Autofill?
Leopoldo Blancas
Autofill?
Post by Leopoldo Blancas »
Hola a todos...
He tratado desde ayer hacer que AutoFill (TextBox) se llene automáticamente y no lo he logrado... no se puede llenar de inicio?
Hi all ...
I've been trying since yesterday to make AutoFill (TextBox) automatically fills and I have not been ... not be filled home?
              AutoFill in Text Box try
              Started by Esgici
              Enhanced by Roberto Lopez and Rathinagiri
              2009.05.10
    */        #include "hmg.ch"
              #include "hfcl.ch"
            PROC Main()
               aCountries := HB_ATOKENS( MEMOREAD( "Countries.lst" ),   CRLF )
               ASORT( aCountries )                    // This Array MUST be sorted
               DEFINE WINDOW frmAFTest ;
                  WIDTH  550 ;
                  HEIGHT 300 ;
                  TITLE 'AutoFill in Text Box try (BE2)' ;
                  ON INIT Llena();
                  MAIN
                  ON KEY ESCAPE ACTION frmAFTest.Release
                  DEFINE LABEL lblCountry
                     ROW        50
                     COL        50
                     VALUE      "Country :"
                     RIGHTALIGN .T.
                     AUTOSIZE   .T.
                  END LABEL // lblCountry
                  DEFINE TEXTBOX txbCountry
                     ROW         48
                     COL         110
                     ONCHANGE    AutoFill( aCountries )
                     ONGOTFOCUS  AFKeySet( aCountries )
                     ONLOSTFOCUS AFKeyRls(  )
                  END TEXTBOX // txbCountry
               END WINDOW // frmAFTest
               frmAFTest.Center
               frmAFTest.Activate
            RETU // Main()
            PROCEDURE Llena()
*               frmAFTest.txbCountry.VALUE := aCountries[1]
*               frmAFTest.txbCountry.VALUE := 'hOLA'
               SetProperty ( 'frmAFTest','txbCountry','VALUE', aCountries[1] )
Aquí quiero asignarle el valor al TextBox pero no logro hacerlo, ya hice pruebas con textbox normales y si lo hace.
Alguna idea?
Polo
Here I want to assign value to TextBox but I can not do it, because I tested with normal textbox does.
Any idea?
Polo
Leopoldo Blancas
Re: Autofill?
hola
Re: Autofill?
Leopoldo Blancas wrote:hola
Polo: se te olvido adjuntar todo el ejemplo completo..
Re: Autofill?
Hola Polo
The "primitive" author of Autofill could not be able to predict that one day you will ask something like this ;)
Used VALUE property of TEXTBOX instead of ON INIT procedure; and Autofill.prg slightly modified.
( maybe one day even win the formality of this change )
PROC Main()
      WIDTH  550 ;
      HEIGHT 300 ;
      TITLE 'AutoFill in Text Box try (BE3)' ;
      MAIN
         ROW        50
         COL        50
         VALUE      "Country :"
         RIGHTALIGN .T.
         AUTOSIZE   .T.
         ROW         48
         COL         110
         VALUE       aCountries[1]
   frmAFTest.Center
   frmAFTest.Activate
RETU // Main()
*-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.
PROC AutoFill( ;              // Auto filling text box
                aList,;       // Items list
                nCaller,;     // NIL : OnChange, 1: UP, 2: Down
                cControlName )
   STATIC cLastVal := '',;
          n1Result := 0
   LOCAL  cFrmName  := '',;
          cTxBname  := '',;
          cTxBValue := '',;     // Text Box Value
          nCarePos  := 0,;  // Text Box CaretPos
          cCurval   := ''
   cFrmName := thiswindow.name
   if pcount() == 3
      cTxBName := cControlName
      cTxBName := this.name
   cTxBValue := GetProperty( cFrmName, cTxBName, "Value" )     // Text Box Value
   nCarePos  := GetProperty( cFrmName, cTxBName, "CaretPos" )  // Text Box CaretPos
   nCarePos := MAX( nCarePos, LEN( TRIM( cTxBValue ) ) )
   IF HB_ISNIL( nCaller )
      IF !( cLastVal == cTxBValue )
         cCurval  := LEFT( cTxBValue, nCarePos )
         IF !EMPTY( cCurval )
            n1Result := ASCAN( aList, { | c1 | UPPER( LEFT( c1, LEN( cCurval ) ) ) == UPPER( cCurval )} )
            IF n1Result > 0
               cCurval := aList[ n1Result ]
            ENDIF n1Result > 0
         ENDIF !EMPTY( cCurval )
         cLastVal := cCurval
         AF_Apply( cFrmName, cTxBName, cCurval, nCarePos )
      ENDIF cLastVal # cCurval
      IF n1Result > 0
         IF nCaller < 2
            n1Result -= IF( n1Result > 1, 1, 0 )
            n1Result += IF( n1Result < LEN( aList ), 1, 0 )
         cLastVal := cCurval
      ENDIF n1Result > 0
   ENDIF HB_ISNIL( nCaller )
RETU // AutoFill()
PROC AF_Apply( ;
               cFrmName,;
               cTxBName,;
               cValue,;
               nPosit )
   SetProperty( cFrmName, cTxBName, "Value", cValue )
   SetProperty( cFrmName, cTxBName, "CaretPos", nPosit )
RETU // AF_Apply()
PROC AFKeySet(;
               aitems )
   Local cFrmName := thiswindow.name,;
   ON KEY UP   OF &cFrmName  ACTION AutoFill(  aitems, 1, cTxBName )
   ON KEY DOWN OF &cFrmName  ACTION AutoFill(  aitems, 2, cTxBName )
RETU // AFKeySet()
PROC AFKeyRls( )
   RELEASE KEY UP   OF &cFrmName
   RELEASE KEY DOWN OF &cFrmName
RETU // AFKeyRls()
Leopoldo Blancas
Re: Autofill?
Hola a todos...
Gracias por contestar...
Pero mi aplicación se trata de asignarle profesor a un grupo de una escuela, por ejemplo, al ir tecleando su nombre y guardarlos en una dbf, pero a la hora de consultar los grupos y saber a quien se le dio los grupos Autofill no permite ingresar valores guardados de una DBF, y yo pensé que era normal como un texbox..... Bueno probare su ejemplo... gracias.
Polo
Hi all ...
Thanks for answering ...
But my application is a professor assign a school group, for example, to go by typing its name and save it to a dbf, but when consulting groups and know who gave Autofill groups can not enter values ​​stored in a DBF, and I thought it was normal as a texbox ..... Well proves his example ... Thank you.
Polo
Leopoldo Blancas
Re: Autofill?
Hola...
Ya probe tu ejemplo Mr. Esgici y ya me aparecen los valores, pero ahora cuando quiero modificarlos ya no hace el Autofill... correctamente...
Alguna solución ???
Polo
Hello ...
Since Mr. Esgici probe your example and I already listed the values​​, but now when I want to modify the Autofill no longer ... correctly ...
Any solution???
Polo
Re: Autofill?
Leopoldo Blancas wrote:... but now when I want to modify the Autofill no longer ...
why ?
what is the problem ?
Re: Autofill?
...and Autofill.prg slightly modified.
( maybe one day even win the formality of this change )...
Now, I'm not sure that my modification on AutoFill.prg is proper :?
