Debug -b option in IDE
reds
Post by reds »
Trying to make use of altd debug function
IDE (r16951) doesn't seem to accept -b compiler option in project environment compiler menu option
i.e.
Hitting the OK button after selection does not close menu box ,I have to cancel it to exit it
is there something else I need to set/select ?
It's also a bit hit and miss as to when you can select the enviroment menu option\
Peter
Re: Debug -b option in IDE
In IDE, you should use Project->Debug to build app with debugger.
Remember to clear incremental data if you use it.
reds
Post by reds »
I don't seem to have a debug project with my install
No matter, I've decided to compile from command prompt
Thanks
