Print EURO sign
hynan
Print EURO sign
Post by hynan »
Hi all,
Am not shure it is reilly a bug,
and maby i did not search good enough, but i cannot find it.
I want print the EURO sign ( € )
the program is for console screen, but not important ( i think )
it must only come on paper,
normally it is code (ALT) 0128
@ 20, 20 PRINT CHR ( 0128 ) FONT "Arial" SIZE 12
wil not work
or....maby it is the txt editor i use the problem ? ( textpad )
Thanks in advance, Greetings, Hynan
Re: Print EURO sign
When you try chr(0128), you will get character 128 from your font. it really couldn't be € sign, becausecharacters (127-254) from fonts depend from codepage, and were projected before € was born (1995).
You should use unicode, I suppose.
Marek
Italia1
Re: Print EURO sign
Post by Italia1 »
Hello. In my XP Home OEM PRINT chr(128) without FONT option but with
SET PRINTDOC ENCODING TO "WinAnsiEncoding"
put Euro sign € in my PDF. Try it. I hope it's useful.
Bye. :)
I use the great HMG3.2(stable). Have i nice international HMG to everyone!
Print EURO sign
Italia1 wrote:Hello. In my XP Home OEM PRINT chr(128) without FONT option but with
Bye. :)
Please note for hmg_hpdf library, you must use: SET HPDFDOC ENCODING TO "WinAnsiEncoding" instead. Ok ?
Re: Print EURO sign
Hola amigos
Aportado por Pablo César ----> SET HPDFDOC ENCODING TO "WinAnsiEncoding"
este otro creo que tambien hace lo mismo segun la tabla
viewtopic.php?f=9&t=2497&hilit=hpdf&start=30" onclick="window.open(this.href);return false;
SET HPDFDOC ENCODING TO "CP1252"
ver tambien
viewtopic.php?f=10&t=3416" onclick="window.open(this.href);return false;
regars
Mustafa :D
Print EURO sign
mustafa wrote:Aportado por Pablo César ----> SET HPDFDOC ENCODING TO "WinAnsiEncoding"
No, no Mustafa. Yo no hé aportado en ese comando. Apenas esclareci, porque estaban utilizando el mismo comando para HMG_HPDF que el de MiniPrint. Este comando fué adicionado por Rathinagiri donde muestra la tabla en:
viewtopic.php?p=22008#p22008
Lo que fué presentado en octubre de 2012.
Print EURO sign
What I know is SET HPDFDOC ENCODING TO calls _HMG_HPDF_SetEncoding function and this function has a particulars details regarding only for hmg_hpdf and not used for standard print. See below the source code:
Function _hmg_hpdf_setencoding( cEncoding )
If _HMG_SYSDATA[ 150 ][ 1 ] == Nil // PDF object not found!
   _HMG_HPDF_Error( 3 )
HPDF_SetCurrentEncoder( _HMG_SYSDATA[ 150 ][ 1 ], cEncoding )
_HMG_SYSDATA[ 150 ] [ 10 ] := cEncoding
So I believe is better not to be confuse both commands. ;)
because I did not found any instructions for SET PRINTDOC ENCODING, which seems you are confusing commands.
Re: Print EURO sign
Hola Pablo César
me equivoque no queria decir "Aportado", queria decir que lo habias
puesto escrito en tu Pos anterior, creo que todos queremos decir lo
mismo , la Fuente es el Gran Maestro Rathinagiri
Un saludo, Regars
Print EURO sign
mustafa wrote:me equivoque no queria decir "Aportado", queria decir que lo habias
mismo
Ahh si, asi es mejor ! :)
Aqui en este link hay mayores esclarecimientos. Por eso actualizé los URL del demo:
Haru Free PDF Library - Fonts and Encodings
