Project Path in IDE
Project Path in IDE
Hi
In addition to project name, it will be nice seeing path of project folder in the IDE; I think :?
Any opinion :?:
Project Path in IDE
Yes I agree also with you.
I used to change IDE title thru View_Build_Log.exe when I click to prg file at IDE which normally should call a sorce editor. ;)
Here there is also a solution for changing itle of IDE (it is from Dr. Soto).
Rgds
Re: Project Path in IDE
Thank to your confirmation.
My opinion was like :
Suggestion for<br /> project path placement in IDE
Suggestion for
TIA
Project Path in IDE
It is good idea to use StatusBar of Main Window of IDE, just to make good use of the space unusable, but IMO changing in the title of IDE, we can identify different projects when are open and minimized windows:
We can change position in title. First can be el project name with path and then IDE version and author credits. Switching place of those info, we can identify very well.
And for me is not necessary to show HMG link in the title. This is my point of view...
IMO status bar is better.
If agreed adding path info to UI of IDE, may our masters ( Rathi, Dr. Soto ) will decide the best place, no doubt.
TIA :D
