablo César wrote: y adapté poca cosa
siempre tan humilde! :D
Posted: Fri Apr 11, 2014 11:49 pm
by Javier Tovar
Hola Pablo César,
Ya vi el archivo UsedFonts.txt, y lo que observo que cada vez que compilamos se genera ese archivo con los tipos de fuentes y características que se ocupan, pero en qué momento se genera? No lo veo en el *.prg
Posted: Sat Apr 12, 2014 12:17 am
Javier Tovar wrote:Muy bien Pablo césar, Excelente! :D :D :D
Gracias Javier. Pero la verdad que los ejemplos fueron pocos los cambios, no se compara con el trabajo que me dió con HMG_HPDF.Prg.
Javier Tovar wrote:Ya vi el archivo UsedFonts.txt, y lo que observo que cada vez que compilamos se genera ese archivo con los tipos de fuentes y características que se ocupan, pero en qué momento se genera? No lo veo en el *.prg
En este momento, no estoy disponibilizando el source porque iria precisar hacer muchos cambios e iria causar mucha confusion si la actualizacion. Pero ahora si compilas, no irás a generar tal archivo, visto que falta la biblioteca y algunos fuentes.
Pero cuando salga la version HMG.3.2.1 solo precisarias adicionar la palabra "LOG" al final de la linha donde empiezas el relatório. Exactamente aqui:
Fijate, en color rojo. Como ya habia mencinado en mi mensaje anterior.
Posted: Sat Apr 12, 2014 12:34 am
by Javier Tovar
OK Pablo César Visto y anotado!
