Harbour MiniGUI 2.7.1
Re: Harbour MiniGUI 2.7.1
Roberto Lopez wrote: ...
You can drag an item to the first position without problems.
Sorry, very sorry; you are right.
Mistaken by hasting :(
The problem is only for AFTER last item. That isn't ADDING/APPENDING, no INSERTING ?
Best Regards
esgici wrote: The problem is only for AFTER last item. That isn't ADDING/APPENDING, no INSERTING ?
I've avoided move an item to the last position because WIN32 function DrawInsert is unable to draw the insertion mark for the last item.
Anyway I'm considerig to allow this (even when the marker is not shown) due the 'popular demand' :)
Please remove the lines I've indiceted in h_windows.prg and test it.
And (as I've said to Sudip) If you eliminate the indicated lines in 'h_windows.prg' you'll be able to drag above the last item.
Please, test again.
Tested. The result is exactly what you say: (even when the marker is not shown) ADDING / APPENDING become possible.
BTW, since this isn't INSERTING, we can assume that Win32 is correct, by don't allow to draw the insertion mark for the last item :)
Anyway now we have possibility to changing position of any item to anywhere in LISTBOX by dragging it.
Thanks a lot.
Best Regards
esgici wrote: BTW, since this isn't INSERTING, we can assume that Win32 is correct, by don't allow to draw the insertion mark for the last item :)
Yes. This was my thinking, but I'm reviewing my decision.
This could be solved using a 'dirty trick' such as adding an empty item to the end of the list while dragging, but it could be not easy to fine-tune.
gfilatov wrote: I'm sorry for a bugreport about This.cellValue bug again but you've missed an underline symbol in the function name at my correction of this problem.
And... we missed other huge bugs in the same routine.
We forgot the possibility to specify a date or numeric textbox.
So, the (right?) code is as follows :) :
(Please, let me know if I've forgot something again).
Procedure _HMG_SetGridCellEditValue ( arg )
	IF	ValType ( arg ) == 'C'
		SetProperty ( "_hmg_grid_inplaceedit" , "t" , "value" , arg )
	ELSEIF	ValType ( arg ) == 'D'
		If _IsControlDefined ( 't' , "_hmg_grid_inplaceedit")
		ElseIf _IsControlDefined ( 'd' , "_hmg_grid_inplaceedit")
			SetProperty ( "_hmg_grid_inplaceedit" , "d" , "value" , arg )
		EndIf
	ELSEIF	ValType ( arg ) == 'N'
		If _IsControlDefined ( 'c' , "_hmg_grid_inplaceedit")
			SetProperty ( "_hmg_grid_inplaceedit" , "c" , "value" , arg )
		ElseIf _IsControlDefined ( 's' , "_hmg_grid_inplaceedit")
			SetProperty ( "_hmg_grid_inplaceedit" , "s" , "value" , arg )
		ElseIf _IsControlDefined ( 't' , "_hmg_grid_inplaceedit")
		EndIf
	ELSEIF	ValType ( arg ) == 'L'
return
TIA.
Grigory,
I've tested the new (fixed) code with this sample:
#include "minigui.ch"
Local aRows [20] [3]
	Private fColor := { || if ( This.CellRowIndex/2 == int(This.CellRowIndex/2) , { 0,0,255 } , { 0,255,0 } ) }
	DEFINE WINDOW Form_1 ;
		WIDTH 640 ;
		HEIGHT 400 ;
		TITLE 'Mixed Data Type Grid Test' ;
		MAIN
		DEFINE MAIN MENU
			DEFINE POPUP 'File'
				MENUITEM 'Set Item'	ACTION SetItem()
				MENUITEM 'Get Item'	ACTION GetItem()
			END POPUP
		END MENU
		aRows [1]	:= {113.12,date(),1,1 , .t. }
		aRows [2]	:= {123.12,date(),2,2 , .f. }
		aRows [3]	:= {133.12,date(),3,3, .t. }
		aRows [4]	:= {143.12,date(),1,4, .f. }
		aRows [5]	:= {153.12,date(),2,5, .t. }
		aRows [6]	:= {163.12,date(),3,6, .f. }
		aRows [7]	:= {173.12,date(),1,7, .t. }
		aRows [8]	:= {183.12,date(),2,8, .f. }
		aRows [9]	:= {193.12,date(),3,9, .t. }
		aRows [10]	:= {113.12,date(),1,10, .f. }
		aRows [11]	:= {123.12,date(),2,11, .t. }
		aRows [12]	:= {133.12,date(),3,12, .f. }
		aRows [13]	:= {143.12,date(),1,13, .t. }
		aRows [14]	:= {153.12,date(),2,14, .f. }
		aRows [15]	:= {163.12,date(),3,15, .t. }
		aRows [16]	:= {173.12,date(),1,16, .f. }
		aRows [17]	:= {183.12,date(),2,17, .t. }
		aRows [18]	:= {193.12,date(),3,18, .f. }
		aRows [19]	:= {113.12,date(),1,19, .t. }
		aRows [20]	:= {123.12,date(),2,20, .f. }
		@ 10,10 GRID Grid_1 ;
			WIDTH 620 ;
			HEIGHT 330 ;
			HEADERS {'Column 1','Column 2','Column 3','Column 4','Column 5'} ;
			WIDTHS {140,140,140,140,140} ;
			ITEMS aRows ;
			EDIT ;
			COLUMNCONTROLS { {'TEXTBOX','NUMERIC','$ 999,999.99'} , {'DATEPICKER','DROPDOWN'} , {'COMBOBOX',{'One','Two','Three'}} , { 'SPINNER' , 1 , 20 } , { 'CHECKBOX' , 'Yes' , 'No' } } ;
			DYNAMICFORECOLOR { fColor , fColor, fColor, fColor, fColor } ;
			COLUMNVALID 	{ ;
					{ || Test1() }	,	;
					{ || Test2() }	,	;
					{ || Test3() }	,	;
					{ || Test4() }	,	;
					{ || Test5() }		;
	CENTER WINDOW Form_1
	ACTIVATE WINDOW Form_1
PROCEDURE SETITEM()
	Form_1.Grid_1.Item (2) := { 123.45 , date() , 2 , 10 , .T. }
PROCEDURE GETITEM()
local a
	a := Form_1.Grid_1.Item (2)
	msginfo ( str ( a [1] )				, '1' )
	msginfo ( dtoc ( a [2] )			, '2' )
	msginfo ( str( a [3] )				, '3' )
	msginfo ( str ( a [4] )				, '4' )
	msginfo ( if ( a [5] == .t. , '.t.' , '.f.' )	, '5' )
procedure test1()
	If This.CellValue == 0
		This.CellValue := 999
	EndIf
return
procedure test2()
	If Year (This.CellValue) <> 2009
		This.CellValue := Date()
	EndIf
return
procedure test3()
	If This.CellValue == 3
		This.CellValue := 1
	EndIf
return
procedure test4()
	If This.CellValue == 1
		This.CellValue := 9
	EndIf
return
procedure test5()
	If This.CellValue == .F.
		This.CellValue := .T.
	EndIf
return
Please, let me know if you find a problem.
TIA.
Roberto Lopez wrote:Grigory,
Roberto,
Thanks a lot. It works OK now. :!:
I've done this function in such way:
PROCEDURE _SetGridCellEditValue ( arg )
   LOCAL FormName := "_hmg_grid_inplaceedit"
   LOCAL ControlName
   SWITCH ValType ( arg )
	CASE 'C'
		ControlName := Iif( _IsControlDefined ( "t" , FormName ), "t", Nil )
		Exit
	CASE 'D'
		ControlName := Iif( _IsControlDefined ( "d" , FormName ), "d", ;
			Iif( _IsControlDefined ( "t" , FormName ), "t", Nil ) )
		Exit
	CASE 'N'
		ControlName := Iif( _IsControlDefined ( "c" , FormName ), "c", ;
			Iif( _IsControlDefined ( "s" , FormName ), "s", ;
			Iif( _IsControlDefined ( "t" , FormName ), "t", Nil ) ) )
		Exit
	CASE 'L'
		ControlName := Iif( _IsControlDefined ( "c" , FormName ), "c", Nil )
   END
   IF ISCHARACTER( ControlName )
      SetProperty ( FormName , ControlName , "value" , arg )
      MsgMiniGuiError ( "CellValue replace: type mismatch. Program Terminated" )
gfilatov wrote: Thanks a lot. It works OK now. :!:
Thanks for your help on this.
Regarding to your implementation, is very interesting the way you handles the error on data type.
Anyway, maybe I use a different approach, since I don´t like SWITCH too much :)
gfilatov wrote: I've done this function in such way:
May be a little problem with error checking.
Please consider the following:
When you assign a character type to a numeric textbox column, error checking will fail since a control named 't' exists, so, no error will be generated (please, correct me if I'm wrong).
Perhaps, the error checking should be based on COLUMNCONTROLS array.
Roberto Lopez wrote: May be a little problem with error checking.
Hi Roberto,
I'm glad to see you in this forum.
Many thanks for your remark. You are right, of course.
I've adde the following verify condition in the function:
	CASE 'C'
		ControlName := Iif( _IsControlDefined ( "t" , FormName ) .and. ;
			!(ValType ( _GetValue ( "t" , FormName ) ) == "N"), "t", Nil )
		Exit
