Hello!
Hello!
Hello everyone!
I am very happy to belong to this forum, I hope to learn a lot of HMG and yours. And I would like to know where I can get Softwere HMG and links to tutorials or aid or if there is a book, which would you recommend?
Just going to meet HMG am very happy!
My language is Spanish, but as I see you all prefer the English, I have asked Google Translator to make me a favor and do it myself.
Greetings from Mexico, DF
Re: Hello!
Bien venido Javier al nuestra comunidad !
Aqui tenemos tambien una seccion en español, si sientes mayores dificultades.
Mi consejo es que empieces con la version HMG 3.1.5 en modo UNICODE, si tienes algun conocimiento de programacion GUI.
Para mejor aprendizaje, te indico los própios ejemplos que encontrarás em la sub-carpeta llamada SAMPLES. Y para bajar la ultima seccion aqui o aqui
Espero haberte ayudado !
Re: Hello!
Gracias Pablo César, pero no tengo ninguna experiencia de programación, tengo 16 años y me gustaría ser programador, y es por eso que estoy empezando a ver que programas se están utilizando, y por parte de mi papá que el utilizo C, Ensamblador, DBase y Clipper en su momento me recomendó que investigara sobre los diferentes SoftWere que hay y es como di con el Foro. Empiezo desde Cero. Espero aprender Rápido.
Y por el idioma, creo que asi esta bien, o tambien lo podria poner Español y abajo ingles. Voy a ver como resulta asi.
Thanks Pablo César, but I have no programming experience, I have 16 years and I would be a programmer, and that's why I'm starting to see what programs are being used, and by my dad that use C, Assembler, DBase Clipper at the time and recommended me to investigate on different softwere there and it's like I found the Forum. I start from zero. I hope to learn fast.
And the language, I think so okay, or it could also put down Spanish and English. I will see how it well.
Hello!
16 years old ? wow very young congratulations !
You are right ! Keep looking for new tools for your programmation. If you are familiar with Clipper, so this is a very good way !
Re: Hello!
Hola Javier :
Bienvenido a HMG, como dice el amigo Pablo comienza utilizando HMG.3.1.5 (test) , recuerda que dentro del IDE hay un enlace a abrir la "Referencia" de HMG. esta referencia contiene los controles y funciones de HMG; ahi dentro esta todo lo necesario para trabajar con esta Libreria grafica.
sino revisa tu instalacion de HMG que generalmente se encuentra en c:\HMG.3.1.5 dentro de ella esta la carpeta \Doc ahi dentro esta la Referencia
en la carpeta \Samples estan los ejemplos ordenados por tipo. puedes entrar y compilar cada uno de los ejemplos para aprender este Mundo grafico de HMG.
esta Referencia tiene el enlace a todos los comandos Harbour (Clipper) como "External Guides and Tutorials".
cualquier cosa crea un nuevo Topico para mas ayuda, esta mas decir que posiblemente hayan pedido tu inquietud y puedes utilizar el buscador que tiene el foro para no preguntar lo mismo.
desde ya Saludos desde Buenos Aires Argentina.
Re: Hello!
Gracias Danielmaximiliano, no entiendo mucho, apenas voy a descargar el Softwere y sí primero consultare por el buscador y si no encuentro lo que busco, después pregunto. Y gracias por la recomendación.
Thanks Danielmaximiliano not understand much, just going to download the first Softwere and yes consultare by the search engine and if you find what I want, then ask. And thanks for the recommendation.
Re: Hello!
Gracias Esgici, y si por lo que veo clipper es un barco.
Thanks Esgici, and if I see a boat clipper.
Re: Hello!
Ahora si que somos internacionales, Brasil, Argentina, Turquia, Polonia, México...
Gracias Mol por el recibimiento
Now if we are international, Brazil, Argentina, Turkey, Poland, Mexico ...
Thanks for the welcome Mol
