CDX Format
CDX Format
Hello,
I'm new here. Just been checking out CDX indexes in samples, but format of CDX seems to be different to what I'm used to. The ones I've used, and have a number of utilities for handling, have all the tags detailed in the header, followed by all the data. The HMG variant I'm looking at shows a list of the tag names in the header, followed by the full detail of the first key, then the data for that key, then the full detail for the second key, then data, etc.
Are there two different formats for CDX files?
Geoff
Geoff
Re: CDX Format
Hello GeoffGeoffBarnard wrote:Hello,
Geoff
Welcome aboard, greetings from Turkiye
In summary, internal structure of index file no matter for me, in general, if it works correct no problem.
If you want to use CDX file(s) built in any other tools by Harbour compiled application, may be some incompatibilities.
I didn't see any other problem with CDX files.
Does possible a little sample ?
Happy HMG
Re: CDX Format
Hola Geoff
No se a que te refieres exactamente, podrias hacer una muestra minima completa para poder entender.
Gracias
Hi Geoff
Not exactly what you mean, you could make a complete minimum sample to understand.
thanks
Gracias
Hi Geoff
thanks
- dhaine_adp
Re: CDX Format
Hi Geoff,
Welcome aboard to HMG. If you're really interested on low level/custom handling of CDX perhaps downloading Harbour (Hb) source code will give you a deeper insight not only with CDX but all RDDs' supported by Hb. HMG is a graphics library created by Mr. Roberto Lopez. However what connects between the GUI and record handling lies with Harbour RDDs', contribs (contributions) and 3rd party contributions. You can find the source and binaries from here:
Assuming that you unpacked the Harbour source on this directory: C:\harbour\core-master\src\rdd -- Your will find all the source codes and function wrappers as you traverse and trace the files and source codes in C. Please take your time skimming through the source codes and don't forget to read the file changelog.txt (You can search this file too, for more info and development history of Habour including RDDs' and DBFCDX).
If you feel that you need more information, the best approach is to address your concern directly to the Harbour Developers at: http://harbour.github.io/" onclick="window.open(this.href);return false; From that Websites Menu, hover your mouse to Development, then click Report Issues.
Danny
The only exception with Harbour DFBCDX is that you can't mix HB DBFCDX driver from another application that uses a different DBFCDX. But within Harbour, we haven't encountered any problem so far.
Danny
Danny
Manila, Philippines
Danny
Manila, Philippines
Re: CDX Format
Hello,
Thanks for messages.
OK, it may be problem with Harbour, not with HMG as such.
Yes, I accept that.
Looking elsewhere, I see some notes that MS may have changed format of .CDX (compound indexes) with intro of VFPro8. My existing systems may be using previous format, I'll have to see what I can do about that.
For my main developments (still DOS based) I'm using Codebase (Sequiter) and C. Still maintaining one BIG system, plus various personal processes. The big warehouse system uses .CDX, various big files using multiple tags.
I was thinking I might be able to use HMG to introduce some windows processes, accessing the main data files, but if indexes are different then this cannot be! I'll do some more testing, but it's possible .CDX with single tag may be OK, problem just with multiple tags.
Yes, I accept that.
Re: CDX Format
Hello Geoff
If you are planning share same data and index files between DOS based and 32/64 bit applications, I'm afraid that you have to be ready to bigger problems
Otherwise, if each application will use their files self-contained, should be no problem; simply you need build new CDX files once.
<hmg>\SAMPLES\Controls\EditBox\EDIT.EXTENDED\demo.prg ( OpenTable() procedure ) may give you some ideas on managing CDX files.
Happy HMG
You are the correct placeGeoffBarnard wrote: ...
I was thinking I might be able to use HMG to introduce some windows processes,..
No ! Please don't panic !accessing the main data files, but if indexes are different then this cannot be!
Happy HMG
Re: CDX Format
Hello Geoff,
Welcome from Belgium!
I started exactly one year ago with converting old clippers to HMG and with the help of this forum I now have
3 large applications up and running in production.
What I mean is: for any possible problem there will be a nice HMG solution !
Greetings, Serge
Greetings, Serge
Re: CDX Format
Hearty welcome Geoff.
Wow! That is so great Serge.I started exactly one year ago with converting old clippers to HMG and with the help of this forum I now have
Re: CDX Format
Thank you Rathinagiri. It all would be impossible without HMG and all your good examples!
- dhaine_adp
Re: CDX Format
Hi Geoff,
Somewhere along, you are always welcome in the forum. W'eve all came from the same place where you at now.
-Danny
Map out your tables or database and begin converting those at the bottom. That would be a long hard work man but definitely it can be done. The good thing is that you can preserved your database structure and all data in it.For my main developments (still DOS based) I'm using Codebase (Sequiter) and C. Still maintaining one BIG system, plus various personal processes. The big warehouse system uses .CDX, various big files using multiple tags.
-Danny
Danny
Manila, Philippines
Danny
Manila, Philippines
