Splash Window
Splash Window
Hola
Buscando en la Red, me encontre esta programa, espero les sirva.
Hello
Searching the Internet, I found this program, I hope they serve.
Splash.rar
(910.57 KiB) Downloaded 619 times
Amarante
Re: Splash Window
Post by Amarante »
Very good!
Is it possible to display an image out of a window (a borderless image) with HMG?
Dr. Soto with the word ...
Leopoldo Blancas
Re: Splash Window
Post by Leopoldo Blancas »
Hola andyglezl...
y el *.prg ?????????
Polo
Re: Splash Window
Leopoldo Blancas wrote:Hola andyglezl...
Polo
aca esta completo para compilar con Minigui.
SPLASHDEMO_2.rar
(460.52 KiB) Downloaded 1288 times
Re: Splash Window
Hola Leopoldo
En este caso solo encontre el ejecutable y maneja solo archivos PNG
Aqui lo interesante es que independiente del lenguaje que uses, puedes
poner tu pantalla de Splash.
Re: Splash Window
This is a example of how to create a splash screen with HMG and BT.
The trick is to make NULL the brush that paints the window background
#define GCL_HBRBACKGROUND  -10
oldBrush := SetClassLong (GetFormHandle("_FormSplash"), GCL_HBRBACKGROUND, NIL)
BT_SplashScreen.rar
(439.94 KiB) Downloaded 561 times
Re: Splash Window
srvet_claudio wrote:This is a example of how to create a splash screen with HMG and BT.
Gracias Claudio..
Re: Splash Window
Thanks Dr. :)
