ToolBar button add / Remove
jpp
Post by jpp »
hi to all
I'm tring to add / remove dynamicly buttons from a toolbar.
to add a button no problem, but when i remove a button ( cForm.cBtn.release ), the button is still present but with no action !
Is it a way to completly remove it ?
Ps: i'm surprise that the "Parent" of the button is not the toolbar but the form
( cForm.cToolbar.cButton.release ) -> Error
thx
Re: ToolBar button add / Remove
Hola JPP : HMG Reference
file:///C:/hmg.3.2/doc/data/index.htm
- Since ToolBar is a container, you can specify when refer to properties or events of its child buttons, ie:
    Win1.ToolBar1.Button1.Enabled := .F.
You can post an example as real tiepo add an item to see if I use the method
AddItem Method
      <ParentWindowName>.<ControlName>.AddItem (<cItem> | <acItem> )
jpp
Post by jpp »
thx daniel for ure answer
but my purpose is not to enable or disable a button in the toolbar,
but to destroy it as u can do it for a control in a form (cForm.cControl.release ).
I the hmg ref ( my bed book ! ) i've not seen the method release for a toolbutton...
I would eliminate the Toolbar completely and recreate the necessary buttons.
this is an example to create and delete controls inside a form I made a while
Public nPage        := 0
Public cPage         := "Page"  + ltrim(str(nPage))
Public cText         := "Text"  + ltrim(str(nPage))
Public cImage        := "Image" + ltrim(str(nPage))
Public cLabel        := "Label" + ltrim(str(nPage))
Public cCombo        := "Combo" + ltrim(str(nPage))
Procedure DeletePage()
Local nDelete
nDelete:= Principal.Container_Tab.Value
cImage := "Image" + ltrim(str(nDelete))
cLabel := "Label" + ltrim(str(nDelete))
cText  := "Text"  + ltrim(str(nDelete))
cCombo := "Combo" + ltrim(str(nDelete))
if iscontroldefined(&cImage,Principal)
   Principal.&(cLabel).RELEASE
   Principal.&(cImage).RELEASE
   Principal.&(cText).RELEASE
   Principal.&(cCombo).RELEASE
     Principal.Container_Tab.DELETEPAGE(nDelete)
   nPage--
   IF nPage == 1
      AddNewPage()
   MSGINFO("Cannot delete PAGE Add+","   Info  " )
Function AddNewPage()
IF nPage == 1
   cPage := 'Page'+ltrim(str(nPage))
   Principal.Container_Tab.AddPage ( nPage, cPage )
   AddControls()
   nPage++
   Principal.Container_Tab.Value  := nPage - 1
 IF Principal.Container_Tab.Value == nPage
    IF nPage >= 2
        Principal.Container_Tab.DeletePage(nPage)
        AddControls()
        nPage++
        Principal.Container_Tab.AddPage ( nPage, 'Add+','New.jpg' )
            nPage++
            AddControls()
            nPage++
            Principal.Container_Tab.AddPage ( nPage, 'Add+' )
            Principal.Container_Tab.Value  := 1
jpp
Post by jpp »
thx
i have made a small sample to understand my problem ( Hmg 3.2 )
if u have some time to test it it will be nice !
    Test toolbar
proc main
DEFINE WINDOW W_TEST ;
		WIDTH 500 ;
		HEIGHT 300 ;
		TITLE "TEST" ;
		Main
		DEFINE MAIN MENU
			DEFINE POPUP 'Test'
			    MENUITEM 'Create toolbar' ACTION createtool()
			    MENUITEM 'destruct toolbar with error create again' ACTION  deltoolbar_with_error_create_again()
			    MENUITEM 'destruct toolbar OK create again' ACTION  deltoolbar_OK()
			    MENUITEM "delete btn1" ACTION delbtn1()
			    MENUITEM "Create btn3" ACTION createbtn3()
			END POPUP
		END MENU
		ON KEY ESCAPE ACTION THISWINDOW.RELEASE
CENTER WINDOW W_TEST
ACTIVATE WINDOW W_TEST
function createtool()
 _DefineToolBar ( "ToolBar1" ,"w_test" , 100 , 30 , .T. , .T. , .T. , .F. , , , .F. , .F. , .F. , .F. , , , .F. , 20 , 20 , .F. )
 _DefineToolButton( "Btn1", ,"Btn1", { ||  MsgInfo('Btn1') })
 _DefineToolButton( "Btn2", ,"Btn2", { ||  MsgInfo('Btn2') })
return nil
function deltoolbar_with_error_create_again()
    First : the toolbar seems to be destroy, but if you want to create it one's again
    u will have an error "Btn1 of w_test always defined"
    THAT WHY i ask me about the "real" parent of btn1 and btn2 ....
    w_test.toolbar1.release
return nil
function deltoolbar_ok()
    w_test.btn1.release     // w_test parent for toolbar's BTN ?????
    w_test.btn2.release
return nil
function delbtn1()
    As u can see btn1 is still present but non action available
    HOW TO REMOVE IT FOM THE TOOLBAR ??????
w_test.btn1.release
return nil
Function createbtn3()
    How know _defineToolButton the ref of the toolbar ???
 _DefineToolButton( "Btn3", ,"Btn3", { ||  MsgInfo('Btn3') })
 return nil
