Triple Dot ( ...)
hmgchang
Triple Dot ( ...)
Post by hmgchang »
I found quiet a lot of tripple dot ( ...) at the samples. and no documentation about it.
like this one in myzip.prg.
PROCEDURE Main( ... )
LOCAL hZip, aDir, aFile, aWild, ;
cZipName, cPath, cFileName, cExt, cWild, cPassword, cComment, ;
tmp
LOCAL lUnicode
IF "--unicode" $ hb_CmdLine()
hb_cdpSelect( "UTF8EX" )
hb_SetTermCP( hb_cdpTerm() )
Set( _SET_OSCODEPAGE, hb_cdpOS() )
lUnicode := .T.
lUnicode := .F.
aWild := { ... }
- its in the PROCEDURE Main( ... )
- and at aWild := { ... }
pls advise Masters... and tq
Just Hmg It !
CalScot
Re: Triple Dot ( ...)
Post by CalScot »
The three dots are known in English as an ellipsis, for which the dictionary says:
ellipsis is the omission of one or more words, which must be supplied by the reader.
In your example
It means that you should provide the code for the procedure Main() and the elements for the aWild array in the example -- that the documentation will not provide it, assuming that you will be able to fill in your own processes/data in these places.
CalScot
hmgchang wrote:I found quiet a lot of tripple dot ( ...) at the samples. and no documentation about it.
It is Harbour language enhancement: variable number of parameters.
... at end of param list e.g. FUNCTION MyFunc(cArg1, nArg2, ...)
may be used elsewhere e.g. { ... } array of params
SYNTAX for variable number of parameters
1) [FUNCTION|PROCEDURE] name( ... )
or
2) [FUNCTION|PROCEDURE] name( var1, var2, varN, ... )
To access passed parameters use the following:
PCOUNT() - returns number of passed parameters
HB_PVALUE( iParamNum ) - returns <iParamNum> parameter
HB_APARAMS() - returns array with all passed parameters
or usual name of parameter variable in case of syntax 2)
Hope that useful. :idea:
Como siempre Grigory una fuente de conocimiento
As always a source of knowledge Grigory
Thanks Scotty and Grigory :)
Viva HMG :D
esgici wrote:Thanks Scotty and Grigory :)
Viva HMG :D
Valuable info
hmgchang
Post by hmgchang »
Thks Masters,
( CalScot, gfilatov, danielmaximiliano, esgici / i like your pic and bpd2000)
I misunderstood the programs since its under the test folder,
now I know I hv to provide in place of the ...
Just Hmg It !
