Año(s), mes(es) y dia(s) transcurridos entre dos fechas
Source code related resources
tave2009
Post by tave2009 »
Hola Amigos:
En esta oportunidad les acerco una función para obtener: año(s), mes(es) y día(s), entre dos fechas ;)
:arrow: CalculaAMD( <FechaInicial>, <FechaFinal>) ==> cResultado
He buscado por los foros y no encontré algo que funcionara correctamente, por lo tanto decidí hacer mi propia función.
Espero sea de utilidad para quien quiera saber la edad o el tiempo transcurrido entre dos fechas.
El código fuente puede contener errores. Lo he 'testeado' sin novedad, pero ...
Saludos.
Walter.
Google Translation:
Hello Friends:
This time I approached a role for the year (s), month (s) and day (s) between two dates;)
: arrow: CalculaAMD (<FechaInicial>, <FechaFinal>) ==> cResultado
I've searched the forums and did not find anything that would work properly, so I decided to make my own function.
Hope this helps for those who want to know the age or the time between two dates.
The source code may contain errors. I've 'tested' without incident, but ...
Greetings.
Walter.
amd.zip
(5.3 KiB) Downloaded 577 times
Re: Año(s), mes(es) y dia(s) transcurridos entre dos fechas
Thanks. It will be really useful.
Hola Walter
It's nice you write in two languages ;)
tave2009 wrote:This time I approached a role for the year (s), month (s) and day (s) between two dates;)
Thanks to sharing :)
viewtopic.php?f=9&t=7&p=13
Hi Esgici,
I had made an assumption that months have 30 days, where as Walter is not assuming things and count for actual number of days, months and years.
rathinagiri wrote:Hi Esgici,
Thanks to you both :)
Viva HMG :D
rathinagiri wrote:where as Walter is not assuming things and count for actual number of days, months and years.
Yeah, this is a good differance !
Thank you Walter for sharing with us, I had appointed to your post by coincidence for same matter in other forum.
Muchas gracias Walter y felicitaciones !
One question Walter: Not all february has 28 days, did you treat that ?
In Spanish: Walter, no todos los meses de febrero tienen 28 dias, has tratado eso en tu rutina de código ?
Yes, he has.
Ahhh yes amigio Rathinagiri, Walter has treated this in:
if nMesActual == 2 so it is not using vetor...
Thanks !
Leopoldo Blancas
Post by Leopoldo Blancas »
Hola a todos...
Yo hice esta rutina para calcular la Edad o antigüedad entre dos fechas... Espero les sirva.
Hi all ...
I did this routine to calculate the age or seniority between two dates ... I hope they can.
FUNCTION CalculaEdad(cFechaNaci,cFechaHoy)
LOCAL FechaNaci:= CtoD(cFechaNaci)
LOCAL nAnoNaci := YEAR(FechaNaci)
LOCAL nMesNaci := MONTH(FechaNaci)
LOCAL nDiaNaci := DAY(FechaNaci)
LOCAL nAnoHoy
LOCAL nMesHoy
LOCAL nDiaHoy
LOCAL nDifAnos  := 0
LOCAL nDifMeses := 0
LOCAL nDifDias  := 0
LOCAL aEdad
LOCAL lAnosMenos := .F.
LOCAL aMesesDias := {}
LOCAL aBisiestos := {1904, 1908, 1912, 1916, 1920, 1924, 1928, 1932, 1936, 1940, 1944, 1948, 1952, 1956, 1960, 1964, 1968, 1972, 1976, 1980, 1984, 1988, 1992, 1996, 2000, 2004, 2008,2012,2016,2020,2024,2028,2032,2036,2040,2044,2048,2052,2056,2060,2064,2068,2076,2080,2084,2088,2092,2096,2100}
LOCAL lBisiesto := .F.
IF PCOUNT()=0
   MsgBox("Falta un parametro String Tipo Fecha '01/01/1900'")
ELSEIF PCOUNT()=1
   nAnoHoy := YEAR(DATE())
   nMesHoy := MONTH(DATE())
   nDiaHoy := DAY(DATE())
ELSEIF PCOUNT()=2
   nAnoHoy := YEAR(CtoD(cFechaHoy))
   nMesHoy := MONTH(CtoD(cFechaHoy))
   nDiaHoy := DAY(CtoD(cFechaHoy))
IF PosiArray(aBisiestos,nAnoNaci) != 0
   lBisiesto := .T.
AADD(aMesesDias,{1,'ENERO',31})
AADD(aMesesDias,{2,'FECBRERO',IIF(lBisiesto,29,28)})
AADD(aMesesDias,{3,'MARZO',31})
AADD(aMesesDias,{4,'aBRIL',30})
AADD(aMesesDias,{5,'MAYO',31})
AADD(aMesesDias,{6,'JINIO',30})
AADD(aMesesDias,{7,'JULIO',31})
AADD(aMesesDias,{8,'AGOSTO',31})
AADD(aMesesDias,{9,'SEPTIEMBRE',30})
AADD(aMesesDias,{10,'OCTUBRE',31})
AADD(aMesesDias,{11,'NOVIEMBRE',30})
AADD(aMesesDias,{12,'DICIEMBRE',31})
*--------------------------------------------PARA CALCULAR LOS AÑOS
IF nMesNaci < nMesHoy
   nDifAnos  := nAnoHoy - nAnoNaci
ELSEIF nMesNaci == nMesHoy
ELSEIF nMesNaci > nMesHoy
   nDifAnos := (nAnoHoy - nAnoNaci)-1
   lAnosMenos := .T.
*------------------------------------PARA CALCULAR LOS MESES Y DÍAS
   nDifMeses  := (nMesHoy - nMesNaci)
   nDifDias  := Abs(nDiaHoy - nDiaNaci)
   IF nDiaNaci < nDiaHoy
      nDifMeses  := nMesHoy - nMesNaci
      nDifDias  := nDiaHoy - nDiaNaci
   ELSEIF nDiaNaci == nDiaHoy
      nDifDias := 0
   ELSEIF nDiaNaci > nDiaHoy
      nDifMeses  := nMesHoy-1
      lMesesMenos:= .T.
      nDifDias := IIF(nMesNaci=1,aMesesDias[12][3]-nDiaNaci + nDiaHoy,aMesesDias[nMesNaci-1][3]-nDiaNaci + nDiaHoy)
   nDifMeses := (12-nMesNaci)+nMesHoy
aEdad:= {nDifAnos,nDifMeses,nDifDias}
RETURN aEdad
Polo
Polo
Leopoldo Blancas
Hola Walter...
Gracias por compartir. :D
Polo
Hello Walter ...
Thanks for sharing. : D
Polo
