HMG 2.8.1? ... Yes! ... well... maybe :)
Posted: Sat Apr 11, 2009 10:34 pm
Well... I'm trying to not make the same mistake twice, so, prior to publish a 2.8.1 full release, I've decided to publish the sources here.
Please, test it!
I've rewrote all 'by cell' thing from the scratch, so, if you find bugs, I'm sure that (at least) will be different ones
You should merge the attached files with your existing HMG installation and create the library (\hmg\sources\makehmg.bat). Please backup your current HMG first)
Here is the provisional changelog:
- Harbour MiniGUI 2.8.1 Changelog:
English:
-Fixed: Window not accepting keystrkes on program start. Introduced in 2.7.0. Reported by RalphMDS.
- Modified: GRID control. Navigation is 'by cell' from this version. To enable or disable it, you must use:
SET CELLNAVIGATION ON | OFF
Sample: \hmg\samples\grid_21
Please, test it!
English:
