Someone saved a pdf file into a mysql blob field
martingz
Post by martingz »
I need to save a pdf file to a mysql blob field, the file could be anywhere, hard disk, CD, network, etc.
what I can do with pictures, but now they occurred it was better a PDF
thanks for your attention
Re: Someone saved a pdf file into a mysql blob field
martingz
Post by martingz »
Yes rathi but my blob field is empty, with images works fine
tnx
Had you tried load_file() mysql function?
When I ran the following queries it worked.
For saving pdf file into blob col
insert into test1 ( pdf_col ) values ( load_file( 'd:/sample.pdf' ) )
For saving pdf file from blob col
select pdf_col from test1 INTO DUMPFILE 'd:/samplecopy.pdf'
martingz
Post by martingz »
I've seen it, but the client does not have access to the server and to use the load_file must be the file on the server
continue to seek a solution
in php you add "/" to load a pdf file
regrads
martingz
Post by martingz »
My partner find the solution for save a pdf into blob field
my partner found the solution to save a pdf on a blob field
you just have to base64 encode and save pdf
cbuff:=hb_base64encode(cbuff)
and to write the pdf
hb_base64decode(oRow:fieldGet("contenido"))
I hope this is useful
Regrads
Thanks a lot for that.
