How to open a table in .mdb
apichit
Post by apichit »
Hi all Friends
How can I open a table in .mdb file with HMG?
Thanks in Advance,
Apichit
Re: How to open a table in .mdb
HI :
#include "adordd.ch"
 USE test2.mdb VIA "ADORDD" TABLE "table1"
Sample :
 * Copyright 2002-2007 Roberto Lopez <harbourminigui@gmail.com>
 * Based on ADORDD sample included in Harbour distribution
#include "minigui.ch"
Function Main()
	DEFINE WINDOW Form_1 ;
		WIDTH 640 HEIGHT 480 ;
		TITLE 'MiniGUI AdoRDD Demo' ;
		MAIN NOMAXIMIZE ;
		ON INIT OpenTable() ;
		ON RELEASE CloseTable()
		@ 10,10 BROWSE Browse_1	;
			WIDTH 610	;
			HEIGHT 390	;
			HEADERS { 'First' , 'Last' , 'Birth' , 'Age' } ;
			WIDTHS { 150 , 150 , 100 , 100 } ;
			WORKAREA Test2 ;
			FIELDS { 'Test2->First' , 'Test2->Last' , 'Test2->Birth' , 'Test2->Age' } ;
			JUSTIFY { 0 , 0 , 2 , 1 }
	CENTER WINDOW Form_1
	Form_1.Browse_1.SetFocus
	ACTIVATE WINDOW Form_1
Return nil
Procedure OpenTable
   IF !IsWinNT() .AND. !CheckODBC()
	MsgStop( 'This Program Runs In Win2000/XP Only!', 'Stop' )
	ReleaseAllWindows()
   IF !FILE('test2.mdb')
	CreateTable()
   IF EMPTY( test2->( LastRec() ) )
	APPEND BLANK
	test2->First   := "Homer"
	test2->Last    := "Simpson"
	test2->Birth   := date() - 45 * 365
	test2->Age     := 45
	APPEND BLANK
	test2->First   := "Lara"
	test2->Last    := "Kroft"
	test2->Birth   := date() - 32 * 365
	test2->Age     := 32
   GO TOP
Procedure CloseTable
   USE
Procedure CreateTable
   DbCreate( "test2.mdb;table1", { { "FIRST",   "C", 10, 0 },;
                                   { "LAST",    "C", 10, 0 },;
                                   { "BIRTH",   "D",  8, 0 },;
                                   { "AGE",     "N",  8, 0 } }, "ADORDD" )
Static Function CheckODBC()
LOCAL oReg, cKey := ""
	OPEN REGISTRY oReg KEY HKEY_LOCAL_MACHINE ;
		SECTION "Software\Microsoft\DataAccess"
	GET VALUE cKey NAME "Version" OF oReg
	CLOSE REGISTRY oReg
Return !EMPTY(cKey)
salamandra
DBs Used: DBF, MySQL, SQL
Post by salamandra »
Hi apichit :) ,
Take a look at the sample located at ..\SAMPLES\RDD.SQL\mdb ;)
Think it´s what you need.
[]´s Salamandra
apichit
Post by apichit »
Thank you very much Danielmaximiliano, Salamandra
Hazael
Post by Hazael »
My favorite way is using SQLMIX. It works very well.
From Harbours contrib\sddodbc\tests folder (the examples are for command line CUI but you can easily adapt it to HMG):
 * $Id: test1.prg 18886 2013-03-02 01:24:02Z vszakats $
#require "rddsql"
#require "sddodbc"
#include "simpleio.ch"
REQUEST SDDODBC, SQLMIX
PROCEDURE Main()
#if defined( __HBSCRIPT__HBSHELL )
   rddRegister( "SQLBASE" )
   rddRegister( "SQLMIX" )
   hb_SDDODBC_Register()
#endif
   Set( _SET_DATEFORMAT, "yyyy-mm-dd" )
   rddSetDefault( "SQLMIX" )
   ? "Connect:", rddInfo( RDDI_CONNECT, { "ODBC", "DBQ=" + hb_DirBase() + "..\..\hbodbc\tests\test.mdb;Driver={Microsoft Access Driver (*.mdb)}" } )
   ? "Use:", dbUseArea( .T., , "select * from test", "test" )
   ? "Alias:", Alias()
   ? "DB struct:", hb_ValToExp( dbStruct() )
   Inkey( 0 )
   Browse()
   INDEX ON FIELD->SALARY TO salary
   dbGoTop()
   Browse()
   dbCloseArea()
Other approach (IMHO a bit more complex and for MySQL although you can do the same for MDB or any database connected via ODBC):
 * $Id: test2.prg 18886 2013-03-02 01:24:02Z vszakats $
#require "rddsql"
#require "sddodbc"
REQUEST SQLMIX, SDDODBC
PROCEDURE Main()
   LOCAL nConnection, nI, aI
   nConnection := rddInfo( RDDI_CONNECT, { "ODBC", "Server=localhost;Driver={MySQL ODBC 5.1 Driver};dsn=;User=test;database=test;" } )
   IF nConnection == 0
      ? "Unable connect to server", rddInfo( RDDI_ERRORNO ), rddInfo( RDDI_ERROR )
   ? nConnection
   ? rddInfo( RDDI_EXECUTE, "DROP TABLE country" )
   ? rddInfo( RDDI_EXECUTE, "CREATE TABLE country (CODE char(3), NAME char(50), RESIDENTS int(11))" )
   ? rddInfo( RDDI_EXECUTE, "INSERT INTO country values ('LTU', 'Lithuania', 3369600),('USA', 'United States of America', 305397000), ('POR', 'Portugal', 10617600), ('POL', 'Poland', 38115967), ('AUS', 'Australia', 21446187), ('FRA', 'France', 64473140), ('RUS', 'Russia', 141900000)" )
   ? dbUseArea( .T., , "SELECT * FROM country", "country" )
   ? "LASTREC:", LastRec()
   DO WHILE ! Eof()
      aI := Array( FCount() )
      FOR nI := 1 TO FCount()
         aI[nI] := FieldGet( nI )
      ? RecNo(), hb_ValToExp( aI )
      dbSkip()
   ENDDO
   dbCloseAll()
[quote=Qatan ]My favorite way is using SQLMIX. It works very well.[/quote]
Muchas gracias Qatan por la info
Qatan thank you very much for the info
Hazael
Post by Hazael »
You are welcome
