Page 1 of 3
Control under the Mouse
Posted: Wed Jan 22, 2014 5:13 pm
by jpp
Hi to all,
if you want to know the control under the mouse pointer ( to select it or change the shape of the pointer ) here if the way to simulate a MOUSE OVER
DEFINE WINDOW w_test
some controls ( label, textbox, etc ... )
CREATE EVENT PROCNAME TESTMOVE HWND W_test
ACTIVATE WINDOW W_TEST
function testmove()
LOCAL hWnd := EventHWND()
Local nMsg:= EventMsg()
local wParam:= EventWPARAM ()
local cNom, cForm
if nMsg == 32 .and. wParam <> win_1.HANDLE
GetControlNameByHandle(wParam,@cNom, @cForm)
msgbox("Event " + str( nMsg,3,0) + " / " + str(wParam,8,0) + " / " + cNom + " / " + cForm )
return nil
that's all !!!
bye
Re: Control under the Mouse
Posted: Thu Jan 23, 2014 3:00 am
That is so nice. :)
Posted: Thu Jan 23, 2014 4:29 am
by Javier Tovar
Muy bien amigo!
Posted: Thu Jan 23, 2014 10:50 am
Hi jpp
Welcome aboard :)
jpp wrote:here if the way to simulate a MOUSE OVER
Good sample, thanks to participation :)
Posted: Thu Jan 23, 2014 11:04 am
by jpp
hi and thx for ure messages...
Now if u want to select the control change the proc EVENT to this one :
function selectCtrl()
local cNom,cForm
static ctrlselect:= ""
if wParam <> win_1.HANDLE
if nMsg == 528 .and. !empty(ctrlselect)
msgbox("ctrl selected " + ctrlselect )
if nMsg == 32
ctrlselect:= upper(cNom)
ctrlselect:= ""
return nil
i've tested with label, textbox and button ...
Any feeback welcome
Bye
Posted: Thu Jan 23, 2014 4:59 pm
by andyglezl
Hi to all,
function testmove()
local cNom, cForm
if nMsg == 32 .and. wParam <> win_1.HANDLE <====== ERROR
return nil
that's all !!!
bye
Hi jpp, gives error, which is defined Win_1?
Posted: Thu Jan 23, 2014 6:43 pm
by Javier Tovar
Hola jpp,
Me da error, me dice que no existe la variable "W_test"
CREATE EVENT PROCNAME TESTMOVE HWND W_test <===== ERROR
function testmove()
local cNom, cForm
return nil
Posted: Thu Jan 23, 2014 9:28 pm
by jpp
Sorry for the mistake !
win_1.handle does not exist, it's W_TEST ( the name of the form )
bye
Posted: Fri Jan 24, 2014 11:14 pm
jpp wrote:if you want to know the control under the mouse pointer ( to select it or change the shape of the pointer ) here if the way to simulate a MOUSE OVER
DEFINE WINDOW w_test AT 222 , 270 WIDTH 550 HEIGHT 350 ;
    TITLE "simulate a MOUSE OVER" ICON NIL MAIN
    ON KEY ESCAPE ACTION Thiswindow.Release()
    DEFINE TEXTBOX Text_1
        ROW    40
        COL    80
        WIDTH  120
        HEIGHT 24
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE Nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONENTER Nil
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        READONLY .F.
        RIGHTALIGN .F.
        DISABLEDBACKCOLOR Nil
        DISABLEDFONTCOLOR Nil
        CASECONVERT NONE
        BACKCOLOR Nil
        FONTCOLOR Nil
        INPUTMASK Nil
        FORMAT Nil
        VALUE "Test Box"
    END TEXTBOX
    DEFINE LISTBOX List_1
        ROW    100
        COL    80
        WIDTH  100
        HEIGHT 100
        ITEMS {"Test1","Test2"}
        VALUE 0
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE Nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        BACKCOLOR Nil
        FONTCOLOR Nil
        ONDBLCLICK Nil
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        SORT .F.
        MULTISELECT .F.
        DRAGITEMS .F.
    END LISTBOX
    DEFINE RADIOGROUP RadioGroup_1
        ROW    100
        COL    300
        WIDTH  120
        HEIGHT 50
        OPTIONS { 'Option 1','Option 2'}
        VALUE 1
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE Nil
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        TRANSPARENT .F.
        SPACING 25
        BACKCOLOR Nil
        FONTCOLOR Nil
        READONLY Nil
        HORIZONTAL .F.
    END RADIOGROUP
CREATE EVENT PROCNAME TESTMOVE HWND W_test.HANDLE
// CREATE EVENT PROCNAME SELECTCTRL HWND W_test.HANDLE
w_test.Center
w_test.Activate
Function TestMove()
Local hWnd := EventHWND()
Local wParam:= EventWPARAM ()
Local cNom, cForm
if nMsg == 32 .and. wParam <> w_test.HANDLE
Function SelectCtrl()
Local cNom,cForm
Static ctrlselect:= ""
if wParam <> w_test.HANDLE
      if nMsg == 32
         ctrlselect:= ""
Nice sample. Thanks JPP for you sharing with us ! :)
Javier Tovar wrote:Hola jpp,
Hola Javier, prueba con: W_test.HANDLE (ejemplo completo es el que acabé postando)
Posted: Sat Jan 25, 2014 12:03 am
by Javier Tovar
Hola Pablo César,
Fantastico! me quede :o
Un Abrazo :D
