Problema con HaruPDF
Re: Acentuação com a hmg_hpdf
Actually, what is your problem?
HASA
Post by HASA »
Colega nesse post você encontrará um imagem do problema, as palavras com acentuação saem se acentuacao, veja:
Colega, en este post encontrarás una imagen del problema, las palabras vienen con acentuación acentuación, ver:
viewtopic.php?f=40&t=2903
HASA
:P
IMATECH
Post by IMATECH »
Hi Hasa !
Did you try to use:
hb_OEMtoANSI( string )
If fail: Send a small sample in a reply
ps: if possible, make your posts in english :)
http://translate.google.com
M., Ronaldo
By: IMATECH
Imation Tecnologia
HASA
Post by HASA »
Colleague in this post you'll find an image of the problem, the words come up with accentuation accentuation, see:
:oops:
HASA
IMATECH
Post by IMATECH »
Did you try to use:
M., Ronaldo
By: IMATECH
Imation Tecnologia
HASA
Post by HASA »
Ronaldo did not?
:cry:
IMATECH
Post by IMATECH »
Are you using hmg 3.046 ( over this will not work ) ?
Context Editor using ansi or unicode for .prg files ?
*** DOS: change to ansi/win1252
Direct use of hbhpdf works fine on all my tests
M., Ronaldo
By: IMATECH
Imation Tecnologia
HASA
Post by HASA »
:D
Thanks for the tip;
Hasa
Oi Hasa,
Você resolveu o seu problema ?
Hi Hasa,
Did you solved you problem ?
HASA
Post by HASA »
Bom dia, Pablo na verdade NÃO, como utilizo a Minigui Extend nos exemplos de lá tbm tem o mesmo problema, mas... o interessante é que utilizo a impressão de DANFE via a HbNfe e não tenho problemas com acentuação. É que achei muito mais simples utilizar essa dica que é bem parecida com a sintaxe da MINIPRINT o da HbNfe é mais complexo porem acentua sem problemas. Obrigado pela pergunta.
HASA
Good morning, Pablo actually NOT like to use MiniGUI Extend the examples there TBM has the same problem, but ... the interesting thing is that I use to print DANFE saw HbNfe and have no problems with accents. It is thought that much simpler to use this tip which is very similar to the syntax of the Miniprint HbNfe is more complex however accentuates smoothly. Thanks for the question.
HASA
