Error in Graph_4 Sample
I don't know whether it is an error or normal behavior, in pie chart when one of the value become 0 pie chart shows wrong result. Please note following code. I changed graph_4 sample to show the problem. Please compile and run and see what happens ;) Please check pie chart with data values!!!
#include "minigui.ch"
function main
	define window m at 0,0 width 800 height 600 main On Init ShowPie() backcolor { 255,255,255}
		define button x
			row 10
			col 10
			caption "Draw"
			action showpie()
		end button
		Define Button Button_1
			Row	10
			Col	150
			Caption	'Print'
			Action PRINT GRAPH OF m PREVIEW DIALOG
		End Button
	end window
	m.center
	m.activate
return nil
function showpie
ERASE WINDOW m
DRAW GRAPH IN WINDOW m AT 100,100;
      TO 500,500 ;
      TITLE "Sales" ;
      TYPE PIE;
      ; //SERIES {1500,1800,200,500,800};
      SERIES {1500,1800,0,500,800};
		DEPTH 25;
		SERIENAMES {"Product 1","Product 2","Product 3","Product 4","Product 5"};
		COLORS {{255,0,0},{0,0,255},{255,255,0},{0,255,0},{255,128,64},{128,0,128}};
		3DVIEW;
		SHOWXVALUES;
		SHOWLEGENDS NOBORDER
return nil
I faced the problem in front of one of my very good clients!
Please check the problem.
Re: Error in Graph_4 Sample
Hi Sudip
sudip wrote:
... in pie chart when one of the value become 0 pie chart shows wrong result.
Perhaps you are right, we have a problem in TYPE PIE GRAPH.
No when one of SERIES values become zero, but when its percentage become very little, close to zero. F.e in your example result is correct when the third value 7 ( %0.28), 6 (%0.00)is not.
If you are sure that this is a bug please write to Sourceorge HMG bug tracker.
Very bad :( That means before deeply tested we have don't give anything to client !
Hi Sudip
I guess you need an urgent solution though temporary.
First, a question : What we want see in a graph when some values are very close to zero ?
My answer is "simply nothing".
If you too would agree, my suggestion is :
Here modified version of function showpie and added a little one.
function showpie
aValues := { 1500, 1800, 0, 500, 800 }
aPNames := {"Product 1","Product 2","Product 3","Product 4","Product 5"}
aColors := { BLUE, RED, FUCHSIA, BROWN, GREEN }
PGNormlz( aValues, aPNames, aColors )
ERASE WINDOW m
      TO 500,500 ;
      TITLE "Sales" ;
      TYPE PIE;
      SERIES aValues ;
      DEPTH 25;
      SERIENAMES aPNames ;
      COLORS aColors ;
      3DVIEW;
      SHOWXVALUES ;
return nil
PROC PGNormlz( aValues, aNames, aColors )      // Normalizing Pie Graph values
   LOCAL nIndice := 0,;
         n1Value := 0,;
         nTotal  := 0
   AEVAL( aValues, { | n1Value | nTotal += n1Value } )
   FOR nIndice := 1 TO LEN( aValues )
      n1Value  := aValues[ nIndice ]
      nPercent := n1Value * 100 / nTotal
      IF nPercent < .016
         ADEL( aValues, nIndice )
         ASIZE( aValues, LEN( aValues ) - 1 )
         ADEL( aNames, nIndice )
         ASIZE( aNames, LEN( aNames ) - 1 )
         ADEL( aColors, nIndice )
         ASIZE( aColors, LEN( aColors ) - 1 )
RETU // PGNormlz()
I hope this help you.
Esgici,
Thanks a lot. It works! But I can surely tell you after several testing!
Hi Esgici,
Thanks for the very quick correction. I tested with the code. It is all right!! Yesterday I tried something similar in front of my client. But I checked with 0.00 not with 0.016 like you did in your sample.
Thank you very much.
esgici wrote:Hi Sudip
function showpie
ERASE WINDOW m
      TO 500,500 ;
      TITLE "Sales" ;
      TYPE PIE;
      SERIES aValues ;
      DEPTH 25;
      COLORS aColors ;
      3DVIEW;
      SHOWXVALUES ;
return nil
         n1Value := 0,;
         nTotal  := 0
      IF nPercent < .016
RETU // PGNormlz()
Very smart solution!
Thanks.
If you allow it, I'll include your code as part of DrawPieGraph() function as a permanent fix.
Hello Roberto
If you allow it, ...
Please don't blush me :oops:
Everything is for community; Viva Clipper, Viva Harbour, Viva HMG :!: :!: :!:
It isn't ?
With Best Regards
Anyway, I'll review the code and if a more 'elegant' solution (showing the reference for 'zero' series) arises, I'll apply it.
Roberto Lopez wrote: Anyway, I'll review the code and if a more 'elegant' solution ...
IMHO this will be better. Problem isn't only can't show serie value close to zero; when it is, this very little value cause a bigger problem : their "pie" overlay another pie.
Best regards
Best regards
Well... I guess I've found the 'elegant' one.
Please, replace the function 'drawpiegraph' in \hmg\source\graph\h_graph.prg with this:
function drawpiegraph(windowname,fromrow,fromcol,torow,tocol,series,aname,colors,ctitle,depth,l3d,lxval,lsleg,lnoborder)
local topleftrow := fromrow
local topleftcol := fromcol
local toprightrow := fromrow
local toprightcol := tocol
local bottomrightrow := torow
local bottomrightcol := tocol
local bottomleftrow := torow
local bottomleftcol := fromcol
local middletoprow := fromrow
local middletopcol := fromcol + int(tocol - fromcol) / 2
local middleleftrow := fromrow + int(torow - fromrow) / 2
local middleleftcol := fromcol
local middlebottomrow := torow
local middlebottomcol := fromcol + int(tocol - fromcol) / 2
local middlerightrow := fromrow + int(torow - fromrow) / 2
local middlerightcol := tocol
local fromradialrow := 0
local fromradialcol := 0
local toradialrow := 0
local toradialcol := 0
local degrees := {}
local cumulative := {}
local j,i,sum := 0
local cname := ""
local shadowcolor := {}
local previos_cumulative
_HMG_SYSDATA [ 108 ] [ GetFormIndex (windowname) ] := { fromrow , fromcol , tocol - fromcol , torow - fromrow }
if ! lnoborder
	DrawLine(windowname, torow  ,fromcol  ,torow  ,tocol  ,WHITE)
	DrawLine(windowname, torow-1,fromcol+1,torow-1,tocol-1,GRAY )
	DrawLine(windowname, torow-1,fromcol  ,fromrow  ,fromcol  ,GRAY )
	DrawLine(windowname, torow-2,fromcol+1,fromrow+1,fromcol+1,GRAY )
	DrawLine(windowname, fromrow  ,fromcol  ,fromrow  ,tocol-1,GRAY )
	DrawLine(windowname, fromrow+1,fromcol+1,fromrow+1,tocol-2,GRAY )
	DrawLine(windowname, fromrow  ,tocol  ,torow  ,tocol  ,WHITE)
	DrawLine(windowname, fromrow  ,tocol-1,torow-1,tocol-1,GRAY )
if len(alltrim(ctitle)) > 0
   if _iscontroldefined("title_of_pie",windowname)
      _releasecontrol("title_of_pie",windowname)
   define label title_of_pie
      parent &windowname
      row fromrow + 10
      col iif(len(alltrim(ctitle)) * 12 > (tocol - fromcol),fromcol,int(((tocol - fromcol) - (len(alltrim(ctitle)) * 12))/2) + fromcol)
      autosize .t.
      fontcolor {0,0,255}
      fontbold .t.
      fontname "Arial"
      fontunderline .t.
      fontsize 12
      value alltrim(ctitle)
	transparent .t.
   end label
   fromrow := fromrow + 40
if lsleg
   if len(aname) * 20 > (torow - fromrow)
      msginfo("No space for showing legends")
      torow := torow - (len(aname) * 20)
drawrect(windowname,fromrow+10,fromcol+10,torow-10,tocol-10,{0,0,0},1,{255,255,255})
if l3d
   torow := torow - depth
fromcol := fromcol + 25
tocol := tocol - 25
torow := torow - 25
fromrow := fromrow + 25
torow := torow + 1
tocol := tocol + 1
for i := 1 to len(series)
   sum := sum + series[i]
next i
   aadd(degrees,round(series[i]/sum * 360,0))
next i
sum := 0
for i := 1 to len(degrees)
   sum := sum + degrees[i]
next i
if sum <> 360
   degrees[len(degrees)] := degrees[len(degrees)] + (360 - sum)
sum := 0
   aadd(cumulative,sum)
next i
previos_cumulative := -1
fromradialrow := middlerightrow
fromradialcol := middlerightcol
for i := 1 to len(cumulative)
   shadowcolor := {iif(colors[i,1] > 50,colors[i,1] - 50,0),iif(colors[i,2] > 50,colors[i,2] - 50,0),iif(colors[i,3] > 50,colors[i,3] - 50,0)}
*	msginfo ( str(cumulative[i]) )
	if cumulative[i] == previos_cumulative
		loop
	previos_cumulative := cumulative[i]
   do case
      case cumulative[i] <= 45
         toradialcol := middlerightcol
         toradialrow := middlerightrow - round(cumulative[i] / 45 * (middlerightrow - toprightrow),0)
         drawpie(windowname,fromrow,fromcol,torow,tocol,fromradialrow,fromradialcol,toradialrow,toradialcol,,,colors[i])
         fromradialrow := toradialrow
         fromradialcol := toradialcol
      case cumulative[i] <= 90 .and. cumulative[i] > 45
         toradialrow := toprightrow
         toradialcol := toprightcol - round((cumulative[i] - 45) / 45 * (toprightcol - middletopcol),0)
      case cumulative[i] <= 135 .and. cumulative[i] > 90
         toradialrow := topleftrow
         toradialcol := middletopcol - round((cumulative[i] - 90) / 45 * (middletopcol - topleftcol),0)
      case cumulative[i] <= 180 .and. cumulative[i] > 135
         toradialcol := topleftcol
         toradialrow := topleftrow + round((cumulative[i] - 135) / 45 * (middleleftrow - topleftrow),0)
      case cumulative[i] <= 225 .and. cumulative[i] > 180
         toradialrow := middleleftrow + round((cumulative[i] - 180) / 45 * (bottomleftrow - middleleftrow),0)
         if l3d
            for j := 1 to depth
               drawarc(windowname,fromrow + j,fromcol,torow+j,tocol,fromradialrow+j,fromradialcol,toradialrow+j,toradialcol,shadowcolor)
            next j
      case cumulative[i] <= 270 .and. cumulative[i] > 225
         toradialrow := bottomleftrow
         toradialcol := bottomleftcol + round((cumulative[i] - 225) / 45 * (middlebottomcol - bottomleftcol),0)
         if l3d
            for j := 1 to depth
            next j
      case cumulative[i] <= 315 .and. cumulative[i] > 270
         toradialcol := middlebottomcol + round((cumulative[i] - 270) / 45 * (bottomrightcol - middlebottomcol),0)
         if l3d
            for j := 1 to depth
            next j
      case cumulative[i] <= 360 .and. cumulative[i] > 315
         toradialcol := bottomrightcol
         toradialrow := bottomrightrow - round((cumulative[i] - 315) / 45 * (bottomrightrow - middlerightrow),0)
         if l3d
            for j := 1 to depth
            next j
      endcase
   if l3d
      drawline(windowname,middleleftrow,middleleftcol,middleleftrow+depth,middleleftcol)
      drawline(windowname,middlerightrow,middlerightcol,middlerightrow+depth,middlerightcol)
      drawarc(windowname,fromrow + depth,fromcol,torow + depth,tocol,middleleftrow+depth,middleleftcol,middlerightrow+depth,middlerightcol)
next i
if lsleg
   fromrow := torow + 20 + iif(l3d,depth,0)
   for i := 1 to len(aname)
      if _iscontroldefined("pielegend_"+alltrim(str(i,3,0)),windowname)
         _releasecontrol("pielegend_"+alltrim(str(i,3,0)),windowname)
      cname := "pielegend_"+alltrim(str(i,3,0))
      drawrect(windowname,fromrow,fromcol,fromrow + 15,fromcol + 15,{0,0,0},1,colors[i])
      define label &cname
         parent &windowname
         row fromrow
         col fromcol + 20
         fontname "Arial"
         fontsize 8
         autosize .t.
         value aname[i]+iif(lxval," - "+alltrim(str(series[i],10,2))+" ("+alltrim(str(degrees[i] / 360 * 100,6,2))+" %)","")
         fontcolor colors[i]
	transparent .t.
      end label
      fromrow := fromrow + 20
   next i
return nil
Since I'm not the original code author, I could be missing something important. Please Test.
