MySQL and HMG
Posted: Tue Mar 31, 2009 7:20 am
In answering about data corruption in another thread, this topic had emerged. All those posts made by me, are now grouped in a single thread here.
If you want I can give some udfs used by me to run all the queries and get the resulting table as an array.
1. connect2db(host,user,password,dbname) This is to connect to the database.
2. sql(dbo1,qstr) While running a SQL query. In this, dbo1 is the database object for connecting to the current database, qstr is the query string. This can be used to get data from the database via 'select' query. The table is returned as an array.
3. miscsql(dbo,qstr) For insert, delete, update commands. Returns .t. or .f.
3. While closing the db.
Note: We can not use all the types of variables as such inside a MySQL query. We have to parse the harbour value to MySQL type, by using a function called c2sql(value) (clipper to sql). This is already in the sql sample. Let this also been added to the user defined functions.
So, our insert query may be like this.
Select query may be like this.
We can get the automatically incremented number by "select last_insert_id()" query for further processing.
Regarding concurrent issue:
Every connection to the MySQL server is handled in a separate thread. The connection is exclusive and last_insert_id() would give different auto increment numbers to different persons in the same network according to their increment id.
So, in a Point on Sale terminal, if two persons push the save invoice button simultaneously, the server would give invoice number (if it is auto incremented) first come first serve basis and till now FYI, I had not got any problem in this.
If you want to be sure, it is safe if we have Begin Transaction ... End Transaction (if our transaction has multiple queries).
MySQL had virtually removed the multi-user and concurrency problems in my programs. And also, indexing.
Transaction processing is nothing to do with HMG. It is the work of MySQL.
We can send each statement as a SQL query like select all in one line, separated by ;.
This is the syntax for begin... end transaction. From MySQL manual:
example
In HMG we can send this like this.
With this, we can simultaneously save a transaction affecting two or more tables.
//dbo is a public variable holding the database object
FUNCTION connect2db(host,user,password,dbname)
dbo := tmysqlserver():new(AllTrim(host),AllTrim(user),AllTrim(password))
IF dbo:NetErr()
msginfo(dbo:ERROR())
RETURN nil
dbo:selectdb(dbname)
IF dbo:NetErr()
RETURN nil
//msginfo("Successfully Connected to the MySQL Server")
RETURN nil
function sql(dbo1,qstr)
local table := nil
local currow := nil
local tablearr := {}
local rowarr := {}
local curdateformat := set(_SET_DATEFORMAT)
local i := 0
local j := 0
set date ansi
table := dbo1:query(qstr)
set(_SET_DATEFORMAT,curdateformat)
if table:neterr()
msgstop(table:error())
table:destroy()
return tablearr
if table:lastrec() > 0
asize(tablearr,0)
for i := 1 to table:lastrec()
asize(rowarr,0)
currow := table:getrow(i)
for j := 1 to table:fcount()
aadd(rowarr,currow:fieldget(j))
next j
aadd(tablearr,aclone(rowarr))
next i
table:destroy()
return tablearr
return tablearr
function miscsql(dbo,qstr)
local curdateformat := set( _SET_DATEFORMAT)
set date ansi
table := dbo:query(qstr)
set( _SET_DATEFORMAT,curdateformat)
if table:NetErr()
msgstop(table:ERROR())
table:destroy()
return .f.
table:destroy()
return .t.
dbo:destroy()
function C2SQL(Value)
local cValue := ""
local cFormatoDaData := set(4)
do case
case Valtype(Value) == "N"
cValue := AllTrim(Str(Value))
case Valtype(Value) == "D"
if !Empty(Value)
// MySQL dates are like YYYY-MM-DD
if cFormatoDaData = 'mm-dd-yyyy' // USA
cValue := "'"+PadL(Month(Value), 2, "0") + '-'+ PadL(Day(Value), 2, "0") + "-" + Str(Year(Value), 4) + "'"
elseif cFormatoDaData = 'dd/mm/yyyy' // BRITISH ou FRENCH
cValue := "'"+PadL(Day(Value), 2, "0") + "/" + PadL(Month(Value), 2, "0") + "/" + Str(Year(Value), 4) + "'"
elseif cFormatoDaData = 'yyyy.mm.dd' // ANSI
cValue := "'"+Str(Year(Value), 4) + "." + PadL(Month(Value), 2, "0") + "." + PadL(Day(Value), 2, "0") + "'"
elseif cFormatoDaData = 'dd.mm.yyyy' //GERMAN
cValue := "'"+PadL(Day(Value), 2, "0") + "." + PadL(Month(Value), 2, "0") + "." + Str(Year(Value), 4) + "'"
elseif cFormatoDaData = 'dd-mm-yyyy' //ITALIAN
cValue := "'"+PadL(Day(Value), 2, "0") + "-" + PadL(Month(Value), 2, "0") + "-" + Str(Year(Value), 4) + "'"
elseif cFormatoDaData = 'yyyy/mm/dd' //JAPAN
cValue := "'"+Str(Year(Value), 4) + "/" + PadL(Month(Value), 2, "0") + "/" + PadL(Day(Value), 2, "0") + "'"
elseif cFormatoDaData = 'mm/dd/yyyy' // AMERICAN
cValue := "''"
case Valtype(Value) $ "CM"
IF Empty( Value)
cValue="''"
cValue := "'"
Value:=DATATOSQL(value)
cValue+= value+ "'"
case Valtype(Value) == "L"
cValue := AllTrim(Str(iif(Value == .F., 0, 1)))
otherwise
cValue := "''" // NOTE: Here we lose values we cannot convert
endcase
return cValue
qsuccess := miscsql(dbo,"insert into table1 (name, address1,city) values ("+c2sql(form1.name1.value)+","+c2sql(form1.address1.value)+","+c2sql(form1.city.value)+")")
tablearray := sql(dbo,"select * from table1 where city = "+c2sql(form1.city.value))
No. It is the id which can be received only after the insertion. If you want to know that id for any further processing, you can get. That's all.So, can I store "select last_insert_id()" into temporary code and insert that temporary code into table?
START TRANSACTION, COMMIT, and ROLLBACK Syntax
START TRANSACTION | BEGIN [WORK]
COMMIT [WORK] [AND [NO] CHAIN] [[NO] RELEASE]
ROLLBACK [WORK] [AND [NO] CHAIN] [[NO] RELEASE]
SET AUTOCOMMIT = {0 | 1}
START TRANSACTION;
SELECT @A:=SUM(salary) FROM table1 WHERE type=1;
UPDATE table2 SET summary=@A WHERE type=1;
COMMIT;
qsuccess := miscsql(dbo,"START TRANSACTION;SELECT @A:=SUM(salary) FROM table1 WHERE type=1;UPDATE table2 SET summary=@A WHERE type=1;COMMIT;")
