Parece que con Harbour en las variables locales no es posible la macrosubstitución, pero creo recordar que en una aplicación que hice en 2004 me funcionaba, por ejemplo en un browse algo como WORKAREA &cAlias con variable LOCAL. Ha habido cambio desde entonces o me falla la memoria ???
Saludos cordiales
Macrosubstitución
Re: Macrosubstitución
Hola Agustin :
Harbour 3.x Nigthtly tiene ejemplo en C:\hb32\tests\macro.prg
con variables Private y locales, en el ChangeLog.txt no encontre correcciones sobre Macros, apenas algunas pero nada muy importantes.
Leopoldo Blancas
Hola...
Si se puede hacer la macro sustitución con LOCALES, PRIVATE Y PUBLIC...., Aunque yo prefiero Private y Public. Por esta Razón:
Espero te ayude.
Polo
Macro evaluation--unary (Special)
Syntax
&<cMacroVar>[.]
&(<cMacroExp>)
Operands
<cMacroVar> can be any character variable. The period (.) is the
macro terminator and indicates the end of the macro variable and
distinguishes the macro variable from adjacent text in the statement.
<cMacroExp> is a character expression enclosed in parentheses. In
this instance, the expression is evaluated first, and the macro
operation is performed on the resulting character value. This allows
the contents of fields and array elements to be compiled and run.
Description
The macro operator in CA-Clipper is a special operator that allows
runtime compilation of expressions and text substitution within strings.
Whenever the macro operator (&) is encountered, the operand is submitted
to a special runtime compiler (the macro compiler) that compiles
expressions, but not statements or commands.
Text Substitution
Whenever a reference to a private or public macro variable, embedded in
a character string, is encountered, the variable reference is replaced
by the content of the macro variable. For example,
cMacro := "there"
? "Hello &cMacro" // Result: Hello there
If you specify a macro expression (e.g., &(cMacro1 + cMacro2)), and the
macro variable is a local, static, field variable, or an array element,
it is treated as literal text and not expanded.
Macro operator:nesting
Compile and Run
When a macro variable or expression specified within an expression is
encountered, it is treated like an expression, with the macro symbol
behaving as the compile and run operator. If the macro is specified as
a macro variable,
cMacro := "DTOC(DATE())"
? &cMacro
the macro compiler compiles, then executes the content of the macro
variable. The compiled code is then discarded.
If you specify an expression enclosed in parentheses and prefaced by the
macro operator (&),
? &(INDEXKEY(0))
the expression is evaluated and the resulting character string is
compiled and run as a macro variable.
Using the macro operator, you can compile a character string containing
a code block definition:
bBlock := &("{ |exp| QOUT(exp) }")
The run portion of the operation returns the code block as a value. You
may then use the code block by invoking it with the EVAL() function.
This is especially significant in activations that involve extensive
looping through user-defined conditions (operations that in earlier
versions of CA-Clipper required macro expansion). In those versions,
the macro expression was compiled and run for each iteration of the
loop. With the combination of a macro expansion and a code block
EVAL(), the compilation is performed once at compile time, and the
EVAL() merely executes the code block each time through the loop:
EVAL(bBlock, DATE())
The time savings at runtime can be enormous.
Notes
. Command keywords: You cannot use the macro operator (&) to
substitute or compile command keywords. However, you can redefine
command keywords by modifying the command definition in Std.ch,
overriding an existing command definition with a new definition using
the #command directive, or redefining a command keyword using the
#translate directive. In any case, you may redefine a command
keyword only at compile time, not at runtime.
. Command arguments: In prior versions of CA-Clipper as well as
in other dialects, you could use macro variables as the arguments of
commands requiring literal text values. These included all file
command arguments and SET commands with toggle arguments. In these
instances, you can now use an extended expression enclosed in
parentheses in place of the literal argument. For example,
xcDatabase = "Invoices"
USE &xcDatabase.
can be replaced with:
USE (xcDatabase)
It is important to use extended expressions if you are using local
and static variables. Generally, commands are preprocessed into
function calls with command arguments translated into function
arguments as valid CA-Clipper values. File names in file commands,
for instance, are stringified using the smart stringify result marker
and passed as arguments to the functions that actually perform the
desired actions. If you specify a literal or macro value as the
command argument, it is stringified. If, however, the argument is an
extended expression, it is written to the result text exactly as
specified. This example,
#command RENAME <xcOld> TO <xcNew>;
FRENAME( <(xcOld)>, <(xcNew)> )
RENAME &xcOld TO &xcNew
RENAME (xcOld) TO (xcNew)
is written to the result text as this:
FRENAME( "&xcOld", "&xcNew" )
FRENAME( xcOld, xcNew )
when preprocessed. When the macro variables are stringified, the
macro variable names are hidden in the string and not compiled.
Later, at runtime, they are substituted into the string and passed as
arguments to the FRENAME() function. This precludes local and static
macro variables since the names of the variables are not present at
runtime to be substituted. Public and private variables, however,
behave as expected.
. Lists as arguments of commands: The macro operator (&) will
not fully substitute or compile a list as an argument of most
commands. In particular, these are commands where an argument list
is preprocessed into an array or a code block. Instances of this are
arguments of the FIELDS clause and SET INDEX. An exception is the
SET COLOR command which preprocesses the list of colors into a single
character string and passes it to the SETCOLOR() function.
In any case, list arguments should always be specified as extended
expressions with each list argument specified:
LOCAL xcIndex := { "Ntx1", "Ntx2" }
SET INDEX TO (xcIndex[1]), (xcIndex[2])
. Arrays: You can use the macro operator (&) with arrays and
array elements. However, because of the increased power of
CA-Clipper arrays, you may find less need to use the macro operator
(&) to make variable references to arrays. You can now assign array
references to variables, return array references from user-defined
functions, and nest array references within other arrays. You may
also create arrays by specifying literal arrays or using the ARRAY()
function.
You can, therefore, make references to arrays and array elements
using both macro variables and macro expressions with the restriction
that you cannot make the subscript references in a PRIVATE or PUBLIC
statement. Also, you cannot specify the macro operator (&) in a
declaration statement, such as a LOCAL or STATIC statement.
Attempting this will generate a fatal compiler error.
This example references array elements using macro variables:
cName := "aArray"
nElements := 5
cNameElement := "aArray[1]"
PRIVATE &cName.[nElements] // Creates "array" with 5
// elements
&cNameElement. := 100 // Assigns 100 to element 1
&cName.[3] := "abc" // Assigns "abc" to element 3
You can successfully apply a macro operator (&) to an array element
if the reference is made using a macro expression. A macro variable
reference, however, will generate a runtime error. For example, the
following lists the values of all fields of the current record:
USE Customer NEW
aStruc := DBSTRUCT()
FOR nField := 1 TO LEN(aStruc)
? &(aStruc[nField, 1])
. Code blocks: You can apply the macro operator (&) to a macro
variable or expression in a code block in most cases. There is a
restriction when the macro variable or macro expression contains a
declared variable. A runtime error occurs if you specify a complex
expression (an expression that contains an operator and one or more
operands) that includes the macro operator (&) within a code block.
This has important implications for the use of local and static
variables in the conditional clauses of commands, since these clauses
are blockified as they are written to the result text during
preprocessing. This applies to all FOR and WHILE clauses, the SET
FILTER command, and the SET RELATION linking expression. The general
workaround is to gather the entire expression into a single macro
variable then apply the macro operator (&) to the variable.
. Macro conditions: When using the macro operator (&) to specify
conditional clauses of database commands such as FOR or WHILE
clauses, there are some restrictions based on the expression's
complexity and size:
- The maximum string size the macro compiler can process is 254
characters.
- There is a limit to the complexity of conditions (the more
complex, the fewer the number of conditions you can specify).
. Procedures and functions: You can reference procedure and
function calls using macro variables and expressions. With DO, the
macro variable reference to the procedure can be all or part of the
procedure name. With a call to a function (built-in or user-
defined), the macro variable reference must include the function name
and all of its arguments.
In CA-Clipper, because of the added facility code blocks, all
invocations of procedures and functions using the macro operator
should be converted to the evaluation of code blocks. This code
fragment
cProc := "AcctsRpt"
DO &cProc
bProc := &( "{ || AcctsRpt() }" )
EVAL(bProc)
The advantage of a code block over a macro evaluation is that the
result of the compilation of a string containing a code block can be
saved and, therefore, need only be compiled once. Macro evaluations
compile each time they are referenced.
. References into overlays: You must declare procedures and
user-defined functions that are used in macro expressions and
variables but not referenced elsewhere as EXTERNAL, or the linker
will not include them into the executable (.EXE) file.
. TEXT...ENDTEXT: Macro variables referenced within a
TEXT...ENDTEXT construct are expanded. Note that a field cannot be
expanded, so you must first assign the field value to a memory
variable then reference the memory variable as a macro variable
within the TEXT...ENDTEXT. For example:
USE Customer NEW
myVar := Customer->CustName
TEXT
This is text with a macro &myVar
ENDTEXT
. Nested macros: The processing of macro variables and
expressions in CA-Clipper permits nested macro definitions. For
example, after assigning a macro variable to another macro variable,
the original macro variable can be expanded resulting in the
expansion of the second macro variable and evaluation of its
contents:
cOne = "&cTwo" // expand cTwo
cTwo = "cThree" // yielding "cThree"
cThree = "hello"
? &cOne // Result: "hello"
Espero te ayude.
Polo
Gracias Daniel y Polo. Voy a estudiar lo que me pasais para aclarar mis ideas sobre macros.
