Page 1 of 2
Cursor shape/size in console screen
Posted: Mon Jul 01, 2013 5:23 am
by hynan
Hi all,
My first post, and question,
am using for some program console screen,
so starting with:
REQUEST HB_GT_WIN_DEFAULT
SETMODE ( 25, 80 )
SETCOLOR ( "W+/B, GR+/R, N, GR+/N, GR+/R" )
CLS
when making some SAY GET READ
cursor shape(size) does not change when pressing the INSERT button,
so cannot see if insert or overwrite mode is active.
Is there a way to fix this ?
Thanks in advance,
greetz from Holland ;)
Re: Cursor shape/size in console screen
Posted: Mon Jul 01, 2013 11:29 am
can you post a short example to test that way forum members prove in their respective machines and would verify the failure or bug.
Posted: Mon Jul 01, 2013 4:28 pm
by hynan
FUNCTION MAIN ()
LOCAL TMP := " "
SETMODE ( 25, 80 )
SET CODEPAGE TO ENGLISH
SET LANGUAGE TO ENGLISH
CLS
@ 0,0 SAY "Input" GET TMP
READ
When showing the Input cursor will stay same size,
when pressing Insert or not,
Insert is working Ok, change from overwrite to Insert an vice versa,
but cursor size not change ( like old clipper, from full block to half block )
Hope you understand my englisch ;)
Greetz, Hynan
Posted: Tue Jul 02, 2013 5:12 pm
by dhaine_adp
Hi Hynan,
The code mysIns(), below failed also. HMG ON KEY command can't be used so I tried it with SETKEY(). It seems like the Insert key press is evaluated inside the GET object. Msginfo() didn't appear at all. I also tried replacing VK_INSERT (from HMG i_keyb.ch) using HB INS value 338 but didn't work as well. That's supposed to be a workaround to the problem, LOL but failed. :cry:
Sorry Pal.
Danny
FUNCTION MAIN ()
LOCAL TMP := " "
SETMODE ( 25, 80 )
SETCURSOR(1)
*SET SCOREBOARD OFF
SETKEY( VK_INSERT, { || myIns() } )
CLS
READ
function myIns()
//msginfo( HB_NTOS( SETCURSOR() ), "x" )
SET KEY TO
KEYBOARD VK_INSERT
IF SETCURSOR() = 1
   SETCURSOR( 2 )      // Half block cursor
   SETCURSOR( 1 )      // normal cursor
Posted: Tue Jul 02, 2013 5:29 pm
by hynan
Thanks for thinking with me and trying some ;)
Greetz, Hynan...
Posted: Tue Jul 02, 2013 7:27 pm
Really bad new, I also did not found a way to change cursor style.
I got how to differenciate insert modes by Daniel example, but I can not get to change console cursor style.
Function Main()
LOCAL TMP := "   "
SETMODE ( 25, 80 )
SETCURSOR(1)
*SET SCOREBOARD OFF
SETKEY( 22, { || MyIns() } )
CLS
READ
SETKEY( 22, { || Nil } )
Function MyIns()
IF READINSERT()
   READINSERT(.F.)
   SetCursor( 1 )
   @ 24,00 SAY PadC("NO INS",80)
   READINSERT(.T.)
   SETCURSOR( 2 )
   @ 24,00 SAY PadC("INS",80)
Probably the problem is with GT_WIN_DEFAULT
Posted: Tue Jul 02, 2013 8:03 pm
Creo se añadio una nueva caracteristica a
por eso el tamaño del cursor no cambia, voy a revisar los cambios en Changed.log de harbour.
Translate Google
I think they added a new feature to
so the size of the cursor does not change, I will review the changes in Changed.log of harbor.
no InsertCursor.png (11.45 KiB) Viewed 6062 times
Posted: Wed Jul 03, 2013 6:03 am
by hynan
Thanks all for looking into it,
Greetz, Hynan
Posted: Wed Jul 03, 2013 6:36 pm
by dhaine_adp
Hi Pablo & Hynan,
The code below works and change the cursor size. The trick is that we need to use the command CLEAR GETS and re-invoke GET OBJECT. It works fine with one READ statement.
The new problem begins with this sample code below. SETKEY() have to be redefined on UDF getMisc() because of parameter changes, it has to call getMisc(). Also you would notice that even if the cursor is set into half block mode on the first getKey() READ, when getMisc() were executed the cursor is set to normal [SETCURSOR(1)] by GT itself?
We need to break the GET objects so that when CLEAR GETS were issued the program won't terminate.
Pablo: Thanks for the READINSERT()
Now, I wonder if it is really the right approach or is it a bug from GT? Because if you look at the code there are two EXIT points that must be taken care off in order to change the cursor size. It will be fine as long as the get*() UDF will always RETURNs NIL.
Danny
Function Main()
PRIVATE aItems_ := {SPACE(5),SPACE(10), 0}
SETMODE ( 25, 80 )
SETCURSOR(1)
*SET SCOREBOARD OFF
CLS
getLabels()
getKey()
getMisc()
function getLabels()
@ 0,0 SAY "Code:"
@ 1,0 SAY "Description:"
@ 2,0 SAY "Unit Cost:"
function getKey()
SETKEY( 22, { || MyIns("CODE") } )
@ 0, 7 get aItems_[ 1 ] PICTURE "@!"
READ
function getMisc()
SETKEY( 22, { || MyIns("MISC") } )
@ 24,00 SAY PadC("NO INS-" + HB_NTOS( SETCURSOR() ),80)
@ 1,13 get aItems_[ 2 ] PICTURE "@!"
@ 2,12 get aItems_[ 3 ] PICTURE "@ZB9,999.999"
READ
END SEQUENCE
Function MyIns( cMode )
CLEAR GETS
IF READINSERT()
   READINSERT(.F.)
   SetCursor( 1 )
   READINSERT(.T.)
   SETCURSOR( 2 )
   @ 24,00 SAY PadC("INS-" + HB_NTOS( SETCURSOR() ),80)
IF cMode == "CODE"
   getKey()
   getMisc()
Posted: Wed Jul 03, 2013 7:38 pm
by dhaine_adp
Hi all,
I think its problem with GT. Below is another implementation of the sample code:
To test, copy & paste the code below and recompile. While you are in GET aItems_[1] press insert and fill-up the field until it moves to the second instance of the GET object aItems_[2] and #3. You'll notice that you are still in Insert Mode but the cursor is set to normal. Press Insert key twice and you'll see the cursor change to half block.
There's is no checking on the cursor size. I think that's all, I'm going to quit testing.
Danny
Function Main()
PRIVA cMode := ""
SETMODE ( 25, 80 )
SETCURSOR(1)
*SET SCOREBOARD OFF
SETKEY( 22, { || MyIns(cMode) } )
CLS
getLabels()
getKey()
getMisc()
@ 0,0 SAY "Code:"
function getKey()
cMode := "CODE"
READ
function getMisc()
cMode := "MISC"
READ
END SEQUENCE
CLEAR GETS
IF READINSERT()
   READINSERT(.F.)
   SetCursor( 1 )
   READINSERT(.T.)
   SETCURSOR( 2 )
IF cMode == "CODE"
   getKey()
   getMisc()
