how to catch mouse event in a grid ?
jpp
How to catch mouse event in a grid ?
Post by jpp »
hi to all
i'm trying to catch some mouse event in a a grid but i can not !
event WM_KEYPRESS is catched, but none of the mouse.
Where is my mistake please ?
* HMG Virtual Grid Demo
* (c) 2003 Roberto Lopez
	DEFINE WINDOW Form_1 ;
		WIDTH 450 ;
		HEIGHT 400 ;
		TITLE 'Hello World!' ;
		MAIN
		@ 10,10 GRID Grid_1 ;
		WIDTH 400 ;
		HEIGHT 330 ;
		HEADERS {'Column 1'} ;
		WIDTHS {140};
		VIRTUAL ;
		ITEMCOUNT 1000 ;
		ON QUERYDATA QueryTest()
	create event procname test HWND form_1.grid_1.handle
	CENTER WINDOW Form_1
	ACTIVATE WINDOW Form_1
proc test
local msg:= eventmsg()
do case
case msg== WM_KEYDOWN
	msgbox("key_down")
case msg== WM_MOUSEWHELL
	msgbox("Mouse wheel")
case msg== WM_LBUTTONDOWN
	msgbox("Mouse lbtn Down")
case msg== WM_RBUTTONDOWN
	msgbox("Mouse Rbtn Down")
endcase
return nil
Procedure QueryTest()
    This.QueryData := Str ( This.QueryRowIndex ) + ',' + Str ( This.QueryColIndex )
Italia1
Re: how to catch mouse event in a grid ?
Post by Italia1 »
Hi jpp,
I don't know if I can help you, but I see WM_NCMOUSEMOVE, WM_NCLBUTTONDOWN, WM_NCLBUTTONUP, WM_NCLBUTTONDBLCLK, WM_NCRBUTTONDOWN, WM_NCRBUTTONUP, WM_NCRBUTTONDBLCLK, WM_NCMBUTTONDOWN, WM_NCMBUTTONUP, WM_NCMBUTTONDBLCL.
I hope you helpful.
I use the great HMG3.2(stable). Have i nice international HMG to everyone!
jpp
Post by jpp »
hello italia1,
Thx for answer but in the grid mouse events are windows events and are not catch by create event.
I've found a workaround by 'patching' the events function in the source code and now i can catch everything !
if someone have interest for that, i will publish it !
bye
Hello jpp,
I have interest!
Thx, Serge
jpp
Post by jpp »
here the way :
Here is the patch of the event fnt ( H_WINDOWS.PRG )
Function EventProcess (hWnd, nMsg, wParam, lParam, IsKeyboardMessage, IsHMGWindowsMessage, nHookID, nHookCode)
LOCAL nIndex
LOCAL cProcName, Ret := NIL
LOCAL lProcessMessage
   FOR nIndex = 1 TO HMG_LEN (_HMG_EventData)
      lProcessMessage := .F.
      IF EventProcessAllHookMessage (nIndex) == .T.
         lProcessMessage := .T.
      ELSEIF EventProcessHMGWindowsMessage (nIndex) == .T. .AND. IsHMGWindowsMessage == .T.
      ELSEIF EventProcessKeyboardMessage   (nIndex) == .T. .AND. IsKeyboardMessage   == .T.
      *-- Deb Jpp
      ELSEIF AT("BYPASS", UPPER( EventGetPROCNAME (nIndex))) > 0
      *-- Fin Jpp
      IF EventCompareParam (_HMG_EventData[nIndex][2], hWnd) .AND. ;
         EventCompareParam (_HMG_EventData[nIndex][3], nMsg) .AND. ;
         EventSTOP (nIndex) <> .T.                           .AND. ;
         lProcessMessage == .T.
         EventSTOP (nIndex, .T.)   // avoids re-entry
         _PushEventInfo()
            _HMG_EventIsInProgress        := .T.
            _HMG_EventIsKeyboardMessage   := IsKeyboardMessage
            _HMG_EventIsHMGWindowsMessage := IsHMGWindowsMessage
            _HMG_EventHookID              := nHookID
            _HMG_EventHookCode            := nHookCode
            _HMG_EventINDEX               := nIndex
            _HMG_EventHWND                := hWnd
            _HMG_EventMSG                 := nMsg
            _HMG_EventWPARAM              := wParam
            _HMG_EventLPARAM              := lParam
            _HMG_EventPROCNAME            := ALLTRIM (EventGetPROCNAME (nIndex))
            cProcName := _HMG_EventPROCNAME
            IF HB_URIGHT(cProcName, 1) <> ")"
               Ret := &cProcName()
               Ret := &cProcName
            _HMG_EventIsInProgress := .F.
         _PopEventInfo()
         EventSTOP (nIndex, .F.)   // restore entry
Return Ret
Then if the name of your create event proc have 'Bypass' in the name
you catch all events of the control.
Example :
create event procname Check_Event_bypass() HwND form_1.GRID_1.HANDLE
#define DO_EVENT    Nil
#define NO_EVENT    1
proc check_event_bypass()
local nMsg:= eventMsg()
if nMsg==WM_MOUSEWHEEL
    return  NO_EVENT
elseif nMsg==WM_MOUSEMOVE
    return NO_EVENT
elseif nMsg== WM_LBUTTONDOWN
    return DO_EVENT
elseif nMsg== WM_RBUTTONDOWN
    return DO_EVENT
elseif nMsg== WM_KEYUP
    return DO_EVENT
elseif nMsg== WM_KEYDOWN
Thanks for sharing JPP !
Nice implementation JPP ! (I wish t know your real name :P ) I thought was not possible to do it... Thank you to share your experience in all around for events propierties.
Just for good understanding for rest of colleagues I make a demo after changings with ByPass in H_WINDOWS.PRG source lib file:
#define NO_EVENT    1
#define WM_MOUSEMOVE      512    // 0x0200      // ok
#define WM_LBUTTONDOWN    513    // 0x0201      // ok
#define WM_LBUTTONUP      514    // 0x0202      // ok
#define WM_RBUTTONDOWN    516    // 0x0204      // ok
#define WM_RBUTTONUP      517    // 0x0205      // ok
#define WM_MOUSEWHEEL     522    // 0x020A      // ok
#define WM_KEYDOWN        256    // 0x0100
#define WM_KEYUP          257    // 0x0101
#define WM_MOUSEHOVER     673    // 0x02A1
#define WM_MOUSELEAVE     675    // 0x02A3
Private cMsg
    WIDTH 430 ;
    HEIGHT 500 ;
    TITLE 'Demo Events' ;
    MAIN NOSIZE
    DEFINE STATUSBAR FONT "Courier New" SIZE 9
        STATUSITEM PadC("",75)
    END STATUSBAR
        WIDTH 400 ;
        HEIGHT 330 ;
        HEADERS {'Column 1','Column 2','Column 3'} ;
        WIDTHS {120,120,120} ;
        VIRTUAL ;
		CELLNAVIGATION ;
        ITEMCOUNT 1000 ;
	@ 360, 50 CHECKBOX Check_1 CAPTION 'Switch behaviour' WIDTH 150
	@ 360, 250 TEXTBOX Text_1 ;
		VALUE "" ;
		TOOLTIP 'Just Setting Focus and test'
	@ 400,10 LABEL Label_1 VALUE "Test with: keys Down and Up | Mouse Wheel | Mouse Left Btn | Mouse Right Btn" WIDTH 400 HEIGHT 60 FONT 'Arial' SIZE 8
	@ 420,60 LABEL Label_2 VALUE "Mouse moving | Switch Check Box | Set Focus in TextBox" WIDTH 400 HEIGHT 60 FONT 'Arial' SIZE 8
CREATE EVENT PROCNAME Check_Event_ByPass() HwND form_1.GRID_1.HANDLE
// CREATE EVENT PROCNAME Check_Event_Form()
Function Check_Event_Form()
Local WM_:=EventMSG()
IF EventHWND() == Form_1.HANDLE
   DO CASE
      CASE WM_ == WM_KEYDOWN
           msgbox("key_down")
      CASE WM_ == WM_MOUSEWHEEL
      CASE WM_ == WM_LBUTTONDOWN
      CASE WM_ == WM_RBUTTONDOWN
   ENDCASE
Function Check_Event_ByPass()
Local nMsg := EventMsg()
Local xRet := DO_EVENT
DO CASE
   CASE nMsg == WM_KEYUP
        cMsg:="key_up"
		xRet:=NO_EVENT
   CASE nMsg == WM_KEYDOWN
        cMsg:="key_down"
		xRet:=NO_EVENT
   CASE nMsg == WM_MOUSEWHEEL
        cMsg:="Mouse wheel"
		xRet:=NO_EVENT
   CASE nMsg == WM_MOUSEMOVE
		cMsg:="Mouse move"
		xRet:=NO_EVENT
   CASE nMsg == WM_LBUTTONDOWN
        cMsg:="Mouse lbtn Down"
   CASE nMsg == WM_RBUTTONDOWN
        cMsg:="Mouse Rbtn Down"
ENDCASE
If GetProperty("Form_1","Check_1","Value")=.T.
   xRet:=If(xRet==DO_EVENT,NO_EVENT,DO_EVENT)
Endif
Form_1.StatusBar.Item(1):=cMsg
Return xRet
Nice work jpp and thanks. I hope all of you will enjoy it !
MouseGridEvents (Executable Demo file).rar
(839.78 KiB) Downloaded 435 times
I also wish to ask to Dr. Soto if this jpp implementation:
*-- Deb Jpp
*-- Fin Jpp
Could be added at H_WINDOWS.PRG source lib file. What do you think about Claudio ?
jpp
Post by jpp »
thanks Pablo to have some interest for my work ...
I'have made an other patch to the source code to avoid to create an array of itemcount element in a virtual grid when you specify a dynamicback of forecolor.
I'had posted about that problem but with no answer i've found a good workaround.
Ps: My name is Jean Pierre, old programmer since .... a big lot of time and i'm very impressived by the work made by the HMG community !
good weekend to all !
Little joke:
event : how to catch a mouse in a grid ?
En verdad bonita aplicación, Felicidades app y demás que contribuyen a que esto sea una realidad.
