How to Avoid Data Corruption
I am facing problems regarding data corruption in .dbf files, both in multi-user and single-user mode. The corruption mainly occurs in my old VFP apps (here I am not asking help for another software tool). Is it due to .dbf files or the software tool I used.
I am asking for help because, I should know it before creating my future apps on .dbf files.
If I use MySql, will the data corruption be reduced? (I saw numerous databases with SQL Server have data corruption)
If the answer is Yes, then can my app easily create tables, indexes etc., and ability to change their structure on the fly (as they currently do with .dbf)?
Re: How to Avoid Data Corruption
Data corruption, by saying, you mean because of power shutdown, program crash or what?
In my few years experience, MySQL is doing well. We can activate auto backup of critical data that would be stored in a separate place in regular intervals.
Hi Rathi,
I just expected your message :) Thanks a lot!
I really don't know from where those evils come. But, I see some junk characters inside my clients tables !!! ;( And they ruin the database temporarily! Whole system is halted and required "my" "VALUED" presence at client's site!!!
Very good :) I know very little about MySql. I tried 3 examples given with HMG 2.6.7. I liked 2nd one (1st example is thorough, but I don't know Spanish!!!). Now, I must have a serious try on MySql.
If you want I can give some udfs used by me to run all the queries and get the resulting table as an array.
1. connect2db(host,user,password,dbname) This is to connect to the database.
//dbo is a public variable holding the database object
FUNCTION connect2db(host,user,password,dbname)
dbo := tmysqlserver():new(AllTrim(host),AllTrim(user),AllTrim(password))
IF dbo:NetErr()
   msginfo(dbo:ERROR())
   RETURN nil
dbo:selectdb(dbname)
IF dbo:NetErr()
   RETURN nil
//msginfo("Successfully Connected to the MySQL Server")
RETURN nil
2. sql(dbo1,qstr) While running a SQL query. In this, dbo1 is the database object for connecting to the current database, qstr is the query string. This can be used to get data from the database via 'select' query. The table is returned as an array.
function sql(dbo1,qstr)
local table := nil
local currow := nil
local tablearr := {}
local rowarr := {}
local curdateformat := set(_SET_DATEFORMAT)
set date ansi
table := dbo1:query(qstr)
set(SET_DATEFORMAT,curdateformat)
if table:neterr()
   msgstop(table:error())
   table:destroy()
   return tablearr
   if table:lastrec() > 0
      asize(tablearr,0)
      for i := 1 to table:lastrec()
         asize(rowarr,0)
         currow := table:getrow(i)
         for j := 1 to table:fcount()
            aadd(rowarr,currow:fieldget(j))
         next j
         aadd(tablearr,aclone(rowarr))
      next i
   table:destroy()
   return tablearr
return tablearr
3. miscsql(dbo,qstr) For insert, delete, update commands. Returns .t. or .f.
function miscsql(dbo,qstr)
local curdateformat := set( _SET_DATEFORMAT)
set date ansi
table := dbo:query(qstr)
set( _SET_DATEFORMAT,curdateformat)
if table:NetErr()
    msgstop(table:ERROR())
    table:destroy()
    return  .f.
table:destroy()
return .t.
3. While closing the db.
dbo:destroy()
Note: We can not use all the types of variables as such inside a MySQL query. We have to parse the harbour value to MySQL type, by using a function called c2sql(value) (clipper to sql). This is already in the sql sample. Let this also been added to the user defined functions.
function C2SQL(Value)
   local cValue := ""
    local cFormatoDaData := set(4)
   do case
      case Valtype(Value) == "N"
         cValue := AllTrim(Str(Value))
      case Valtype(Value) == "D"
         if !Empty(Value)
            // MySQL dates are like YYYY-MM-DD
            if cFormatoDaData = 'mm-dd-yyyy' // USA
            cValue := "'"+PadL(Month(Value), 2, "0") + '-'+ PadL(Day(Value), 2, "0") + "-" + Str(Year(Value), 4) + "'"
            elseif  cFormatoDaData = 'dd/mm/yyyy' // BRITISH ou FRENCH
            cValue := "'"+PadL(Day(Value), 2, "0") + "/" + PadL(Month(Value), 2, "0") + "/" + Str(Year(Value), 4) + "'"
            elseif cFormatoDaData = 'yyyy.mm.dd' // ANSI
            cValue := "'"+Str(Year(Value), 4)  + "." + PadL(Month(Value), 2, "0") + "." + PadL(Day(Value), 2, "0") + "'"
            elseif cFormatoDaData = 'dd.mm.yyyy' //GERMAN
            cValue := "'"+PadL(Day(Value), 2, "0") + "." + PadL(Month(Value), 2, "0") + "." + Str(Year(Value), 4) +  "'"
            elseif cFormatoDaData = 'dd-mm-yyyy'  //ITALIAN
            cValue := "'"+PadL(Day(Value), 2, "0") + "-" + PadL(Month(Value), 2, "0") + "-" + Str(Year(Value), 4)  + "'"
            elseif cFormatoDaData = 'yyyy/mm/dd' //JAPAN
            cValue := "'"+Str(Year(Value), 4)  + "/" + PadL(Month(Value), 2, "0") + "/" + PadL(Day(Value), 2, "0") + "'"
            elseif cFormatoDaData = 'mm/dd/yyyy' // AMERICAN
            cValue := "''"
      case Valtype(Value) $ "CM"
         IF Empty( Value)
            cValue="''"
            cValue := "'"
            Value:=DATATOSQL(value)
            cValue+= value+ "'"
      case Valtype(Value) == "L"
         cValue := AllTrim(Str(iif(Value == .F., 0, 1)))
      otherwise
         cValue := "''"       // NOTE: Here we lose values we cannot convert
   endcase
return cValue
So, our insert query may be like this.
qsuccess := miscsql(dbo,"insert into table1 (name, address1,city) values ("+c2sql(form1.name1.value)+","+c2sql(form1.address1.value)+","+c2sql(form1.city.value)+")")
Select query may be like this.
tablearray := sql(dbo,"select * from table1 where city = "+c2sql(form1.city.value))
Hi Rathi,
I don't know, how can I show my gratitude to you? :)
Thank you very much. Your code will be extremely helpful to me.
So, I am starting my MySql "mission" right now!!! (you know this is the busiest time for Indian programmers - end of the fiscal year and beginning of a new fiscal year!!!)
With my best regards.
With pleasure Sudip.
I found an error during adding record in \Samples\Mysql\Demo_2
It shows following error message during insert.
I solved the problem. The "code" column of Names table is AUTO_INCREMENT. So we should not pass value of "code" during insertion.
Previously code was:
If status == 1
  cQuery := "INSERT INTO NAMES  VALUES ( '"+cCode+"' , '"+ AllTrim(cName)+"' , '"+cEmail+ "' ) "
Else
  cQuery := "UPDATE NAMES SET  Name = '"+cName+"' , eMail = '"+cEMail+"'  WHERE CODE = " + AllTrim(gCode)
Endif
I modified:
If status == 1
  cQuery := "INSERT INTO NAMES (Name, eMail)  VALUES ( '"+AllTrim(cName)+"' , '"+cEmail+ "' ) "
Else
Endif
Yes. And you can get the automatically incremented number by "select last_insert_id()" query for further processing.
Hi Rathi,
I am sharing Sudip's sentiments, me too am very thankful to all your valuable contributions, guidances and helps.
This your MySQL guidance will be a good starting way for me too.
Thanks a lot.
