Grid becomes very slow with 2 instances...
jpp
Post by jpp »
Hi to all !
After a week end in front of HMG grid, i'm near the Burnout ...
I've made a sample pgm to explain my problem.
App and dbf are on a shared folder
if i run the app on a client all is OK ( loading time / Refresh about 500 ms )
if i run the app on another client the loading time / Refresh becomes 13 seconds on the both computers.
I've made test on three differents networks but allways the same and i really dont know what can be wrong
in my program.
you are my only chance, otherwise all i've made since one month will be unusable ....
Thanks a lot ...
RDDSETDEFAULT( "DBFNTX" )
DEFINE WINDOW Form_D ;
WIDTH 800 ;
HEIGHT 510 ;
TITLE 'Multiple Index Test' ;
MAIN
DEFINE MAIN MENU
POPUP 'DataBase'
ITEM "Create Test DataBase" ACTION test_database()
ITEM "Test Grid DataBase" ACTION testgrid()
end popup
end menu
end window
activate window form_d
return
proc test_database
LOCAL aStruct := { ;
{ "CODE", "C", 10, 0 }, ;
{ "FIRST" , "C", 30, 0 }, ;
{ "LAST" , "C", 30, 0 }, ;
{ "BIRTH" , "D", 30, 0 } ;
if file("test.dbf")
ferase("test.dbf")
DbCreate( "test", aStruct, "DBFNTX", .T. )
for f:=1 to 10000
append blank
repla Code with "CODE "+ str(f,5,0)
repla FIRST with "first "+ str(f,5,0)
repla LAST with "last "+ str(f,5,0)
repla birth with date()+f
next
if file("test1.ntx")
ferase("test1.ntx")
if file("test2.ntx")
ferase("test2.ntx")
if file("test3.ntx")
ferase("test3.ntx")
if file("test4.ntx")
ferase("test4.ntx")
index on code to test1
index on first to test2
index on last to test3
index on first+last to test4
dbcloseall()
return
proc testgrid
local t1:= HB_milliseconds(), t2
DEFINE WINDOW Form_1 ;
WIDTH 800 ;
HEIGHT 510 ;
CHILD ;
ON RELEASE DBCLOSEALL()
use test Shared index test1,test2,test3,test4
DEFINE MAIN MENU
POPUP 'Test'
ITEM 'Order 1 ' ACTION Ordertest(1)
ITEM 'Order 2 ' ACTION Ordertest(2)
ITEM 'Order 3 ' ACTION Ordertest(3)
ITEM 'Order 4 ' ACTION Ordertest(4)
END POPUP
END MENU
@ 10,10 GRID Grid_1 ;
WIDTH 770 ;
HEIGHT 400 ;
HEADERS {'Column 1','Column 2','Column 3','Column 4'} ;
WIDTHS {140,140,140,100};
VALUE { 1 , 1 } ;
ROWSOURCE "Test" ;
COLUMNFIELDS { 'Code' , 'First' , 'Last' , 'Birth' }
t2:= HB_milliseconds()
msgbox("Loading time " + str(t2-t1,5,0))
CENTER WINDOW Form_1
ACTIVATE WINDOW Form_1
Procedure OrderTest(n)
local t1,t2
dbsetorder(n)
Form_1.Grid_1.Refresh
msgbox("refrestime " + str(t2-t1,5,0))
jpp
Re: Grid becomes very slow with 2 instances...
Post by jpp »
Hi
I'have made an other test, and i am very in trouble
just a simple grid with a dbf on a shared folder, the browse of the database with pagedown is very quick.
if simply open the database and it's index on another pc on the network and the pagedown on the first pc becomes slow ...
i really do not know what to do ...
Hi jpp,
Run your program and apparently runs fast, I think the problem is that you must not delete the database that the previous user already opened, you must open the database with "USE MyDatabase MiAlias ​​NEW SHARED ALIAS" as "sHARED" is to share the dbf's in "RED" mode.
I hope help you.
Hi jpp,
I modified your program a little, in essence use CDX indices and increase the speed twice, but still, if the refresh is slow GRID., By time I can not do more tests, hopefully someone will help us.
Greetings.
Public ccDirData  := "\\Principal\Test2"      //ES LA RUTA DE LA CARPETA DONDE ESTAN LAS DBF Y CDX.
SET PATH    TO ( ccDirData )
SET DEFAULT TO ( ccDirData )
REQUEST DBFCDX
RddSetDefault( "DBFCDX" )
WIDTH 800 ;
HEIGHT 510 ;
MAIN
DEFINE MAIN MENU
POPUP 'DataBase'
ITEM "Create Test DataBase" ACTION test_database() 	//
end popup
end menu
end window
return
proc test_database
REQUEST DBFCDX
if file("test.dbf")
ferase("test.dbf")
DbCreate( "test", aStruct, "DBFCDX", .T. )
for f:=1 to 10000
append blank
next
if file(ccDirData+"/test1.ntx")
ferase("test1.ntx")
ferase("test2.ntx")
ferase("test3.ntx")
ferase("test4.ntx")
INDEX ON Code TAG Test1
INDEX ON First TAG Test2
INDEX ON Last TAG Test3
INDEX ON First+Last TAG Test4
dbcloseall()
return
proc testgrid
REQUEST DBFCDX
WIDTH 800 ;
HEIGHT 510 ;
CHILD ;
use test NEW Shared
      Test->(ORDSETFOCUS('Test1'))
      Test->(ORDSETFOCUS('Test2'))
      Test->(ORDSETFOCUS('Test3'))
      Test->(ORDSETFOCUS('Test4'))
*index test1,test2,test3,test4
DEFINE MAIN MENU
POPUP 'Test'
END POPUP
END MENU
WIDTH 770 ;
HEIGHT 400 ;
VALUE { 1 , 1 } ;
ROWSOURCE "Test" ;
local t1,t2
dbsetorder(n)
jpp
Post by jpp »
hi javier,
thx for your answer and your test . in time i've made the tests as you with dbfcdx, but it's still too slow
in a professional environment.
( i've made the same test with my old clipper, and still really faster in all the ways ! )
I've made an other test to understand the pb,
i have a database in a shared folder in the server.
on a client i open in shared mode the database and i just make a loop
proc main
use test new shared index test1, test2, test3, test4
t1=hb_milliseconds()
dbgotop()
while !eof()
dbskip()
enddo
t2=hb_milliseconds()
msgbox("time to skip " + str(t2-t1,8,0))
dbcloseall()
return
i have a result of 180 ms
now, i just open the database with indexes on an other computer
proc main
msgbox( "wait to close")
dbcloseall()
return
then i re-do the same test on the first computer and the time is about 7000 ms !
I will be very happy if somebody could make the same test, because if the results are the same it is impossible to
program some app in a network share.
this little sample explains why networking's grid with a lot ( 2 or 3 ! ) of users becomes very slow, because grid uses GetDataGridRecCount() , and GetDataGridRecCount() uses 'count to' which is so slow as dbskip when the database is open
on differents computers.
i will go to bed, perhaps the solution will come tomorow .... :(
Hola jpp, antes que te vayas a dormir...
Lo que yo he observado en una aplicación en RED, es que si se puede manejar muy agradablemente, por falta de tiempo ahorita no puedo hacer una aplicación limpia. Yo tengo un sistemita de pruebas en red y parece que esta en una sola maquina, muy rapido, solo que no tengo bases de datos grande, a lo mejor esa es la diferencia. He leido que se pueden hacer trucos para solo cargar parte de la base de datos al momento e irse cargando los demas a la hora de hacer scroll. NO ES QUE SEA DEFICIENTE PROGRAMAR EN RED, ES SOLO CUESTION DE EXPERIENCIA.
Saludos y
Ahora si puedes irte a dormir :D :D :D
Hi jpp, before you go to sleep ...
What I have observed in an application to RED, is that if you can handle very nicely, for lack of time right now I can not do a clean application. I have a test sistemita network and it looks like this on a single machine, very fast, just that I have no big database, maybe that's the difference. I have read that you can do tricks to load only part of the database when loading and leave others when scrolling. BE POOR IS NOT SET IN RED IS ONLY A MATTER OF EXPERIENCE.
greetings and
Now if you can go to sleep
dhaine_adp
Post by dhaine_adp »
Hi JPP,
Just a question regarding network share:
1. What is the speed of your network connection 10/100/1000 Auto/Half/Full Duplex?
2. Did you try mapping the network drive and run the test again?
3. Are they in the same IP segment? Otherwise how many router hop?
4. Lastly I assume your test workstation has no issue about drive fragmentation, no CRCs' and bad sectors.
Pardon me for asking such questions, no offense meant.
Danny
Danny
Manila, Philippines
Jpp,
It's running rather fast here (200-300msecs).
It slows down when I change 10.000 to 100.000 (2100 msecs) but still fast.
Changing to 1 million records: 23.363 msecs (very slow)....
Greetings, Serge
jpp wrote:Hi
It is a known Windows LAN problem and it is related to your Windows LAN's settings.
The Harbour contrib library HbWin have a special function win_osNetRegOk() for check and set a correct Windows Registry settings for safe networking.
Usage:
   ? 'Checking and setting network for Windows'
   IF WIN_OSISTSCLIENT() .AND. !WIN_OSNETREGOK() // Note: If Windows Terminal Server client DONOT
                                            //       attempt to set registry.
     ? 'Registry on WTS server is not set correctly for networking.'
     ? 'Please check with System Administrator to set the registry correctly.'
   ELSEIF WIN_OSNETREGOK( .T. )
     ? 'Registry set OK for networking'
     ? 'Failed to set registry - May need "Administrator" rights'
Hope that useful :o
