HMG 3.2 (Stable)
HMG 3.2 (Stable)
Dear Friends,
After a long time, we are releasing a stable version of HMG. This is the first UNICODE stable version of HMG.
As usual, the new version can be downloaded from here.
Alternatively it can be downloaded from Sourceforge also.
Changelog for this version:
-HMG 3.2 (Stable) 2013/12/08
   - This is a stable version of HMG
   - Zero message warning of compiler (Contributed by Dr. Claudio Soto)
   - Fixed: message loop bug (introduced in HMG.3.1.5) (Contributed by Dr. Claudio Soto)
   - Improvement in GetFolder() function (see doc) (Contributed by Dr. Claudio Soto)
   - Now DISABLEUPDATE/ENABLEUPDATE method available in GRID, COMBOBOX, BROWSE and TREE controls (Contributed by Dr. Claudio Soto)
   - New functions: GetUserName, GetComputerName, SetComputerName (Contributed by Dr. Claudio Soto)
   - New function: HMG_GetImageInfo ( [ cFileName | hBitmap ], @nWidth, @nHeight, @aBackColor, [ nRowColor ], [ nColColor ] ) --> Return lBoolean (Contributed by Dr. Claudio Soto)
   - New function: HMG_MessageBoxTimeout ( cText, cCaption, nTypeIconButton, nMilliseconds ) ---> return nRetValue (Contributed by Dr. Claudio Soto)
      - nTypeIconButton and nRetValue: are constants defined in i_MsgBox.ch
   - New info debug command: DEBUGINFO [ STOREIN cVar ] [ TITLE xTitle ] [ TYPE nTypeIconButton ] [ TIMEOUT nMilliseconds ] [ PARAMETERS ] xData1, xData2, ... (Contributed by Dr. Claudio Soto)
   - TREE control New Properties/Methods : (Contributed by Dr. Claudio Soto)
      - GetProperty     -> AllValue, RootValue, FirstItemValue, ImageCount, ParentValue, ChildValue, SiblingValue, ItemText, IsTrueNode
      - Set/GetProperty -> NodeFlag,ImageIndex
      - SetProperty     -> AddImage, TextColor, BackColor, LineColor
      - DoMethod        -> SetDefaultNodeFlag, SetDefaultAllNodeFlag, Sort
      - TREESORT ControlName OF ParentName [ ITEM nItem ] [ RECURSIVE lRecursive ] [ CASESENSITIVE lCaseSensitive ] [ ASCENDINGORDER lAscendingOrder ] [ NODEPOSITION nNodePosition ]
      - Enanced Expand/Collapse method: include recursive clause
   - Updated documentation of changes (Contributed by Dr. Claudio Soto)
   - New demos: (Contributed by Dr. Claudio Soto)
      - Samples\Controls\EditBox\EditBoxOverwrite (CREATE EVENT example)
      - Samples\Controls\Grid\GridIncrementalSearch (CREATE EVENT example)
      - Samples\Miscellaneous\ScreenSplash
      - Samples\Controls\Tree\TreeSort
HMG 3.2 (Stable)
Wow ! Thank you Rathinagiri, Claudio and all comunity !!
I Love you all ! :)
Re: HMG 3.2 (Stable)
Thank you very much, I will try it as soon as possible!
Rathinagiri wrote:After a long time, we are releasing a stable version of HMG. This is the first UNICODE stable version of HMG.]
Viva HMG, viva Mr. Diamond, viva Dr. Soto :D
Great release.
Is very good to have a stable release again.
Thanks to all involved on it.
Gracias a quienes hacen posible tener esta nueva versión ! ;)
Thanks to those who make it possible to have this new version ! ;)
Gracias a todos los que intervinieron en esto para que sea posible.
tonton2
Post by tonton2 »
Bonsoir,
Merci à toute l'equipe,je vais l'essayer tout de suite et la comparer avec la 3.1.5 :roll:
Hello,
Thank you to all the team, I'll try now and compare it with 3.1.5 :lol:
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
tonton2
Post by tonton2 »
il faudrait changer le paramètre de configuration de HMG dans IDE il indique 3.1.5 au lieu de 3.2.
should change the configuration parameter HMG IDE it says 3.1.5 instead of 3.2.
Y.TABET
Merhaba Youcef
tonton2 wrote:il faudrait changer le paramètre de configuration de HMG dans IDE il indique 3.1.5 au lieu de 3.2.
This indication is recorded in <hmg_root>\IDE\hmg.ini file;
this is a flat text file and you can freely modify it :arrow:
Happy HMG :D
