Hello HMGFORUM,
Is There any way to build HMG projects in 64 bit for fast processing?
Thanks
Build to 64-bit
Build to 64-bit
AMD Phenom II X6 1090T 3.2GHz (OverClock 3.9GHz) | Windows 8.1 Pro 64-bit
4GB DDR3 | GTX 550 Ti 1GB | MSI 880GMA-E35
Re: Build to 64-bit
HMG is based on win32api. If it is compatible or identical API functions are there in 64Bit processing, then it can be done easily I think.
- srvet_claudio
Re: Build to 64-bit
The theory is as follows:
1) Build the Harbour libraries with MinGW64 (Harbour 64 bits)
2) Build the HMG libraries with Harbour 64 bits and MinGW64 (HMG 64 bits)
3) Compile the applications with HMG 64 bits and MinGW64
But there are some practical problems when porting HMG to 64 bits in the C code:
1) Change Get/SetClassLong and Set/GetWindowLong for Get/SetClassLongPtr and Get/SetWindowLongPtr
2) Check all assignments of types and pointers, see http://www.viva64.com/en/a/0004/
Re: Build to 64-bit
Now, can we use pre-compiler directives to use 32 bits or 64 bits in the same code?
- srvet_claudio
Re: Build to 64-bit
Yes, and Get/SetClassLongPtr and Get/SetWindowLongPtr are compatible with 32 and 64 bits.Rathinagiri wrote:Now, can we use pre-compiler directives to use 32 bits or 64 bits in the same code?
Build to 64-bit
For that reason, should it have two HMG versions for that.
Because Windows version early 64 bits (Windows early Win7 and Win7 in 32bits) will not recognize apps in 64bits, then will be necessary to choose when is needed to build apps in 32 when in 64bits... I guess...
