I think I seen a post that said how to use check box Y/N instead of T F. I have an old table I am using with Y/N fields and it would
save a lot of programing to use check box to modify field.
Any help would be appreciated Thanks ................ Franco
Y/N check box
Y/N check box
All The Best,
Franco
Canada
Franco
Canada
Re: Y/N check box
Hello Franco,
Where you want to be displayed is "S / N" IN VIEW OF .T / .F where you just have to want to do..:
and your Variable cValor the samples in a grid for example.
tranks
cValor: = IF (lvalue == T., "SI", "NO".)tranks
Re: Y/N check box
Thank you Javier, this works perfectly ................................. Franco
All The Best,
Franco
Canada
Franco
Canada
