busqueda en una dbf / dbf search
CarlosRD
Post by CarlosRD »
HOLA A TODOS / HI ALL:
TENGO LA NECESIDAD DE HACER LA SIGUIENTE BUSQUEDA Y NO LA HE ENCONTRADO EN LOS EJEMPLOS DE LA VERSION 3.0.46
SI EN UNA BASE DE DATOS TENGO LOS SIGUIENTES REGISTROS:
REGISTRO 1 -> JUAN PEREZ BOTIJA
REGISTRO 2 -> JUAN ESPINOZA REYES
REGISTRO 3 -> ESPERANZA LOPEZ PEREZ
REGISTRO 4 -> PEREZ REYES JOSE LUIS
REGISTRO 5 -> CARLOS ZARATE LOZADA
SI POR MEDIO DE UN TEXTBOX INGRESO LA PALABRA “PEREZ”, NECESITO OBTENER LO SIGUIENTE:
ALGUIEN HA HECHO ESTO ANTES???
SALUDOS, CARLOS RD.
I HAVE THE NEED FOR THE NEXT SEARCH AND HAVE NOT FOUND IN THE EXAMPLES OF VERSION 3.0.46
IF I HAVE NEXT RECODS IN A DATABASE:
RECORD 1 -> JUAN PEREZ BOTIJA
RECORD 2 -> JUAN ESPINOZA REYES
RECORD 3 -> ESPERANZA LOPEZ PEREZ
RECORD 4 -> PEREZ REYES JOSE LUIS
RECORD 5 -> CARLOS ZARATE LOZADA
USING A TEXTBOX CONTROL I TYPE “PEREZ”, I NEED TO GET NEXT:
ANYBODY HERE HAS MADE SOMETHING LIKE THIS???
REGARDS, CARLOS RD.
Todo en el Nombre de Jesus / All in the name of Jesus
Carlos RD
Re: busqueda en una dbf / dbf search
Did you tried OrdWildSeek() :?:
By the way, why you are writing everything in uppercase :?:
Vikipedia wrote:With the advent of the Bulletin board system, or BBS, and later the Internet, typing messages in all caps became closely identified with "shouting" (yelling) or attention-seeking behavior, and is considered very rude. As a result, netiquette generally discourages the use of all caps when posting messages online. While all caps can be used as an alternative to rich-text "bolding" for a single word or phrase, to express emphasis, repeated use of all caps can be considered "shouting" or irritating.
Source is here
CarlosRD
Post by CarlosRD »
Thanks Esgici.
Ordwildseek() works perfect.
About my writing with uppercase, it was only because my keyboard had activated the capslook key. :oops:
regars, Carlos RD
Carlos RD
Mario Mansilla
Post by Mario Mansilla »
Hola Carlos :
podrias publicar un ejemplo de como lo utilizaste ?
Mario Mansilla
Hi Carlos:
could you post an example of how you used it?
Mario Mansilla
CarlosRD wrote: Ordwildseek() works perfect.
I'm glad that you like it :)
No problem amigo; I was sure that you understood me :)
Mario Mansilla wrote: could you post an example of how you used it?
Hola Mario
You would find here an explanation and a simple examle; if you need more detailed exmple, please inform me.
CarlosRD
Post by CarlosRD »
Mario Mansilla wrote: Hola Carlos :
Mario Mansilla
con mucho gusto mario, buenas tardes.
function busca_cliente(f_dato)	// funcion llamada por una tecla o procedimiento para filtrar información
	m_recnos_found := {}		// array para anidar los registros que coincidan
	select wa_clientes			// archivo de clientes (work area), en donde voy a realizar la busqueda
	go top
	do while OrdWildSeek( f_dato , .t. )
		aadd ( m_recnos_found, { wa_clientes->clave, wa_clientes->nombre } )		// agrego al arrar, los registros coincidentes
	enddo
return (m_recnos_found)
Asi quedaria el procedimiento de la busqueda, luego el array que regresa a tu llamada, lo puedes anidar en un listbox para seleccionar al cliente (en este caso) que necesitas.
Espero que mi explicacion sea la correcta. Saludos, Carlos RD.
Carlos RD
Mario Mansilla
Hola Carlos / Esgici :
muchas gracias por su ayuda .
Personalmente utilizo mucho el onchange de un textbox para ingresar el criterio de busqueda y el resultado lo muestro en un control browse evaluando con Dbseek . Ambos ejemplo que me muestran utilizan un control grid o listbox , veo si lo puedo implementar con un control browse .
Cualquier cosa les consulto .
Saludos .
Mario Mansilla
Hola Carlos and Mario
This example may considered more clear and more useful :
// The example uses two wildcard search strings to show
// possible search results of OrdWildSeek()
   PROCEDURE Main
      LOCAL aCust := {}
      USE Customer
      INDEX ON Upper(LastName) TO Cust01
      DO WHILE OrdWildSeek( "*MAN?", .T. )
         AAdd( aCust, FIELD->Lastname )
      ENDDO
      AEval( aCust, {|c| QOut(c) } )
      // Found records:
      //   Dormann
      //   Feldman
      GO TOP
      aCust := {}
      DO WHILE OrdWildSeek( "*EL*", .T. )
      ENDDO
      // Found records:
      //   Feldman
      //   Hellstrom
      //   Keller
      //   Reichel
      USE
