HMG Case
dragancesu
DBs Used: DBF, MySQL, Oracle
HMG Case
Post by dragancesu »
I finally made ​​a brief guide to the program that I want to introduce myself and that I think will help someone
Enclosed you have a program, demo data, the icon for the program and the examples mentioned in the text
Not everything is as polished as it should expect criticism and suggestions, first how to fix the generated code
This I did for myself, and see if you can use like
data.zip
(1.93 KiB) Downloaded 657 times
program.zip
(1.05 MiB) Downloaded 726 times
dragancesu
Re: HMG Case
Just another attachment
SAMPLES.ZIP
(5.92 KiB) Downloaded 682 times
picture.zip
(15.5 KiB) Downloaded 663 times
dragancesu
Re: HMG Case
Just manual
manual.zip
(58.97 KiB) Downloaded 657 times
Re: HMG Case
Thank you for sharing
Re: HMG Case
dragancesu wrote:I finally made ​​a brief guide to the program that I want to introduce myself and that I think will help someone
Not everything is as polished as it should expect criticism and suggestions, prvko how to fix the generated code
Hi Dragan
FYI : Here we are share our source code and data files ( as you made ) and don't send executable files, and moreover don't run .exes came from internet in general.
Re: HMG Case
esgici wrote: FYI : Here we are share our source code and data files ( as you made ) and don't send executable files, and moreover don't run .exes came from internet in general.
I agree with Esgici, HMG is OpenSource & All post should be in .prg and not in .exe
Re: HMG Case
Hey do not be afraid to share your effort, many colleagues have mountains alongside our sand castles.
Re: HMG Case
Hi Dragan,
It is very interesting tool 8-)
I've made the small corrections and suggestions in the generated code as below:
MEMVAR New_rec, _qry_exp
PROCEDURE MAIN // for test, usually edit_EMPLOYE
   PUBLIC New_rec:= .F. , _qry_exp := ""
   SET PROCEDURE TO Use_dbf.prg  // for test
   SET NAVIGATION EXTENDED
   SET CENTURY ON
   SET DATE GERMAN
   SET DELETED ON
   Use_employe()  // from use_dbf.prg
   DEFINE WINDOW Win_1 ;
      WIDTH 800 ;
      HEIGHT 700 ;
      TITLE "Table EMPLOYE" ;
      ICON "EMPLOYE.ICO" ;
      MAIN  // for test, usually MODAL
      ON KEY ESCAPE ACTION Win_1.Release
      DEFINE STATUSBAR FONT "Arial" SIZE 12
         STATUSITEM "Table EMPLOYE"
         KEYBOARD WIDTH 90
         DATE WIDTH 100
         CLOCK WIDTH 80
      END STATUSBAR
      DEFINE TOOLBAR ToolBar_1 BUTTONSIZE 60,40 IMAGESIZE 32,32 FLAT BORDER
      BUTTON FIRST_EMPL ;
         CAPTION "&First" ;
         PICTURE "go_first.bmp" ;
         ACTION( dbGotop(), Win_1.Browse_1.Value := RecNo() )
      BUTTON PREV_EMPL ;
         CAPTION "&Prev" ;
         PICTURE "go_prev.bmp" ;
         ACTION( dbSkip( -1 ), Win_1.Browse_1.Value := RecNo() )
      BUTTON NEXT_EMPL ;
         CAPTION "&Next" ;
         PICTURE "go_next.bmp" ;
         ACTION( dbSkip(), if ( Eof(), dbGobottom(), Nil ), Win_1.Browse_1.Value := RecNo() )
      BUTTON LAST_EMPL ;
         CAPTION "&Last" ;
         PICTURE "go_last.bmp" ;
         ACTION( dbGoBottom(), Win_1.Browse_1.Value := RecNo() )   SEPARATOR
      BUTTON FIND_EMPL ;
         CAPTION "F&ind" ;
         PICTURE "edit_find.bmp" ;
         ACTION Find_EMPL()
      BUTTON NEW_EMPL ;
         CAPTION "&New" ;
         PICTURE "edit_new.bmp" ;
         ACTION ( New_rec := .T., NewRecord_EMPL() )
      BUTTON EDIT_EMPL ;
         CAPTION "&Edit" ;
         PICTURE "edit_edit.bmp" ;
         ACTION iif ( RecordStatus_EMPL(), EnableField_EMPL(), Nil )
      BUTTON DELETE_EMPL ;
         CAPTION "&Delete" ;
         PICTURE "edit_delete.bmp" ;
         ACTION iif ( RecordStatus_EMPL(), DeleteRecord_EMPL(), Nil )
      BUTTON PRINT_EMPL ;
         CAPTION "P&rint" ;
         PICTURE "edit_print.bmp" ;
         ACTION PrintData_EMPL()
      BUTTON EXIT_EMPL ;
         CAPTION "E&xit" ;
         PICTURE "edit_close.bmp" ;
      END TOOLBAR
      PaintDisplay_EMPL()
      @ 90,10 BROWSE Browse_1 ;
         WIDTH 350 ;
         HEIGHT 450 ;
         FONT "Arial" ;
         SIZE 11 ;
         HEADERS { "CLI_ID","CLI_SNAM","CLI_NAME","CLI_TLF","CLI_DAYS","CLI_WAGE","CLI_BDATE","CLI_HDATE","CLI_SALARY","CLI_CITY" } ;
         WIDTHS { 70,130,130,120,90,90,110,110,110,110 } ;
         WORKAREA EMPLOYE ;
         FIELDS { "CLI_ID","CLI_SNAM","CLI_NAME","CLI_TLF","CLI_DAYS","CLI_WAGE","CLI_BDATE","CLI_HDATE","CLI_SALARY","CLI_CITY" } ;
         JUSTIFY { BROWSE_JTFY_RIGHT, ,,, BROWSE_JTFY_RIGHT, BROWSE_JTFY_RIGHT, ,, BROWSE_JTFY_RIGHT, } ;
         ON CHANGE LoadData_EMPL() ;
         ON HEADCLICK { {|| Head1_EMPL()}, ,,,,,,,, {|| Head10_EMPL()} } ;
         ON DBLCLICK ( EnableField_EMPL(), iif ( ! RecordStatus_EMPL(), DisableField_EMPL(), Nil ) )
      @ 580, 50 BUTTON SAVE_EMPL ;
         CAPTION "&Save" ;
         PICTURE "ok.bmp" ;
         ACTION SaveRecord_EMPL() ;
         RIGHT ;
         WIDTH 100 ;
         HEIGHT 40
      @ 580,150 BUTTON CANCEL_EMPL ;
         CAPTION "&Cancel" ;
         PICTURE "cancel.bmp" ;
         ACTION CancelEdit_EMPL() ;
         RIGHT ;
         WIDTH 100 ;
         HEIGHT 40
      @ 580,300 BUTTON QUERY_EMPL ;
         CAPTION "&Query" ;
         ACTION QueryRecord_EMPL() ;
         RIGHT ;
         WIDTH 100 ;
         HEIGHT 40
   DisableField_EMPL()
   Win_1.Browse_1.Value := EMPLOYE->( RecNo() )
   LoadData_EMPL()
   Win_1.Browse_1.SetFocus
   CENTER WINDOW Win_1
   ACTIVATE WINDOW Win_1
PROCEDURE DisableField_EMPL
   Win_1.Browse_1.Enabled     := .T.
   Win_1.Control_1.Enabled    := .F.
   Win_1.Control_2.Enabled    := .F.
   Win_1.Control_3.Enabled    := .F.
   Win_1.Control_4.Enabled    := .F.
   Win_1.Control_5.Enabled    := .F.
   Win_1.Control_6.Enabled    := .F.
   Win_1.Control_7.Enabled    := .F.
   Win_1.Control_8.Enabled    := .F.
   Win_1.Control_9.Enabled    := .F.
   Win_1.Control_10.Enabled   := .F.
   Win_1.Save_EMPL.Enabled    := .F.
   Win_1.Cancel_EMPL.Enabled  := .F.
   Win_1.Query_EMPL.Enabled   := .F.
   EnableToolbar_EMPL()
PROCEDURE EnableField_EMPL
   Win_1.Browse_1.Enabled     := .F.
   Win_1.Control_1.Enabled    := .T.
   Win_1.Control_2.Enabled    := .T.
   Win_1.Control_3.Enabled    := .T.
   Win_1.Control_4.Enabled    := .T.
   Win_1.Control_5.Enabled    := .T.
   Win_1.Control_6.Enabled    := .T.
   Win_1.Control_7.Enabled    := .T.
   Win_1.Control_8.Enabled    := .T.
   Win_1.Control_9.Enabled    := .T.
   Win_1.Control_10.Enabled   := .T.
   Win_1.Save_EMPL.Enabled    := .T.
   Win_1.Cancel_EMPL.Enabled  := .T.
   DisableToolbar_EMPL()
   Win_1.Control_2.SetFocus
PROCEDURE DisableToolbar_EMPL
   Win_1.Toolbar_1.FIRST_EMPL.Enabled  := .F.
   Win_1.Toolbar_1.PREV_EMPL.Enabled   := .F.
   Win_1.Toolbar_1.NEXT_EMPL.Enabled   := .F.
   Win_1.Toolbar_1.LAST_EMPL.Enabled   := .F.
   Win_1.Toolbar_1.FIND_EMPL.Enabled   := .F.
   Win_1.Toolbar_1.NEW_EMPL.Enabled    := .F.
   Win_1.Toolbar_1.EDIT_EMPL.Enabled   := .F.
   Win_1.Toolbar_1.DELETE_EMPL.Enabled := .F.
   Win_1.Toolbar_1.PRINT_EMPL.Enabled  := .F.
   Win_1.Toolbar_1.EXIT_EMPL.Enabled   := .F.
PROCEDURE EnableToolbar_EMPL
   Win_1.Toolbar_1.FIRST_EMPL.Enabled  := .T.
   Win_1.Toolbar_1.PREV_EMPL.Enabled   := .T.
   Win_1.Toolbar_1.NEXT_EMPL.Enabled   := .T.
   Win_1.Toolbar_1.LAST_EMPL.Enabled   := .T.
   Win_1.Toolbar_1.FIND_EMPL.Enabled   := .T.
   Win_1.Toolbar_1.NEW_EMPL.Enabled    := .T.
   Win_1.Toolbar_1.EDIT_EMPL.Enabled   := .T.
   Win_1.Toolbar_1.DELETE_EMPL.Enabled := .T.
   Win_1.Toolbar_1.PRINT_EMPL.Enabled  := .T.
   Win_1.Toolbar_1.EXIT_EMPL.Enabled   := .T.
FUNCTION RecordStatus_EMPL()
   Local RetVal
   EMPLOYE->( dbGoTo ( Win_1.Browse_1.Value ) )
   IF EMPLOYE->(RLock())
      RetVal := .T.
      MsgExclamation ("Record is LOCKED, try again later")
      RetVal := .F.
RETURN RetVal
PROCEDURE LoadData_EMPL
   Win_1.Control_1.Value    := EMPLOYE->CLI_ID
   Win_1.Control_2.Value    := EMPLOYE->CLI_SNAM
   Win_1.Control_3.Value    := EMPLOYE->CLI_NAME
   Win_1.Control_4.Value    := EMPLOYE->CLI_TLF
   Win_1.Control_5.Value    := EMPLOYE->CLI_DAYS
   Win_1.Control_6.Value    := EMPLOYE->CLI_WAGE
   Win_1.Control_7.Value    := EMPLOYE->CLI_BDATE
   Win_1.Control_8.Value    := EMPLOYE->CLI_HDATE
   Win_1.Control_9.Value    := EMPLOYE->CLI_SALARY
   Win_1.Control_10.Value   := EMPLOYE->CLI_CITY
PROCEDURE CancelEdit_EMPL
   DisableField_EMPL()
   LoadData_EMPL()
   UNLOCK
   New_rec := .F.
PROCEDURE SaveRecord_EMPL
   Local NewRecNo
   DisableField_EMPL()
   IF New_rec == .T.
      EMPLOYE->( dbAppend() )
      New_rec := .F.
      EMPLOYE->( dbGoto ( Win_1.Browse_1.Value ) )
   NewRecNo := EMPLOYE->( RecNo() )
   EMPLOYE->CLI_ID     := Win_1.Control_1.Value
   EMPLOYE->CLI_SNAM   := Win_1.Control_2.Value
   EMPLOYE->CLI_NAME   := Win_1.Control_3.Value
   EMPLOYE->CLI_TLF    := Win_1.Control_4.Value
   EMPLOYE->CLI_DAYS   := Win_1.Control_5.Value
   EMPLOYE->CLI_WAGE   := Win_1.Control_6.Value
   EMPLOYE->CLI_BDATE  := Win_1.Control_7.Value
   EMPLOYE->CLI_HDATE  := Win_1.Control_8.Value
   EMPLOYE->CLI_SALARY := Win_1.Control_9.Value
   EMPLOYE->CLI_CITY   := Win_1.Control_10.Value
   dbCommit()
   UNLOCK
   Win_1.Browse_1.Value := NewRecNo
   Win_1.Browse_1.Refresh
   Win_1.StatusBar.Item(1) := "Save Record"
PROCEDURE NewRecord_EMPL
   Win_1.StatusBar.Item(1) := "Editing"
   SET ORDER TO 1
   dbGoBottom()
   Win_1.Control_1.Value   := EMPLOYE->CLI_ID + 1
   Win_1.Control_2.Value   := space(12)
   Win_1.Control_3.Value   := space(12)
   Win_1.Control_4.Value   := space(11)
   Win_1.Control_5.Value   := 0
   Win_1.Control_6.Value   := 0
   Win_1.Control_7.Value   := date()
   Win_1.Control_8.Value   := date()
   Win_1.Control_9.Value   := 0
   Win_1.Control_10.Value  := space(10)
   EnableField_EMPL()
PROCEDURE DeleteRecord_EMPL
   IF MsgYesNo ( "Are you sure you want to delete record?", "Confirmation" )
      DELETE
      dbSkip()
      IF EMPLOYE->(Eof())
         dbGoBottom()
   UNLOCK
PROCEDURE Find_EMPL
   Win_1.StatusBar.Item(1) := "Query"
   Win_1.Control_1.Value   := 0
   Win_1.Control_7.Value   := ctod('')
   Win_1.Control_8.Value   := ctod('')
   EnableField_EMPL()
   Win_1.Query_EMPL.Enabled := .T.
   Win_1.Control_1.SetFocus
PROCEDURE PrintData_EMPL
   Local RecRec
   RecRec := EMPLOYE->( RecNo() )
   dbGoTop()
   DO REPORT ;
      TITLE "EMPLOYE" ;
      HEADERS { "","","","","","","","","","" }, { "CLI_ID","CLI_SNAM","CLI_NAME","CLI_TLF","CLI_DAYS","CLI_WAGE","CLI_BDATE","CLI_HDATE","CLI_SALARY","CLI_CITY" } ;
      WIDTHS { 7,13,13,12,9,9,11,11,11,11 } ;
      TOTALS { .F.,.F.,.F.,.F.,.F.,.F.,.F.,.F.,.T.,.F. } ;
      NFORMATS { '','','','','','999.99','','',"99,999.99",'' } ;
      WORKAREA EMPLOYE ;
      LPP 50 ;
      CPL 80 ;
      LMARGIN 10 ;
      PREVIEW
   EMPLOYE->( dbGoTo(RecRec) )
PROCEDURE PaintDisplay_EMPL
   @  90,410 FRAME Frame_1 WIDTH 300 HEIGHT 450
   @ 100, 420 LABEL Label_1 VALUE "CLI_ID"
   @ 130, 420 LABEL Label_2 VALUE "CLI_SNAM"
   @ 160, 420 LABEL Label_3 VALUE "CLI_NAME"
   @ 190, 420 LABEL Label_4 VALUE "CLI_TLF"
   @ 220, 420 LABEL Label_5 VALUE "CLI_DAYS"
   @ 250, 420 LABEL Label_6 VALUE "CLI_WAGE"
   @ 280, 420 LABEL Label_7 VALUE "CLI_BDATE"
   @ 310, 420 LABEL Label_8 VALUE "CLI_HDATE"
   @ 340, 420 LABEL Label_9 VALUE "CLI_SALARY"
   @ 370, 420 LABEL Label_10 VALUE "CLI_CITY"
   @ 100, 520 TEXTBOX  Control_1 NUMERIC INPUTMASK "99999"
   @ 130, 520 TEXTBOX  Control_2         INPUTMASK repl("A",12)
   @ 160, 520 TEXTBOX  Control_3         INPUTMASK repl("A",12)
   @ 190, 520 TEXTBOX  Control_4         INPUTMASK repl("A",11)
   @ 220, 520 TEXTBOX  Control_5 NUMERIC INPUTMASK "99"
   @ 250, 520 TEXTBOX  Control_6 NUMERIC INPUTMASK "9.99"
   @ 280, 520 TEXTBOX  Control_7 DATE
   @ 310, 520 TEXTBOX  Control_8 DATE
   @ 340, 520 TEXTBOX  Control_9 NUMERIC INPUTMASK "99999.99"
   @ 370, 520 TEXTBOX  Control_10         INPUTMASK repl("A",10)
PROCEDURE Head1_EMPL
   SELECT EMPLOYE
   SET ORDER TO 1
   dbGotop()
   LoadData_EMPL()
PROCEDURE Head10_EMPL
   SELECT EMPLOYE
   SET ORDER TO 2
   dbGotop()
   LoadData_EMPL()
PROCEDURE QueryRecord_EMPL
   Local found_rec
   PreQuery_EMPL()
   SET FILTER TO
   dbGotop()
   IF ! EMPTY( _qry_exp )
      COUNT TO found_rec FOR &_qry_exp
      dbGotop()
      IF found_rec = 0
         Win_1.Statusbar.Item(1) := "Not found!"
         SET FILTER TO &_qry_exp
         dbGotop()
         Win_1.Statusbar.Item(1) := "Found " + ALLTRIM(STR(found_rec)) + " record(s)!"
   DisableField_EMPL()
PROCEDURE PreQuery_EMPL
   Local _ima_filter
_qry_exp := ""
_ima_filter := .F.
IF ! EMPTY ( Win_1.Control_1.Value )     // CLI_ID
   IF _ima_filter
      _qry_exp = _qry_exp + " .AND. "
      _qry_exp = _qry_exp + "CLI_ID = " + STR( Win_1.Control_1.Value )
      _ima_filter := .T.
IF ! EMPTY ( Win_1.Control_2.Value )     // CLI_SNAM
   IF _ima_filter
      _qry_exp = _qry_exp + "CLI_SNAM = " + chr(34) + Win_1.Control_2.Value + chr(34)
      _ima_filter := .T.
IF ! EMPTY ( Win_1.Control_3.Value )     // CLI_NAME
   IF _ima_filter
      _qry_exp = _qry_exp + "CLI_NAME = " + chr(34) + Win_1.Control_3.Value + chr(34)
      _ima_filter := .T.
IF ! EMPTY ( Win_1.Control_4.Value )     // CLI_TLF
   IF _ima_filter
      _qry_exp = _qry_exp + "CLI_TLF = " + chr(34) + Win_1.Control_4.Value + chr(34)
      _ima_filter := .T.
IF ! EMPTY ( Win_1.Control_5.Value )     // CLI_DAYS
   IF _ima_filter
      _qry_exp = _qry_exp + "CLI_DAYS = " + STR( Win_1.Control_5.Value )
      _ima_filter := .T.
IF ! EMPTY ( Win_1.Control_6.Value )     // CLI_WAGE
   IF _ima_filter
      _qry_exp = _qry_exp + "CLI_WAGE = " + STR( Win_1.Control_6.Value )
      _ima_filter := .T.
IF ! EMPTY ( Win_1.Control_7.Value )     // CLI_BDATE
   IF _ima_filter
      _qry_exp = _qry_exp + "CLI_BDATE = " + "CTOD(" + chr(34) + DTOC(Win_1.Control_7.Value) + chr(34) + ")"
      _ima_filter := .T.
IF ! EMPTY ( Win_1.Control_8.Value )     // CLI_HDATE
   IF _ima_filter
      _qry_exp = _qry_exp + "CLI_HDATE = " + "CTOD(" + chr(34) + DTOC(Win_1.Control_8.Value) + chr(34) + ")"
      _ima_filter := .T.
IF ! EMPTY ( Win_1.Control_9.Value )     // CLI_SALARY
   IF _ima_filter
      _qry_exp = _qry_exp + "CLI_SALARY = " + STR( Win_1.Control_9.Value )
      _ima_filter := .T.
IF ! EMPTY ( Win_1.Control_10.Value )     // CLI_CITY
   IF _ima_filter
      _qry_exp = _qry_exp + "CLI_CITY = " + chr(34) + Win_1.Control_10.Value + chr(34)
* end of program *
Hope that useful :idea:
P.S. I've placed here a most recent version with small improvements ;)
how it is looks?
how it is looks?
Re: HMG Case
gfilatov wrote: ...corrections in the generated code...
:o
Re: HMG Case
:o
Hi Esgici,
I've considered the generated code as good example of Browse control handling.
That's all 8-)
