AUTO UPDATER?
AUTO UPDATER?
As I've commented many times, my recent work is about HMG applications that get data through the Internet (NETIO).
The main issue with this scheme is the app update.
Currently I must send the '.exe' by email to each remote user with directions to replace the old one. The problem is that some users are not capable to handle that.
So, the solution is an auto-updater.
The obvious path is to have two '.exe'. The first one checks an FTP server for an update, and if there is one, it is downloaded and executed.
No problem, it is easy to do... but I don't like it :)
My wish is to have only one .exe doing all the job, but I'm afraid that, there is a lot of problems to solve to achieve that.
had someone tried this with success?
TIA.
Re: AUTO UPDATER?
My main .exe file test if update is ready to download. If new version is present, it's downloaded, then executed.
function CheckPresenceOfNewVersion
	param lSilent
	local cVersion:= "", lInstall := .f., cVersionTXT := ""
	if lSilent = NIL
		lSilent := .f.
	if !DownloadFromWWW("http://www.molsystemy.pl/faktury/f4wersja.txt",Kat_Roboczy+"f4wersja.txt", .t.)
		if !lSilent
			MsgBox("Error in connection")
		return
	cVersionTXT := Memoread(Kat_Roboczy+"f4wersja.txt")
	cVersion := alltrim(Memoline(cVersionTXT))
	if cVersion > cCurrentInstalledVersion
		load window Form_NewVersion
		center window Form_NewVersion
		Form_NewVersion.E_INFO.Value := cVersionTXT
		ON KEY ESCAPE OF Form_NewVersion ACTION Form_NewVersion.Release
 		define ACTIVEX Counter
			Parent Form_NewVersion
			ROW 1
			COL 1
			WIDTH 1
			HEIGHT 1
			PROGID "shell.explorer.2"
		end ACTIVEX
		activate window Form_NewVersion
		lInstall := .f.
		if !lSilent
			MsgBox("New version is absent...")
return
function InstallNewVersion
	local lServerAnswer
	WAIT WINDOW  "Downloading new version..."  NOWAIT
	lServerAnswer := DownloadFromWWW("http://www.mol-systemy.com.pl/faktury/f4setup.exe",Kat_Roboczy+"f4setup.exe", .t.)
	WAIT CLEAR
	declare window MainForm
	if !lServerAnswer
               // this line is for my statistic only
		cAddress := 'http://molsystemy.pl/faktury/licznikaktualizacjifaktury.php?nip=' + alltrim(DaneFirmy[8])+'&nazwa='+hb_strtoUTF8(alltrim(DaneFirmy[6]))
		GetProperty('Form_NewVersion','Counter','Object'):Navigate(cAddress)
		MsgBox("Close app on other workstations and press OK to install new version")
		cprog	:= Kat_Roboczy+'f4setup.exe'
		cParam	:= '/dir="' + left(sc_dost, len(sc_dost)-1)+'"'
		_Execute ( GetActiveWindow() ,, cProg , cparam ,, 5 )
		MainForm.release
return
Re: AUTO UPDATER?
PROCEDURE DownloadFromWWW
	param cURL, cLocalFileName, lSilent
	LOCAL oCon, oUrl, i, cResponse
	local ret := .f.
	local oOldErrorHandle
	oOldErrorHandle:= ErrorBlock({|e| break(e)})
	BEGIN SEQUENCE
	cLocalFileName := alltrim(cLocalFileName)
	if lSilent = NIL
		lSilent := .f.
	oUrl := tURL():New( cUrl )
	IF Empty( oUrl )
		if !lSilent
			MsgBox("Wrong url: " + cUrl)
		BREAK
	IF oUrl:cProto != "http"
		if !lSilent
			MsgBox('Wrong http address')
		BREAK
	END
	oCon := TipClientHttp():New( oUrl )
	oCon:nConnTimeout := 20000
	if !lSilent
		MsgBox("Connecting with "+ oUrl:cServer)
	IF oCon:Open( cUrl )
		if !lSilent
			MsgBox("Connected." +chr(10)+"Press OK to download " + oUrl:cPath +oUrl:cFile)
		oCon:WriteAll(cLocalFileName)
		if !lSilent
			MsgBox("Downloaded and saved as: "+cLocalFileName)
		oCon:Close()
		ret := .t.
		IF oCon:SocketCon == NIL
			cResponse := "uninitialized connection"
		ELSEIF hb_InetErrorCode( oCon:SocketCon ) == 0
			cResponse := oCon:cReply
			if !lSilent
				cResponse := "Error in connection: " + hb_InetErrorDesc( oCon:SocketCon )
		if !lSilent
			MsgBox("Can't connect with: "+ oUrl:cServer+chr(10)+"Host answer: "+cResponse)
		ret := .f.
	END
	RECOVER
		if !lSilent
			MSGSTOP("Connection with server couldn't be completed")
	END SEQUENCE
	ErrorBlock(oOldErrorHandle)
RETURN ret
Re: AUTO UPDATER?
Really useful Marek. Thanks a lot. I will try in my system.
AUTO UPDATER?
Seems to usefull !!!
Thanks Marek for sharing with us ! :)
Re: AUTO UPDATER?
mol wrote:My main .exe file test if update is ready to download. If new version is present, it's downloaded, then executed.
Looks great. I'll try it, Thanks.
Re: AUTO UPDATER?
Roberto,
I have the same "problem" which I resolved as follows:
On startup (a batchjob) I first do TSKILL of the main.exe, then start my INIT.EXE which will check on mysql database if there is a new version.
If there is download it, rename main.exe to main-date-time.exe and the rename the downloadfile to main.exe
After the INIT.exe I do START MAIN.EXE (with a new version or unchanged version). This is working since 5 years without problems.
If interested I can send you the programs + SQL structures.
Greetings,
Re: AUTO UPDATER?
serge_girard wrote:Roberto,
Greetings,
I'm working with NETIO, so, my plan is to transfer the updated EXE via NETIO, to avoid the set up of an additional server (FTP or HTTP) and keep the things simple.
And, of course, the idea of a batch file controlling things, is nice, clean and simple.
My problem is that sometimes, I miss the simple solutions.
Thanks for your answer.
Nascimento
Re: AUTO UPDATER?
Post by Nascimento »
hi mol I could post the Form_NewVersion sorry I could not compile
att: Nascimento
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: AUTO UPDATER?
Post by dragancesu »
I recently watched this can be done
I think the solution is simply a program that serves to install HMG is installforge.net when you go to make the installation there is an option update and should specify the internet site where the new version
