DEFINE REPORT (with filtered data)
Hola a todos
Alguno de ustedes a utilizado el DEFINE REPORT con registros filtrados ?
Me explico mejor, el DEFINE REPORT me saca el reporte con TODOS los registros
de la DB seleccionada en ese momento, yo quiero sacar solo los de cierta fecha
o cierta condicion. Gracias.
Hello everyone
Some of you used the DEFINE REPORT with filtered records?
Let me explain better, the DEFINE REPORT takes the report with me ALL records
of the currently selected DB, I want to get only a certain date
or certain condition. Thanks.
Hello everyone
Re: DEFINE REPORT (with filtered data)
Hola Andyandyglezl wrote: Some of you used the DEFINE REPORT with filtered records?
Did you try to build your own filter yourself ?
For example adding this line :
SET FILTER TO "Chile" $ COUNTRY to top of ( BEFORE DEFINE REPORT Report1 line ) CreateReport function of <...>\SAMPLES\Controls\ReportAdvanced\REPORT.ADVANCED.1\demo.prg
Happy HMG'ing
Garcias esgici
Crei que asi seria, pero pense que el "Report" le podia indicar lo que queria imprimir.
Lo solucione asi, espero que les sirva !
Thanks Esgici
I thought that was so, but I thought the "Report" you could indicate what I wanted to print.
It solves so, I hope they serve!
Thanks Esgici
- CreateRep.rar
- (15.33 KiB) Downloaded 879 times
Congrats !andyglezl wrote: I thought that was so, but I thought the "Report" you could indicate what I wanted to print.
You have ask a question and also you respond by a way more complex than mine
Sadly, since I don't know your language, it not served to me in any manner
Anyway, Viva HMG
Lo siento por eso esgici
Pero a excepcion de los "titulos" y los arreglos de "dias" de la semana y "meses"
(que ya traduje con google) lo demas es variables, campos, lenguaje en HMG y Harbour...
aqui va de nuevo traducidos al ingles
Sorry about that Esgici
But with the exception of the "titles" and arrangements of "days" of the week and "months"
(already translated with google) the rest is variables, fields, and Harbour HMG language ...
here goes again translated into English
- crearep.rar
- (2.22 KiB) Downloaded 847 times
OKandyglezl wrote: Sorry about that Esgici
Thank to your extra efforts
Viva HMG
Gracias por compartir Andy....
probando.....
probando.....
Buena solucion André, felicitaciones. Creando un dbf virtual, buena idea !andyglezl wrote:Lo solucione asi, espero que les sirva !
Good solution André, congratulations. Creating a virtual dbf, good idea !
- SALINETAS24
Es una opción que nos saca del apuro, pero no es muy ortodoxa. El sistema trabaja el doble, por un lado procesando y grabando y despues sacando el REPORT.
Lo suyo sería que se implementara dentro de la misma funcion de activacion, como ya la teníamos para el Clipper 5,2.
Pero muchas gracias por la idea.
ACTIVATE REPORT rptComis ;
WHILE ! Clien ->( EoF() ) .AND. LASTKEY(INKEY())!=K_ESC ;
.AND. Clien->NUMERO <= nFinal ;
ACTION Clien ->( DbSkip() )
Hola Salinetas
No entiendo que es lo que te preocupa, ya no estamos en la epoca de D.O.S.,
ya no hay problema con el espacio en disco, en memoria, los procesadores
son de varios nucleos, etc. etc. yo lo hice hace 5 años y no tuve problema.
Que equipo tienes ?
Que equipo tienes ?
