Unicode and HMG_HPDF
Hi All
It's seems that HMG_HPDF doesn't support unicode :( :?
Is this correct and if so may be a hope for the future ?
IMATECH
Re: Unicode and HMG_HPDF
Post by IMATECH »
Hi Esgici !
I see no problem :)
cText_hbHpdf := hb_Translate( c_AnyString, 'UTF8EX', cMyCodePage )
M., Ronaldo
By: IMATECH
Imation Tecnologia
IMATECH wrote: I see no problem :)
Thank Ronaldo, I will prob it.
By the way my problem is on file name, not pdf text.
IMATECH
Post by IMATECH »
Hi Esgici !
I Think you can use the same solution:
c_file_name_for_pdf_File := hb_Translate( c_AnyString, 'UTF8EX', cMyCodePage )
M., Ronaldo
By: IMATECH
Imation Tecnologia
Gracias Ronaldo por compartir sus conocimientos
Hi All
esgici wrote: It's seems that HMG_HPDF doesn't support unicode :( :?
This is my SSW :
Results of this SSW
Results of this SSW
the code :
  Exploring UTF8 implementation in HMG_HPDF
#include "hfcl.ch"
PROCEDURE Main()
   cSourceFileName := "español.txt"
   cSourceText := HB_MEMOREAD( cSourceFileName )
   cTargetFileName := STRTRAN( cSourceFileName, "txt", "pdf" )
   SELECT HPDFDOC ( cTargetFileName ) TO lSelPDF // papersize HPDF_PAPER_A4
   IF lSelPDF
      START HPDFDOC
         START HPDFPAGE
            @ 20,  20 HPDFPRINT cSourceText
         END HPDFPAGE
      END HPDFDOC
      IF FILE( cTargetFileName )
         MsgInfo( "PDF Builded as " + cTargetFileName )
         MsgStop( "PDF Building Unsuccessful :(", "Unexpected ERROR !" )
      ENDIF FILE( cTargetFileName )
   ENDIF lSelPDF
RETURN // BTExplore.Main()
*-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.
Any idea :?:
And, Ronaldo,
Would you like add your suggestions on this code,
( with required REQUEST statements and SETxxx commands / functions)
please.
Esgici,
As of now we can't use unicode with HPDF.
Claudio had also tested in a newer version of HPDF for unicode. We are investigating this and it is a main agenda for the upcoming versions.
Rathinagiri wrote: As of now we can't use unicode with HPDF.
Thanks to clarification my brother,
you are UNIQUE :arrow:
With my best reagrds :D
quartz565
Post by quartz565 »
Please do not forget the problem with the distance between the letters of the Greek words... :) :arrow:
Nikos.
os: Windows Server 2019 - 64
IMATECH
Post by IMATECH »
Hi Esgici !
Adjusted ( but not tested ! )
#include "hfcl.ch"
PROCEDURE Main()
   cSourceText := hb_Translate( HB_MEMOREAD( cSourceFileName ), 'UTF8EX', 'ESISO' )
   SELECT HPDFDOC ( hb_Translate( cTargetFileName, 'UTF8EX', 'ESISO' ) ) TO lSelPDF // papersize HPDF_PAPER_A4
   IF lSelPDF
      _HMG_HPDF_SetEncoding( "WinAnsiEncoding" )
      START HPDFDOC
         START HPDFPAGE
         END HPDFPAGE
      END HPDFDOC
   ENDIF lSelPDF
// hb_gtsys()
PROCEDURE hb_gtsys()
   REQUEST HB_LANG_ES
   REQUEST HB_CODEPAGE_ESISO
M., Ronaldo
By: IMATECH
Imation Tecnologia
