Search string in EDITBOX
Hello,
I'm a member since october last year and rebuild (from Clipper 5.2.) some very large applications in HMG. It's working very fine!
Now I have a new challenge:
Is it possible to search for a string in a EDITBOX (filled up with memoRead) and if found to auto-select that piece of string in the EDITBOX (To show where in the EDITBOX the searchstring is found) ?
I have a TEXTBOX for the searchstring which activates a function with the AT() function so I can find the position but I don't know how to move the mouse to select>
Any body any idea?
Thx and greetings,
Any body any idea?
Thx and greetings,
Re: Search string in EDITBOX
Please consider this small sample.
local cText := 'LAWS RELATING TO WIRING, TEST, AND OPERATION:' + chr( 13 ) + chr( 10 ) + ;
'' + chr( 13 ) + chr( 10 ) + ;
'1. Any wire cut to length will be too short.' + chr( 13 ) + chr( 10 ) + ;
'2. Milliampermeters will be connected across the power source, voltmeters in series with it.' + chr( 13 ) + chr( 10 ) + ;
'3. The probability of an error in the schematic is directly proportional to the trouble it can cause.' + chr( 13 ) + chr( 10 ) + ;
'4. Identical units tested under identical conditions will not be identical on the final test after being buried under other components and wiring.' + chr( 13 ) + chr( 10 ) + ;
"5. A self starting oscillator won't." + chr( 13 ) + chr( 10 ) + ;
'6. A crystal oscillator will oscillate at the wrong frequency -- if it oscillates at all.'
define window ebs at 0, 0 width 400 height 300 main
define textbox search
row 10
col 10
width 200
end textbox
define button searchbutton
row 10
col 220
width 80
caption 'Search'
action doeditboxsearch()
end button
define editbox eb
row 40
col 10
width 380
height 200
value cText
end editbox
end window
ebs.center
ebs.activate
function doeditboxsearch
local cString := ebs.search.value
local cText := ebs.eb.value
local nStart := at( cString, cText )
if nStart > 0
TextBoxEditSetSel( 'ebs', 'eb', ( nStart - 1 ), ( nStart - 1 ) + len( cString ) )
ebs.eb.setfocus
return nil
function TextBoxEditSetSel( cParent, cControl, nStart, nEnd )
local nHandle := GetControlHandle( cControl, cParent )
TextBoxSetSel( nHandle, nStart, nEnd )
return nil
#pragma BEGINDUMP
#include <windows.h>
#include <commctrl.h>
#include "hbapi.h"
#include <wingdi.h>
HB_FUNC ( TEXTBOXSETSEL )
HWND hWnd1;
hWnd1 = (HWND) hb_parnl (1);
SendMessage((HWND) hWnd1,EM_SETSEL, (WPARAM)(int) hb_parni(2),(LPARAM) (int) hb_parni(3));
#pragma ENDDUMP
Thank you rathinagiri!
This works fine!
Now I can enhance it to make it Search->Next
Bye & thx,
This works fine!
Bye & thx,
Good idea!
But this functions needs to be improved:
1) Multiple 'founds'. Only the first string is found.
2) In a long textstring (76Kb) the searchstring is found but you have to scroll down for yourself....
Anybody?
Anybody?
Serge,
Can you please post a sample?
Hi rathinagiri,rathinagiri wrote:Hi,
Please consider this small sample.![]()
Nice sample!
I have made an improvement to support multiple find. in case someone needed it, code is below:
FUNCTION MAIN()
LOCAL cText := 'LAWS RELATING TO WIRING, TEST, AND OPERATION:' + Chr( 13 ) + Chr( 10 ) + ;
'' + Chr( 13 ) + Chr( 10 ) + ;
'1. Any wire cut to length will be too short.' + Chr( 13 ) + Chr( 10 ) + ;
'2. Milliampermeters will be connected across the power source, voltmeters in series with it.' + Chr( 13 ) + Chr( 10 ) + ;
'3. The probability of an error in the schematic is directly proportional to the trouble it can cause.' + Chr( 13 ) + Chr( 10 ) + ;
'4. Identical units tested under identical conditions will not be identical on the final test after being buried under other components and wiring.' + Chr( 13 ) + Chr( 10 ) + ;
"5. A self starting oscillator won't." + Chr( 13 ) + Chr( 10 ) + ;
// SET AUTOADJUST ON NOBUTTONS
cText := hb_MemoRead( "c:\hmg.3.0.46\changelog.txt" )
DEFINE WINDOW ebs At 0, 0 WIDTH 500 HEIGHT 300 MAIN
DEFINE TEXTBOX search
Row 10
Col 10
WIDTH 200
END TEXTBOX
DEFINE BUTTON SearchButton
Row 10
Col 220
WIDTH 80
CAPTION 'Search'
ACTION doeditboxsearch( .F. )
END BUTTON
DEFINE BUTTON ContinueSearch
Row 10
Col 310
WIDTH 80
CAPTION 'Find next'
ACTION doeditboxsearch( .T. )
END BUTTON
DEFINE EDITBOX eb
Row 40
Col 10
WIDTH 450
HEIGHT 200
VALUE cText
END EDITBOX
ebs.center
ebs.activate
FUNCTION doeditboxsearch( lFindNext )
STATIC nStartSearch := 0
LOCAL cString := ebs.search.value
LOCAL cText := ebs.eb.value
LOCAL nStart
hb_Default( @lFindNext, .F. )
IF ! lFindNext
nStartSearch := 0
nStart := hb_AtI( cString, cText, nStartSearch ) // case-insensitive search
IF nStart > 0
ebs.eb.setfocus
TextBoxEditSetSel( 'ebs', 'eb', ( nStart - 1 ), ( nStart - 1 ) + Len( cString ) )
nStartSearch := ( nStart ) + Len( cString ) -1
FUNCTION TextBoxEditSetSel( cParent, cControl, nStart, nEnd )
LOCAL nHandle := GetControlHandle( cControl, cParent )
#pragma BEGINDUMP
#include "hbapi.h"
#include <wingdi.h>
HWND hWnd1;
#pragma ENDDUM---------
1. EDITBOX control does not support auto-scrolling to the new found position. (setting CaretPos doesn't help scrolling.)
2. I have interchanged EDITBOX with RICHEDITBOX control that support auto-scrolling but.. i did notice a strange behaviour:
selected text is shifted some positions next to the found text. Try it yourself to see what i mean.
3. Tested with both hmg 3.0.46 and minigui extended. same results.
I hope someone may have an idea why it happens..
regards,
Pete
Rathinagiri,
Here is an example.
The first 3 'finds' of 'jaja' are visible, for the others you have to scroll down.
Here is an example.
- search.rar
- (1.71 KiB) Downloaded 417 times
Rathinagiri,
I enhanced your exemple with Find-Next
Serge_girard, see implemented to scroll caret editbox:
i think it is what you are looking for...
#define SILVER {204,204,204}
PUBLIC start
cInput_file := memoRead("BATCHOUT.TXT")
cEDIT := 'JAJA'
Start := 1
DEFINE WINDOW SEARCH AT 0, 0 WIDTH 600 HEIGHT 600 MAIN
ON KEY ESCAPE ACTION {SEARCH.Release}
@ 30,5 EDITBOX Edit_1 ;
WIDTH 550 ;
HEIGHT 500 ;
VALUE cInput_file ;
FONT "Courier New" ;
MAXLENGTH 255
@ 5,10 TEXTBOX T_SEARCH;
TOOLTIP 'Search' ;
WIDTH 150 ;
MAXLENGTH 20 ;
VALUE cEDIT ;
BACKCOLOR SILVER ;
FONTCOLOR BLUE BOLD ;
ON CHANGE Start_From_One()
@ 5,170 BUTTON bt_Search ;
CAPTION '&Search' ;
WIDTH 150 HEIGHT 22 ;
FONT 'Arial' SIZE 9 FLAT ;
ACTION { Search_Output(Start) } ;
DEFINE MAIN MENU
POPUP 'TEST'
ITEM 'TEST AT() ' //ACTION TEST_AT()
END POPUP
END MENU
CENTER WINDOW SEARCH
ACTIVATE WINDOW SEARCH
FUNCTION Start_From_One()
START = 1
FUNCTION Search_Output(xStart)
Local cEDIT_String := SEARCH.T_SEARCH.value
Local cText := memoRead("BATCHOUT.TXT") // SEARCH.Edit_1.value
Local nHandle := GetControlHandle("Edit_1","SEARCH")
cText := UPPER(ALLTRIM(cText))
cEDIT_String := UPPER(ALLTRIM(cEDIT_String))
nLN := LEN(cEDIT_String)
IF nStart := AT(cEDIT_String, cText ) > 0
lFND := .f.
FOR A = 1 TO LEN(cText) - nLN + 1
IF SUBSTR(cText, xStart, xStart + nLN - 1) = cEDIT_String
TextBoxEditSetSel( 'SEARCH', 'Edit_1', ( xStart - 1 ), ( xStart - 1 ) + LEN( cEDIT_String ) )
SEARCH.Edit_1.setfocus
lFND := .t.
EXIT
xStart++
NEXT A
IF !lFND
MSGINFO('NO MORE ' + cEDIT_String, 'ok')
xStart = 0
MSGINFO(cEDIT_String + ' NOT found', 'ok')
xStart = 0
ScrollCaret(nHandle)
Start := xStart + 1
RETURN nil
#pragma BEGINDUMP
#include "hbapi.h"
#include <wingdi.h>
HWND hWnd1;
HB_FUNC ( SCROLLCARET )
HWND hWnd = (HWND) hb_parnl (1);
SendMessage((HWND) hWnd,EM_SCROLLCARET,(WPARAM)(int) 1,(LPARAM)(int) 0);
#pragma ENDDUMPHMGing a better world
Pablo ,
This exactly what I was looking for and it all works very fine and fast!
Thx all !!
Thx all !!
