Page 11 of 15
Re: HMG 3.1.4 (Test)
Posted: Wed Jun 26, 2013 2:51 pm
My configuration :
- Esgici configuration at 2013.06.26
- BE_ConfD626.JPG (32.97 KiB) Viewed 12007 times
Posted: Wed Jun 26, 2013 3:12 pm
In my Windows 7 system it works properly. Where as, it is not working in Windows Vista.
So, might be Windows platform problem.
Posted: Wed Jun 26, 2013 6:05 pm
Rathinagiri wrote:In my Windows 7 system it works properly. Where as, it is not working in Windows Vista.
not working in Windows 7 Home Premiun 64 bits.
Uso el IDE solamente para generar los formularios en forma simple, despues de ello utilizo Crimsom editor para seguir trabajando con las modificaciones de los formularios y codigo fuente, tambien lo mismo con el archivo de recursos. a veces compilo con el IDE, a veces con MiBuil.bat personalizado.
sucede que tengo la mala costumbre de manejarme como si fuera Visual Fox Pro.
Use the IDE only generate simple forms, after this I use Crimsom editor to continue working with the amendments to the forms and source code, also the same with the resource file. sometimes compile with the IDE, sometimes with personalized MiBuil.bat.
happens that I have a bad habit of Handle as if Visual Fox Pro
- Seguros2013Unicode.png (77.89 KiB) Viewed 11979 times
Posted: Wed Jun 26, 2013 8:16 pm
by EduardoLuis
Hi Rathi and Daniel:
I've tested interest under Window 7 32 bit and works ok.- (compiling & executing)
I suggest you to make this test: (i can't because i don't have your OS)
Compile your programs under Windows XP or Win 7 32 bits.-
Then test EXE file under Vista, Win 7 64 bit, and or Win 8 32/64 bit.-
I think the conflict is between compiler & OS.-
This it just a suggestion.-
With regards Eduardo.
Hola Rathi y Daniel:
He testeado "interest" en Window 7 32 bit y funciona perfectamente.- (compilacion y ejecución).-
Les sugiero hacer este test: (yo no puedo porque no tengo sus SO)
Compilen los programas bajo Windows XP o Win 7 32 bits.-
Luego testeen el archivo ejecutable bajo Vista, Win 7 64 y/o Win 8 32/64 Bits.-
Creo que el conflicto es entre el compilador de la versión 3.14 y el SO.-
Esta es una simple sugerencia.-
Cordialmente. Eduardo.-
Posted: Wed Jun 26, 2013 9:38 pm
EduardoLuis wrote:Hi Rathi and Daniel:
Eduardo : la aplicacion trabaja correctamente, estamos "hablando" del IDE.
en mi caso (win7 64) al intentar cambiar el lenguaje o el editor preferido pierde el contenido de estos 2 archivos INI.
no me habia dado cuenta que tambien elimina el contenido del archivo de configuracion .HBC y el de recursos .RC
esto no pasa con el IDE Ansi.
como ves en la imagen; en los proyectos creo diferentes carpetas para contener ordenadamente los distintos componentes del mismo.
tal cual me manejo con VFP y Free Pascal.
Posted: Wed Jun 26, 2013 9:54 pm
by EduardoLuis
Ok Daniel.
Yo no utilizo en IDE Unicode, tal vez por eso no advertí el error.- Disculpa que no haya interpretado correctamente el problema.-
Un abrazo. Eduardo
HMG 3.1.4 (Test)
Posted: Thu Jun 27, 2013 1:53 pm
Rathinagiri wrote:In my system IDE (unicode) empties the resource file and hbc files if I open any old ANSI project.
Does anybody come across the problem?
And
danielmaximiliano wrote:to me if I want to change the language or preferred editor, the IDE does crash and issues an error message, the solution was using Notepad + + open. INI and convert to UTF-8 w / BOM you that way if you open the IDE without no problem.
try to open the resource file and convert it that way I think is intact.
My suggestions for both cases, is to add a verification routine in IDE source for both files (.hbp and .ini) checking if is with FILESIZE() if is zero value then display a message to user, in other to avoid or advance these errors.
HMG 3.1.4 (Test)
Posted: Sat Jun 29, 2013 2:39 pm
New considerations and some others items have been redone at my re-edited message of:
http://hmgforum.com/viewtopic.php?p=27346#p27346
Dear colleagues Rathi and/or Claudio, can you comment all about it ? If these indications/changings would be good for next releases ?
HMG 3.1.4 (Test)
Posted: Sat Jun 29, 2013 2:56 pm
BuildLib.bat and BuilAllLib.bat, now has a new optional mode compiling, as shows image below:
- Screen.PNG (11.15 KiB) Viewed 11830 times
Thank you Dr. Soto for a further benefit !!!
Posted: Wed Jul 10, 2013 11:50 am
by radohabjan
Hello friends,
I'm testnig new version and for now I have just problem with special SL (Slovenian) characters in EDIT EXTEND function. Where can I correct this charachters or translations ?
br Rado
