HMG Print Samples
ROBROS
Re: HMG Print Samples
Post by ROBROS »
Hi esgici,
so far I never felt in need to print data via dbase, clipper etc. I always opened data with excel and made them fit for printing. Or I transferred data to other people who were able to output them fitting their needs. Now I am helping a 2 people company to make their day a bit easier. They can use programs (excel is used to create forms, but not with filling these forms with data), so I decided to try it with hmg. The job is to fill forms with data. Thank you so much for your print samples, it brought me confidence, I can do that with hmg.
Your samples are very useful for me.
Thank you
Robert
ROBROS
Post by ROBROS »
Hi, Ihave a question:
Does printsystem work with windows 10? I mean is the default printer recognized? I can't try, because I use win 7 in VirtualBox.
Thx
Robert
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
No worries, recognizes all printers as well as pdf printers (print to pdf)
ROBROS
Post by ROBROS »
Thx, Dragan, I was hoping this.
Robert
Templar
Post by Templar »
Printing certainly is one of the hardest things, and can i ask for some help, please?
The samples are very useful, but I am struggling with trying to right-justify text. Any tips on this?
I've used <RightMargin> - LEN( TextString ) + nCharWidth
but it still isn't quite right.
Yemplar
dragancesu
Try demo, prtest01.prg
*-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.
   HMG Print ( Mini Print ) for beginners in 10 easy steps
   Step #1  :
   Use everything with default values,
   write only "This is a test"
   to four corners and center of paper.
PROCEDURE  PrintTest()
      Default paper size is A4 Sheet; 210- by 297-millimeters
   LOCAL lSuccess := .F.,;
         cTestString   := "This is a test",;
         nMostRightCol := 210,;  // Default page size is A4 : 210 x 297 mm
         nMostBottmRow := 297
   SELECT PRINTER DEFAULT TO lSuccess PREVIEW
   IF lSuccess
      START PRINTDOC
         START PRINTPAGE
             @ 0, 0 PRINT cTestString                                    // Top Left
             @ 0, nMostRightCol PRINT cTestString  RIGHT                    // Top Right
             @ nMostBottmRow / 2, nMostRightCol / 2  PRINT cTestString CENTER  // Center of paper
             @ nMostBottmRow - 4, 0 PRINT cTestString                       // Bottom Left
             @ nMostBottmRow - 4, nMostRightCol PRINT cTestString RIGHT       // Bottom Right
         END PRINTPAGE
      END PRINTDOC
      MsgStop( "Couldn't select default printer !", "ERROR !" )
RETURN  // PrintTest()
dimensions are in mm, just adjust where to print and add RIGHT or CENTER, LEFT is defaults
FONT and SIZE are some of the windows fonts
