EXIT BUTTON VALIDATION
Re: EXIT BUTTON VALIDATION
Grigory,
Your last code will lock then COMPANY table forever as long as the application is running....
Better to CLOSE and re-USE it !
Greetings, Serge
Thank you Grigory for excellent tip
serge_girard wrote:Grigory,
Hello Serge,
IMHO It is a sample for show of breaking a textbox validation only but not a database network using...
gfilatov wrote:... updated sample with implemented your needs below:
Thank to fix and clarify, Grigory :)
Actually, your VALIDATION code is very nice, when used correct :arrow:
Happy HMG :D
dhaine_adp
Post by dhaine_adp »
Here is a multiple flat table and multiple windows validation routine written in clipper logic and was adopted to HMG (windows). Its a code snippet but if you read the code carefully you'll find that it is more like a clipper code roughly equivalent to:
function Label( cMode )
DO CASE
CASE cMain == "EMPLOYEE"
**Screen 1
@ Row, Col SAY "Code"
@ Row, Col SAY "Name"
CASE cMain == "PRODUCT"
**Screen 2
@ Row, Col SAY "Description"
END CASE
function GetFlds( cMode )
DO CASE
*Code
IF cMode == "ADD"
@ Row, Col GET aFVar_[ 1 ] VALID validation()
@ Row, Col SAY aFVar_[ 1 ]
@ Row, Col GET aFVar_[ 2 ] VALID validation()  // Name
** here same logic applies as in the above CASE block and
END CASE
READ
In HMG, the same principles was adopted as described above. The variable cDBMain is a PRIVATE parameter received as follows and called from the Main Menu or Toolbar as: FileMain( "HOLIDAY" )
function FileMain()
   PARAMETERS cDBMain
   --> Then loads a browse or grid window with buttons: Add, Edit, Delete, Search, Print, Close
   --> When Add button is click: GraphicUserInterface( "ADD" )
   --> When Edit button is click: GraphicUserInterface( "EDIT" )
   --> Search: Show Search window
   --> Print: Dump to the contents of the database
   --> Close: Terminate the window
Sorry about the function name GraphicUserInterface(), I named it when I am still learning HMG way back in the year 2007. Since then I used that way and out of pure laziness became the monicker of this routine. LOL as you can see it is still the same old dinasour Clipper wearing the mask of HMG with BEGIN..BREAK..END SEQUENCE. The catch here is that VALIDATE the fields that requires on ON LOSTFOCUS events. When you need ON CHANGE you can still call CheckEventLostFocus( cMode ) but ON LOSTFOCUS must be like this: ON LOSTFOCUS NIL.
The main disadvantage of this is that users can only open one window at a time most especially if they are the same database. And on a case to case basis I comment out this statement on my source code and use SET MULTIPLE ON to let the users open more than one instance of the application. But if you do it this way your code must be fully written in a network environment scheme. Now, in the same sense, you can also test your network routines if your app can put record locks and or file locks effectively before deployment on the same computer without network.
**SET MULTIPLE OFF WARNING
SET MULTIPLE ON
static function GraphicUserInterface( cMode )
   local nebxLen := 0
   // Variable to properly display the record pointer position on the browse window //
   LOCAL nBrwCurRecPos := oTable:BrowseCurrentPos()
   // draw the form or the User Interface in memory //
   IF ISWINDOWDEFINED( frmGUI_1 )
      DOMETHOD("frmGUI_1","Restore")
      DOMETHOD("frmGUI_1","Setfocus")
   IF cDBMain == "EVENTS" .AND. LEN( aDbfFilter_ ) = 0
      MSGSTOP( 'Please set filter for a council that you wish to work with. To do this click on the button that says,"Select View".', "Record filter is required" )
   IF cMode == "ADD"
      DBGOBOTTOM()
      DBSKIP()
      IF .NOT. RecLock()
   lLostFocusEvents := FALSE     // reset lost focus events switch
   // draw Add/Edit windows in memory but not activated yet //
   DO CASE
      CASE cDBMain == "HOLIDAY"
         DEFINE WINDOW frmGUI_1;
            AT 0,0;
            WIDTH 409 HEIGHT 215;
            TITLE IF( cMode == "ADD","New Record Property","Record Property" );
            ICON ImageHome + "nsdla.ico";
            NOMINIMIZE NOMAXIMIZE NOSIZE;
            ON INTERACTIVECLOSE ( lLostFocusEvents := TRUE, ButtonClose( nBrwCurRecPos ) );
            FONT "Arial" SIZE 9
            ON KEY ESCAPE ACTION ( lLostFocusEvents := TRUE, ButtonClose( nBrwCurRecPos, TRUE ) )
            @ 140,170 BUTTON btnGUISave OF frmGUI_1 CAPTION "&Save";
               PICTURE ImageHome + "hp_save.bmp" LEFT ACTION ButtonSave( cMode, @nBrwCurRecPos );
               WIDTH  100 HEIGHT 28
            @ 140,280 BUTTON btnGUIClose OF frmGUI_1 CAPTION "&Close";
               PICTURE ImageHome + "exit20.bmp" LEFT;
               ACTION ButtonClose( nBrwCurRecPos, TRUE );
               WIDTH  100 HEIGHT 28
            @   8, 20 FRAME Frame_GUI OF frmGUI_1 CAPTION "Please fill-up the following information";
               WIDTH  360 HEIGHT 122 FONT "Arial" SIZE 9 BACKCOLOR NIL FONTCOLOR NIL OPAQUE
            @  33, 30 LABEL lblCode OF frmGUI_1 VALUE "&Code:";
               ACTION Nil WIDTH  70 HEIGHT 18 FONT "Arial" SIZE 9
            IF cMode == "ADD"
               @  30,120 TEXTBOX txbCode OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( HOLIDAY->F1 ) WIDTH  120;
                  FONT "Arial" SIZE 9 TOOLTIP "" MAXLENGTH 5;
                  ON LOSTFOCUS CheckEventLostFocus( cMode )
               @  30,120 TEXTBOX txbCode OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( HOLIDAY->F1 ) READONLY WIDTH  120;
            @  63, 30 LABEL lblDesc OF frmGUI_1 VALUE "&Description:";
            @  60,120 TEXTBOX txbDesc OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( HOLIDAY->F2 ) WIDTH  250;
               FONT "Arial" SIZE 9 TOOLTIP "" MAXLENGTH 40 ON LOSTFOCUS Nil;
               ON CHANGE GUISaveButtonEnable()
            @  93, 30 LABEL lblHolidayType OF frmGUI_1 VALUE "Holida&y Type";
            @  90,120 COMBOBOX cboHolidayType OF frmGUI_1 ITEMS acHolidayType_;
               VALUE IF( cMode == "ADD", 0, IF( ASCAN( acHolidayTypeCode_, HOLIDAY->F3 )  > 0,;
                        ASCAN( acHolidayTypeCode_, HOLIDAY->F3 ), 0 ) ) ;
               WIDTH  130 HEIGHT 80 FONT "Arial" SIZE 9 ON LOSTFOCUS CheckEventLostFocus()
      CASE cDBMain == "ROLES"
            AT 0,0;
            WIDTH 466 HEIGHT 254;
            FONT "Arial" SIZE 9
            @ 180,220 BUTTON btnGUISave OF frmGUI_1 CAPTION "&Save";
               WIDTH  100 HEIGHT 28
            @ 180,330 BUTTON btnGUIClose OF frmGUI_1 CAPTION "&Close";
               PICTURE ImageHome + "exit20.bmp" LEFT ACTION ButtonClose( nBrwCurRecPos, TRUE );
               WIDTH  100 HEIGHT 28
            @  20, 30 FRAME Frame_GUI OF frmGUI_1 CAPTION "Please fill-up the following information";
               WIDTH  400 HEIGHT 150 FONT "Arial" SIZE 9 BACKCOLOR NIL FONTCOLOR NIL OPAQUE
            @  43, 50 LABEL lblCode OF frmGUI_1 VALUE "Role &Code:";
            @  83, 50 LABEL lblDesc OF frmGUI_1 VALUE "&Description:";
            @ 123, 50 LABEL lblGenCat OF frmGUI_1 VALUE "&General Category:";
            IF cMode == "ADD"
               @  40,160 TEXTBOX txbCode OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( ROLES->F1 ) WIDTH  120;
                  FONT "Arial" SIZE 9 TOOLTIP "" MAXLENGTH 3 ON LOSTFOCUS CheckEventLostFocus( cMode )
               @  40,160 TEXTBOX txbCode OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( ROLES->F1 ) READONLY WIDTH  120;
            @  80,160 TEXTBOX txbDesc OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( ROLES->F2 ) WIDTH  250;
               FONT "Arial" SIZE 9 TOOLTIP "" MAXLENGTH 50 ON LOSTFOCUS Nil;
            @ 120,160 COMBOBOX cboGenCat OF frmGUI_1 ITEMS acRoles_ VALUE IIF( cMode == "ADD", 0, RoleGenCat( ROLES->F3 ) );
               WIDTH 120 HEIGHT 120 FONT "Arial" SIZE 9 ON CHANGE NIL
      CASE cDBMain == "BARRIO"
            AT 0,0;
            WIDTH 466 HEIGHT 289;
            FONT "Arial" SIZE 9
            @  20, 30 FRAME Frame_1 OF frmGUI_1 CAPTION NIL;
               WIDTH  400 HEIGHT 180 FONT "Arial" SIZE 9 BACKCOLOR NIL FONTCOLOR NIL OPAQUE
            @  43, 50 LABEL lblAreaCode OF frmGUI_1 VALUE "&Area Code :";
               ACTION frmGUI_1.txbAreaCode.Setfocus WIDTH  100 HEIGHT 18 FONT "Arial" SIZE 9
            IF cMode == "ADD"
               @  40,160 TEXTBOX txbAreaCode OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( BARRIO->F1 ) WIDTH  30;
                  FONT "Arial" SIZE 9 TOOLTIP "" MAXLENGTH 2 ON LOSTFOCUS CheckEventLostFocus( cMode )
               @  40,160 TEXTBOX txbAreaCode OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( BARRIO->F1 ) READONLY WIDTH  30;
                  FONT "Arial" SIZE 9 TOOLTIP "" MAXLENGTH 2 ON LOSTFOCUS NIL
            @  73, 50 LABEL lblAreaDesc OF frmGUI_1 VALUE "&Description";
               ACTION frmGUI_1.txbAreaDesc.Setfocus WIDTH  100 HEIGHT 18 FONT "Arial" SIZE 9
            @  70,160 TEXTBOX txbAreaDesc OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( BARRIO->F2 ) WIDTH  250;
               FONT "Arial" SIZE 9 TOOLTIP "" MAXLENGTH 50 ON LOSTFOCUS CheckEventLostFocus( cMode )
            @ 103,200 CHECKBOX chkZone OF frmGUI_1 ;
               CAPTION "&Zone &Required";
               WIDTH  100 HEIGHT 18 VALUE BARRIO->F6 ON CHANGE ZoneCBxChange()
            @ 103, 50 LABEL lblZoneCode OF frmGUI_1 VALUE "&Zone Code";
               ACTION frmGUI_1.txbZoneCode.Setfocus WIDTH  100 HEIGHT 18 FONT "Arial" SIZE 9
            IF cMode == "ADD"
               @ 100,160 TEXTBOX txbZoneCode OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( BARRIO->F3 ) WIDTH  30;
               @ 100,160 TEXTBOX txbZoneCode OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( BARRIO->F3 ) READONLY WIDTH  30;
                  FONT "Arial" SIZE 9 TOOLTIP "" MAXLENGTH 2 ON LOSTFOCUS Nil
            @ 133, 50 LABEL lblZoneDesc OF frmGUI_1 VALUE "Zo&ne Description";
               ACTION frmGUI_1.txbZoneDesc.Setfocus() WIDTH  100 HEIGHT 18 FONT "Arial" SIZE 9
            @ 130,160 TEXTBOX txbZoneDesc OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( BARRIO->F4 ) WIDTH  250;
            @ 163, 50 LABEL lblPPCZone OF frmGUI_1 VALUE "P&PC Zone Alias";
               ACTION frmGUI_1.txbPPCZone.Setfocus() WIDTH  100 HEIGHT 18 FONT "Arial" SIZE 9
            @ 160,160 TEXTBOX txbPPCZone OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( BARRIO->F5 ) WIDTH  250;
            @ 210,230 BUTTON btnGUISave OF frmGUI_1 CAPTION "&Save";
               WIDTH  100 HEIGHT 28
            @ 210,330 BUTTON btnGUIClose OF frmGUI_1 CAPTION "&Close";
               WIDTH  100 HEIGHT 28
      CASE cDBMain == "COUNCIL"
            AT 0,0;
            WIDTH 418 HEIGHT 445;
            FONT "Arial" SIZE 9
            @  20, 20 FRAME Frame_Council OF frmGUI_1 CAPTION "Pas&toral Councils";
               WIDTH  370 HEIGHT 150 FONT "Arial" SIZE 9 BACKCOLOR NIL FONTCOLOR NIL OPAQUE
            @  43, 40 LABEL lblParentCode OF frmGUI_1 VALUE "&Parent Code";
               ACTION frmGUI_1.txbParent.Setfocus() WIDTH  70 HEIGHT 18 FONT "Arial" SIZE 9
            @  73, 40 LABEL lblChildCode OF frmGUI_1 VALUE "&Child Code";
               ACTION frmGUI_1.txbChild.Setfocus() WIDTH  70 HEIGHT 18 FONT "Arial" SIZE 9
            @ 103, 40 LABEL lblDesc OF frmGUI_1 VALUE "&Description";
               ACTION frmGUI_1.txbDesc.Setfocus() WIDTH  70 HEIGHT 18 FONT "Arial" SIZE 9
            @ 133, 40 LABEL lblLevel OF frmGUI_1 VALUE "&Level";
               ACTION frmGUI_1.spnLevel.Setfocus() WIDTH  70 HEIGHT 18 FONT "Arial" SIZE 9
            IF cMode == "ADD"
               @  40,120 TEXTBOX txbParent OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( COUNCIL->F1 ) WIDTH  40;
               @  70,120 TEXTBOX txbChild OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( COUNCIL->F2 ) WIDTH  40;
               @  40,120 TEXTBOX txbParent OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( COUNCIL->F1 ) READONLY WIDTH  40;
                  FONT "Arial" SIZE 9 TOOLTIP "" MAXLENGTH 3 ON LOSTFOCUS NIL
               @  70,120 TEXTBOX txbChild OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( COUNCIL->F2 ) READONLY WIDTH  40;
            @ 100,120 TEXTBOX txbDesc OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( COUNCIL->F3 ) WIDTH  250;
            @ 130,120 SPINNER spnLevel OF frmGUI_1 RANGE 1,5;
               VALUE COUNCIL->F4 WIDTH  40 HEIGHT 24;
               FONT "Arial" SIZE 9 ON CHANGE Nil
            @ 133,170 CHECKBOX chkPerspective OF frmGUI_1 ;
               CAPTION "&Enable View" WIDTH  170 HEIGHT 18 VALUE .F. ON CHANGE CouncilPerspectiveChange()
            @ 220, 20 FRAME Frame_Perspective OF frmGUI_1 CAPTION "Report Perspective";
               WIDTH  370 HEIGHT 180 FONT "Arial" SIZE 9 BACKCOLOR NIL FONTCOLOR NIL OPAQUE
            @ 240, 30 EDITBOX ebxPerspective OF frmGUI_1 WIDTH  350 HEIGHT 150;
               VALUE "" READONLY FONT "Consolas" SIZE 10 TOOLTIP "" NOTABSTOP
            @ 180,180 BUTTON btnGUISave OF frmGUI_1 CAPTION "&Save";
               WIDTH  100 HEIGHT 28
            @ 180,290 BUTTON btnGUIClose OF frmGUI_1 CAPTION "&Close";
               WIDTH  100 HEIGHT 28
      CASE cDBMain == "EVENTS"
            AT 0,0;
            WIDTH 428 HEIGHT 323;
            TITLE IF( cMode == "ADD","New Record Property","Event Property" );
            ON RELEASE ( lLostFocusEvents := TRUE, ButtonClose( nBrwCurRecPos ) );
            FONT "Arial" SIZE 9
            @  20, 20 FRAME Frame_Events OF frmGUI_1 CAPTION NIL;
               WIDTH  380 HEIGHT 210 FONT "Arial" SIZE 9 BACKCOLOR Nil FONTCOLOR Nil OPAQUE
            @  34, 40 LABEL lblEventCode OF frmGUI_1 VALUE "Event Co&de:";
               ACTION frmGUI_1.txbEventCode.Setfocus() WIDTH  80 HEIGHT 14 FONT "Arial" SIZE 9
            @  74, 40 LABEL lblEventName OF frmGUI_1 VALUE "Event Na&me:";
               ACTION frmGUI_1.txtEventName.Setfocus() WIDTH  80 HEIGHT 14 FONT "Arial" SIZE 9
            @ 114, 40 LABEL lblParentClass OF frmGUI_1 VALUE "Pare&nt Class:";
               ACTION frmGUI_1.txbParent.Setfocus() WIDTH  80 HEIGHT 14 FONT "Arial" SIZE 9
            @ 154, 40 LABEL lblChildClass OF frmGUI_1 VALUE "C&hild Class:";
               ACTION frmGUI_1.txbChild.Setfocus() WIDTH  80 HEIGHT 14 FONT "Arial" SIZE 9
            @ 194, 40 LABEL lblCouncilName OF frmGUI_1 VALUE "Desc&ription:";
               ACTION frmGUI_1.txbDesc.Setfocus() WIDTH  80 HEIGHT 14 FONT "Arial" SIZE 9
            @  30,130 TEXTBOX txbEventCode OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( EVENTS->F1 ) READONLY WIDTH  120;
               FONT "Arial" SIZE 9 TOOLTIP "" MAXLENGTH 10 ON LOSTFOCUS CheckEventLostFocus( cMode )
            @  70,130 TEXTBOX txtEventName OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( EVENTS->F2 ) WIDTH  250;
            @ 110,130 TEXTBOX txbParent OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( EVENTS->F3 ) READONLY WIDTH  40;
               FONT "Arial" SIZE 9 TOOLTIP "" MAXLENGTH 3 ON LOSTFOCUS Nil NOTABSTOP
            @ 150,130 TEXTBOX txbChild OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( EVENTS->F4 ) READONLY WIDTH  40;
            @ 190,130 TEXTBOX txbDesc OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( EVENTS->F5 ) READONLY WIDTH  250;
               FONT "Arial" SIZE 9 TOOLTIP "" MAXLENGTH 50 ON LOSTFOCUS Nil NOTABSTOP
            @ 240,200 BUTTON btnGUISave OF frmGUI_1 CAPTION "&Save";
               WIDTH  100 HEIGHT 28
            @ 240,300 BUTTON btnGUIClose OF frmGUI_1 CAPTION "&Close";
               WIDTH  100 HEIGHT 28
      CASE cDBMain == "FEAST"
            AT 0,0;
            WIDTH 470 HEIGHT 453;
            NOMAXIMIZE;
            FONT "Arial" SIZE 9
            @  30, 30 FRAME Frame_Feast OF frmGUI_1 CAPTION NIL;
               WIDTH  400 HEIGHT 130 FONT "Arial" SIZE 9 BACKCOLOR Nil FONTCOLOR Nil OPAQUE
            @ 170, 30 FRAME Frame_ebxRemarks OF frmGUI_1 CAPTION "Remarks ( 300 Characters Only: Used: 0 Left : 300)";
               WIDTH  400 HEIGHT 180 FONT "Arial" SIZE 9 BACKCOLOR Nil FONTCOLOR Nil OPAQUE
            @  44, 50 LABEL lblFeastCode OF frmGUI_1 VALUE "&Feast Code:";
               ACTION frmGUI_1.txbFeastCode.Setfocus() WIDTH  85 HEIGHT 18 FONT "Arial" SIZE 9
            @  40,160 TEXTBOX txbFeastCode OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( FEAST->F1 ) READONLY WIDTH  120;
               FONT "Arial" SIZE 9 TOOLTIP "" MAXLENGTH 10 ON LOSTFOCUS Nil
            @  83, 50 LABEL lblFeastName OF frmGUI_1 VALUE "&Description:";
               ACTION frmGUI_1.txbFeastDesc.Setfocus() WIDTH  85 HEIGHT 24 FONT "Arial" SIZE 9
            @  80,160 TEXTBOX txbFeastDesc OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( FEAST->F2 ) WIDTH  250;
            @ 123, 50 LABEL lblMonthDay OF frmGUI_1 VALUE "&Month and Day:";
               ACTION Nil WIDTH  85 HEIGHT 24 FONT "Arial" SIZE 9
            @ 120,160 TEXTBOX txbMonthDay OF frmGUI_1 HEIGHT 24 VALUE ALLTRIM( FEAST->F3 ) WIDTH  50;
               FONT "Arial" SIZE 9 TOOLTIP "" MAXLENGTH 5 ON LOSTFOCUS CheckEventLostFocus( cMode )
            @ 188, 37 EDITBOX ebxRemarks OF frmGUI_1 WIDTH  385 HEIGHT 155;
               FIELD FEAST->F6 FONT "Arial" SIZE 9 TOOLTIP "" MAXLENGTH 300;
               ON CHANGE frmGUI_1.Frame_ebxRemarks.Caption := "300 Characters (Used: " + ;
               ALLTRIM( STR( LEN( ALLTRIM( This.Value ) ) ) )+ " Remaining: " +;
               ALLTRIM( STR( ( 300 - LEN( ALLTRIM( This.Value ) ) ) ) ) + ")" NOHSCROLL
            @ 360,220 BUTTON btnGUISave OF frmGUI_1 CAPTION "&Save";
               WIDTH  100 HEIGHT 28
            @ 360,330 BUTTON btnGUIClose OF frmGUI_1 CAPTION "&Close";
               WIDTH  100 HEIGHT 28
   ENDCASE
   frmGUI_1.btnGUISave.Enabled := FALSE
   frmGUI_1.Center
   ** setup form controls, disable primary keys and put the control focus **
   ** to initial form controls depending on the table in use.             **
   IF cMode == "ADD"
      DO CASE
            frmGUI_1.txbCode.Setfocus
            frmGUI_1.txbAreaCode.Setfocus()
            frmGUI_1.chkPerspective.Value := FALSE
            frmGUI_1.txbFeastCode.Value := NewFeastCode()
      ENDCASE
   ELSEIF cMode == "EDIT"
      DO CASE
            frmGUI_1.txbAreaDesc.Setfocus()
            frmGUI_1.chkPerspective.Value := TRUE
            nebxLen := LEN( ALLTRIM( frmGUI_1.ebxRemarks.Value ) )
            frmGUI_1.Frame_ebxRemarks.Caption := "300 Characters (Used: " +;
               ALLTRIM( STR( nebxLen ) ) + " Remaining: " + ALLTRIM( STR( ( 300 - nebxLen ) ) ) + ")"
            IF SUBSTR( FEAST->F1, 1, 3 ) == "SYS"
               frmGUI_1.txbFeastDesc.Enabled := FALSE
               frmGUI_1.txbFeastCode.Enabled := FALSE
               frmGUI_1.txbMonthDay.Enabled := FALSE
               frmGUI_1.ebxRemarks.Enabled := FALSE
      ENDCASE
   ENDIF cMode == "ADD"
   frmGUI_1.Activate
static function CheckEventLostFocus( cMode )
   LOCAL cControlName := UPPER( ALLTRIM( This.Name ) )
   IF lLostfocusEvents
      lLostfocusEvents := TRUE
      IF( VALIDATION( UPPER( cControlName ), cMode ), NIL, This.Setfocus )
      lLostfocusEvents := FALSE
static function Validation( cObjName, cMode )
   LOCAL cOrigOrder  := ""
   LOCAL cIndex      := ""
   LOCAL lResetOrder := FALSE
   LOCAL lRetVal := FALSE
   LOCAL nCurPos := RECNO()
   LOCAL TVar1 := ""
   LOCAL cSearchKey := ""
   PRIVATE cScope
   BEGIN SEQUENCE
   DO CASE
         DO CASE
            CASE cObjName == "TXBCODE"
               IF cMode == "EDIT"; lRetVal := TRUE; BREAK; ENDIF
               IF EMPTY( frmGUI_1.txbCode.Value )
                  MSGINFO("This is a required field, please fill-up the information","Input Mandatory")
                  BREAK
               cSearchKey := frmGUI_1.txbCode.Value
               IF Duplication( cSearchKey )
                  BREAK
            CASE cObjName == "CBOHOLIDAYTYPE"
               IF frmGUI_1.cboHolidayType.Value = 0
                  MSGINFO( "Please select holiday type", "Selection is Mandatory")
                  BREAK
         ENDCASE
         DO CASE
               cIndex := dbRoles
               lResetOrder := TRUE
               IF cMode == "ADD"
                  frmGUI_1.txbCode.Value := NewDBRoleCode()
               DBSELECTAREA( "ROLES" )
               cOrigOrder := ORDSETFOCUS( "Code", ( dbRoles ) )
                  BREAK
         ENDCASE
         DO CASE
            CASE cObjName == "TXBAREACODE"
               cIndex := dbBarrio
               lResetOrder := TRUE
               IF cMode == "ADD" .AND. EMPTY( frmGUI_1.txbAreaCode.Value )
                  frmGUI_1.txbAreaCode.Value := NewBgyCode()
                  IF frmGUI_1.chkZone.Value = FALSE
                     frmGUI_1.txbZoneCode.Value := "00"
                     frmGUI_1.txbZoneCode.Value := NewBgyZoneCode( frmGUI_1.txbAreaCode.Value )
               cSearchKey := ALLTRIM( frmGUI_1.txbAreaCode.Value ) + ALLTRIM( frmGUI_1.txbZoneCode.Value )
               DBSELECTAREA( "BARRIO" )
               cOrigOrder := ORDSETFOCUS( "Zones", ( dbBarrio ) )
                  IF MsgYesNo( "Are you going to input Zone information?","Duplicate Code over ride" ) = TRUE
                     lREtVal := TRUE
                     frmGUI_1.chkZone.Value := TRUE
                  BREAK
            CASE cObjName == "TXBZONECODE"
               cIndex := dbBarrio
               lResetOrder := TRUE
               IF cMode == "ADD"
                  IF frmGUI_1.chkZone.Value = TRUE
                     IF ALLTRIM( frmGUI_1.txbZoneCode.Value ) == "00"
                  BREAK
            CASE cObjName == "TXBAREADESC"
               IF EMPTY( frmGUI_1.txbAreaDesc.Value )
                  MSGSTOP( "Please fill-in with Baranggay or Barrio Name.", "Input mandatory" )
                  BREAK
               TVar1 := "SPPC - " + ALLTRIM( frmGUI_1.txbAreaDesc.Value )
               frmGUI_1.txbPPCZone.Value := TVar1
            CASE cObjName == "TXBZONEDESC"
               IF EMPTY( frmGUI_1.txbZoneDesc.Value )
                  MSGSTOP( "Please fill-in with Zone Name (Pangalan ng Purok)", "Input mandatory" )
                  BREAK
               TVar1 += " (" + ALLTRIM( frmGUI_1.txbZoneDesc.Value ) + ")"
         ENDCASE
         DO CASE
            CASE cObjName == "TXBPARENT"
               cIndex := dbBarrio
               lResetOrder := TRUE
               IF cMode == "ADD" .AND. EMPTY( frmGUI_1.txbParent.Value )
                  frmGUI_1.txbParent.Value := NewCouncilParent()
                  frmGUI_1.txbChild.Value  := "000"
               cSearchKey := ALLTRIM( frmGUI_1.txbParent.Value ) + ALLTRIM( frmGUI_1.txbChild.Value )
               DBSELECTAREA( "COUNCIL" )
               cOrigOrder := ORDSETFOCUS( "ParentChild", ( dbCouncil ) )
               DBSEEK( cSearchKey )
               IF FOUND()
                  IF MsgYesNo( "Are you going to make an entry for Ministry or an Organization?","Duplicate Code" ) = TRUE
                     lRetVal := TRUE
                  BREAK
            CASE cObjName == "TXBCHILD"
               cIndex := dbCouncil
               lResetOrder := TRUE
               IF cMode == "ADD"
                  IF !ALLTRIM( frmGUI_1.txbChild.Value ) == "000"
                     frmGUI_1.txbChild.Value := NewCouncilChild( frmGUI_1.txbParent.Value )
                  BREAK
            CASE cObjName == "TXBDESC"
               IF EMPTY( frmGUI_1.txbDesc.Value )
                  MSGSTOP( "Please fill-in the required name or information.", "Input mandatory" )
                  BREAK
         ENDCASE
         DO CASE
            CASE cObjName == "TXBEVENTCODE"
               IF cMode == "ADD"
                  IF EMPTY( frmGUI_1.txbEventCode.Value )
                     frmGUI_1.txbEventCode.Value := CodeGenerator( "EN" )
                  cScope := aDbfFilter_[ 1 ] + aDbfFilter_[ 2 ]
                  nCurPos := EVENTS->( RECNO() )
                  DBSELECTAREA( "EVENTS" )
                  ORDSCOPE( 0, NIL )
                  ORDSCOPE( 1, NIL )
                  IndexManager( "EVENTS", "EventCode", dbEvents )
                  IF DUPLICATION( frmGUI_1.txbEventCode.Value )
                     IndexManager( "EVENTS", "ClassDesc", dbEvents )
                     ORDSCOPE( 0, "&cScope" )
                     ORDSCOPE( 1, "&cScope" )
                     DBGOTOP()
                     DBGOTO( nCurPos )
                     MSGSTOP( "Please check the computer's clock and set it to correct time. If error persist replace the CMOS battery.", "Duplication is not allowed" )
                     BREAK
                  DBGOTOP()
                  DBGOTO( nCurPos )
                  frmGUI_1.txbParent.Value := aDbfFilter_[ 1 ]
                  frmGUI_1.txbChild.Value := aDbfFilter_[ 2 ]
                  frmGUI_1.txbDesc.Value := aDbfFilter_[ 3 ]
            CASE cObjName == "TXTEVENTNAME"
               IF EMPTY( frmGUI_1.txtEventName.Value )
                  MSGSTOP( "Please fill-in the information required.", "Input mandatory" )
                  BREAK
         ENDCASE
         DO CASE
            CASE cObjName == "TXBFEASTDESC"
               IF EMPTY( frmGUI_1.txbFeastDesc.Value )
                  BREAK
            CASE cObjName == "TXBMONTHDAY"
               IF EMPTY( frmGUI_1.txbMonthDay.Value )
                  BREAK
         ENDCASE
   ENDCASE
   lRetVal := TRUE
   END SEQUENCE
   DBSELECTAREA( (oTable:cMainAlias ) )
   IF lResetOrder
      ORDSETFOCUS( ( cOrigOrder ), ( cIndex ) )
   DBGOTO( nCurPos )
   RETURN lREtVal
static function GUISaveButtonEnable()
   frmGUI_1.btnGUISave.Enabled := TRUE
GUISaveButtonEnable() - enables the "Save" button after a successful validation during "EDIT" mode otherwise changes it will remain disable. That ensures users will click either the Close or exit button or the windows close box itself (INTERACTIVECLOSE).
To Moderators: I'm sorry its a long post but perhaps it can be considered.
Danny
Danny
Manila, Philippines
Hi Danny
dhaine_adp wrote:Here is a multiple flat table and multiple windows validation routine written in clipper logic and was adopted to HMG (windows). Its a code snippet but if you read the code carefully you'll find that it is more like a clipper code roughly equivalent to:...
Thank to share you code :)
Not a SSW, but an useful and interesting reading to compare and denote differences between text and GUI programming :arrow:
Viva HMG :D
Hi Danny
Nice Code to learn like me
manoj_duamzn
Post by manoj_duamzn »
Thank you gfilatov
Your suggesion worked perfectly
