Keeping LOG
Keeping LOG
Hi All
Code debugging is un-ignorable need for every programmer and DEBUG facility of Clipper / Harbour / HMG is very handy; with a little drawback :
it's highly complex due to its features and not easy to learn and use.
For a little purpose, a little Msgxxx functions ( especially MsgDebug() of our genius Dr. Soto ) will be enough in many time, under many circumstances; remembering WAIT and ALERT() of console mode.
And we have a little problem too in this method : if required 'repetitive' calls ( such as into a loop ) of that Msg function, requiring repetitive answers may be annoying.
In this condition we need a "log" file to records repeating values.
My preference ( IMHO the easiest way to build a text file ) is using and ALTERNATE file.
Pseudo code :
   build an empty log file
   begin loop
     use "?" or QUOT() to write the log file
   end loop
   close log file and show content
Here two little and simple procedure to Open / Close and show log file
I hope will be useful.
Altes.zip
Source and ReadMe files of xxxxALTE procedures
(1.97 KiB) Downloaded 353 times
Re: Keeping LOG
Thank you Esgici
Re: Keeping LOG
Nice example Esgici.
I create many text files (for report printing in old dot matrix printers) in a HMG application using set alternate. In that case, will this logic work?
Re: Keeping LOG
Thanks Rathi
Rathinagiri wrote:I create many text files (for report printing in old dot matrix printers) in a HMG application using set alternate. In that case, will this logic work?
Sure; this is for building (text) file only, printing is other side of subject ;)
Simply you may need some little modification on 'defaulting parameters" points: you may want no defaulting file name parameter and produce an error message such as "no file name specified" or anything else. Or your default target file name will be different, FE "report.txt" instead of PROCNAME( 1 ) + ".LOG"
IMHO important point is : since '?' and QOUT() are for console, in GUI mode has no effect. Bu this not means "this command / function doesn't work on GUI mode"; instead, as seen in the example, they are working and makes their job successfully :arrow:
Best regards and Happy HMG'ing :D
Re: Keeping LOG
I mean I am already using 'set alternate' in my existing HMG application for other text file creation. In that case both this log file and that text file will work separately?
Re: Keeping LOG
Esgici,
What I use/do is following:
SET PRINTER TO C:\folder\debug.TXT
SET PRINTER ON
SET CONSOLE OFF
<your loop>
? what_ever
SET PRINTER TO
SET PRINTER OFF
SET CONSOLE ON
The file C:\folder\debug.TXT is open in my editor for viewing.
Greetings, Serge
Re: Keeping LOG
Rathinagiri wrote:I mean I am already using 'set alternate' in my existing HMG application for other text file creation. In that case both this log file and that text file will work separately?
As far as I know no :(
Because there isn't a way to change target of '?' / QOUT() to this or that media / file.
Nevertheless we have other ways to write something to separate files.
I will work to build a sample for this.
Re: Keeping LOG
serge_girard wrote: What I use/do is following:
Yes, this way too is legal and possible.
Please look at here.
Re: Keeping LOG
Hi All
esgici wrote:...
As promised :
Screen shoot
Screen shoot
WTMTFSFT.zip
Source and sample data file
(5.24 KiB) Downloaded 349 times
Look at ReadMe file for detailed info.
