Quicktext is a Notepad++ plugin for text substitution with multi field inputs. Using TAB allows code segment to be inserted quickly. The plugin also has option for Add/Modify quick tags, which changes the QuickText.ini file.
In this demo is used QuickText.v0.2.1.
Small and efficient and gets the job done.
It works just as intended and much more.
Recommended!
Notepad++ Quicktext
Notepad++ Quicktext
Notepad++ Quicktext
The Quicktext is very useful also among many plugins, practical and simple to use but it makes a lot of time editing the source code.
I got to include several tags that will be very useful, some few are in Harbour and most in HMG. As was mentioned in the video, use the Quicktext to reproduce examples of components such as: MAIN WINDOW BUTTONS, Grid, COMBOBOX, etc ... These tags are in UPPER case, because I really like to use CamelCase my editions. But if the use of the TAB is bothering you, can replace by ALT + ENTER combined keys at Settings \ Shortcut mapper \ Plugin commands TAB (Replace Tag item) or you can change tags from UPPER to lower case as you wish because all entries are in sensitive case.
So in attached file, are configuration files (instructions in Readme file to install it). TAG list inputed: (click on "Show" button below)
Important note: Some time there is a conflict with Alt-Enter hotkeys that probably was reserved for other functions of NPP. In case is not working properly, please check if is in red color in Settings/Shortcut mapper and change it.
Rgds
Rgds
Re: Notepad++ Quicktext
Hi Pablo,
I referred to the quicktext.ini that you provided
and transfer it to another format, so that it can be used with another plug tools "FingerText" .
- FingerText - 0.5.60.zip
- (476.08 KiB) Downloaded 425 times
