Is there any way to change the Height of a radiogroup items ?
it seem that where aligned horizontally with a textbox or label, the radiogroup items taller than the others.
And sometimes the radiogroup could damage the textbox below it.
thks n rgds
Chang
RadioGroup Height change ?
Just Hmg It !
Re: RadioGroup Height change ?
Chang,
You can adjust the distance of the RadioGroup items with Spacing Property, if you meant this..
( for example see in c:\hmg.3.2\SAMPLES\Controls\RadioGroup\RADIOGROUP.4 )
Nikos.
os: Windows Server 2019 - 64
Nikos.
I have the screen-shot but dont know how to insert it here !
I can't even paste it here !
pls advise how to paste image here !
thks n rgds
Chang
thks n rgds
Chang
Just Hmg It !
in Post A Reply chose in the second frame (Upload attachment) press the button Add the file (chose your image file) and press the Button Submit.
Nikos.
Nikos.
as we can see that the radiobuttons damage the textbox below ....
The other thing is the radiogroup not really align with the label on the left...
- hmgforum01.JPG (13.01 KiB) Viewed 5485 times
Just Hmg It !
Hello hmgchang,
Yes, that is a friend, not everything is perfect at 10000000% but I think we can live with that!, Only manually adjusted until best!
I've used several IDE'S Visual Basic, FoxPro, Delphi and all have those little details. We do not complequemos existence with pequeñeses.
P. D. Only IDE'S, NOT SET FOR ANY OF THEM. HMG and that only a little.
