One more Parameter in Getfile()
quartz565
Post by quartz565 »
I think it would be very useful to set an extra parameter in the function getfile() for the file(s) view in the predefined folder? i.e. 1,2,3,4,5,6 where 1=Details, 2=List, 3=Icons, 4= Tiles, 5=Thumbnails, 6=Filmstrip. This way it wouldn’t be necessary to change this setting from the view menu.
It would make it a lot easier if someone (like my): would like to choose one or more images at once (if you do not know the name of the file...)
Nikos
Nikos.
os: Windows Server 2019 - 64
quartz565
Re: One more Parameter in Getfile()
Post by quartz565 »
It would make it a lot easier if someone (like my): would like to choose one or more images at once (OR if you do not know the name of the IMAGE file...)
Nikos.
quartz565 wrote: I think it would be very useful to set an extra parameter in the function getfile() for the file(s) view in the predefined folder? i.e. 1,2,3,4,5,6 where 1=Details, 2=List, 3=Icons, 4= Tiles, 5=Thumbnails, 6=Filmstrip. This way it wouldn’t be necessary to change this setting from the view menu.
I guess acFilter parameter of GetFile() function may meets your need ( at least a portion ) ;)
Screenshoot of GetFileTest.prg
GetFileTest.zip
Source files of GetFileTest
(843 Bytes) Downloaded 308 times
quartz565
Post by quartz565 »
That’s a very useful utility indeed Esgici. Thanks!
What I mean though is:
When we open a folder by using the getfile() command, in that window the listing of the files is always in “List” view so only the names of the files appear. So if you’d want to have a quick look at some images for example you have to go at the view menu and change it to “Thumbnails”. What I’m trying to find out is if there is an option that can be set to the getfile() command as a parameter which could do that and open the window in “Thumbnails” view.
Nikos.
quartz565 wrote: What I mean though is:
As far as know, GetFile() function of HMG calls GetOpenFileName() of Windows API.
So, "List View" is normal behavior of Windows.
"View menu" and other views are features of Windows Explorer, not sub-functions.
Maybe an expert would develop a solution for your request.
Anyway you would think develop your own GetFile() function.
When done please share with us.
Hi Nikos !
It would be good to have something like this:
or something like this:
But you can do it by yourself, creating a windows, selecting path, showing pictures and multiselecting of files. All depends of your imagination and criativity. ;)
quartz565
Post by quartz565 »
Thanks Esgici,Pablo.
I will try...
Nikos
Nikos.
quartz565 wrote:Hi,
Nikos
Hi Nikos.
In function C_GETFILE (file C:\hmg.3.1.5\SOURCE\c_dialogs.c, line 196) change:
int flags = OFN_FILEMUSTEXIST;
for:
int flags = OFN_FILEMUSTEXIST | OFN_EXPLORER;
and rebuild-lib.
Claudio.
PS: see picture
srvet_claudio wrote: In function C_GETFILE (file C:\hmg.3.1.5\SOURCE\c_dialogs.c, line 196) change:
for:
and rebuild-lib.
I can't believe :o
Can't be simple as that :shock: :shock: :shock:
Viva HMG, viva Dr. Soto :D
srvet_claudio wrote:...
and rebuild-lib.
I couldn't rebuild :(
Will we hope a new release ? :oops:
Best regards :D
